Visitor jnewcomb
ISE 14.1 Licensing Error
I have a problem getting the 32bit version of ISE 14.1 to work with my node locked license file. When I try to run implementation with the 32bit version of ISE it returns a Flexnet Licensing error:-9,57 . The 64bit version of ISE does not give this error but gives erroneous MAP errors and from reading the forums does not work correctly for Windows 10. I have the license file in both the c:\.Xilinx directory and in another directory but setting the path to either has not worked. The same license file works fine for Vivado but I need ISE to work on older devices.
Scholar drjohnsmith
Re: ISE 14.1 Licensing Error
That does mean purchasing a licence for Windows 7 .
If that's a concern, the Linux options could be lower cost
Hello @jnewcomb ,
What exact Operating System are you running ISE on? Is it Windows 10 OS?
In relation to ISE, Xilinx only supports the following operating systems on x86 and x86-64 processor
architectures.
This info can be found from these ISE related release notes:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/irn.pdf
Is that the case in your situation or are you trying to run ISE 14.1 on Windows 10 OS, which is unsupported version of OS for ISE 14.1?
If that is the case, then this is the reason why you are seeing this behaviour, as ISE 14.1 wasn't even tested on Win10, so this behaviour is expected in this case.
Can you confirm on the above please? Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Visitor jnewcomb
I realize that ISE is not officially supported by Windows 10 but the reality is customers have to support older devices not covered by Vivado and Windows 7 has not really been around for 7 years. I had ISE working under windows 10 in August of this year but had windows to crash on my system and thus have had to reinstall ISE. There are some steps that I had read before that someone had figured out to make it to work I just haven't found the right thread to find the instructions. I was posting this in hopes  that someone could point me to the right thread.
Hello @jnewcomb ,
I would suggest to you installing e.g. Windows 7 virtual machine on your Windows 10 OS and that way, you can then install Full ISE 14.1 on Win 7 VM.
That way you should be able to overcome this issue.
Hope this helps.
Kind Regards,
Anatoli Curran,
Scholar drjohnsmith
