ISE 14.6 System Generator license error
I'm using the following Software:
Windows 7 SP1 Enterprise 64 Bit
MATALB R2012b 32 Bit
ISE Design Suite 14.6
System Generator is installed and detects the MATLAB version.
Currently I'm using the free 30 days evaluation license.
While building the Simulink-model the following error occures:
--------------------------------- Version Log ----------------------------------
Version                                 Path
System Generator 14.6                   C:/Xilinx/14.6/ISE_DS/ISE/sysgen
Matlab 8.0.0.783 (R2012b)               C:/Program Files (x86)/MATLAB/R2012b
ISE                                     C:/Xilinx/14.6/ISE_DS/ISE
Summary of Errors:
Error 0001: ERROR: A license checkout has failed for System Generator...
     Block: Unspecified
Error 0001:
Reported by:
  Unspecified
Details:
ERROR: A license checkout has failed for System Generator for DSP (SysGen).
Please launch Xilinx License Configuration Manager (xlcm) program
to make sure that a valid license exists and it can be found by
the program.
In order to set XILINXD_LICENSE_FILE environment variable
correctly do the following.
1. Close the design and exit MATLAB.
2. Set environment variable, XILINXD_LICENSE_FILE, to point to
the valid license file or the license server.
3. Relaunch MATLAB and start System Generator process.
------------------- A message from the license manager --------------
INFO:Security:71 - If a license for part 'xc5vlx50t' is
available, it will be possible to use 'SysGen_TDP' instead of 'SysGen'.
INFO:Security:60 - The XILINXD_LICENSE_FILE environment variable
is set to 'D:\.Xilinx\Xilinx.lic'.
INFO:Security:63 - The LM_LICENSE_FILE environment variable is
not set.
INFO:Security:68 - For more information or for assistance in
obtaining
 a license, please run the Xilinx License Configuration Manager
       (xlcm or "Manage Xilinx Licenses".)
INFO:Security:68a - user is ad, on host NA-E6420-1205.
WARNING:Security:9b - No 'SysGen' feature version 2013.06 was
available for part 'xc5vlx50t'.
ERROR:Security:12 - No 'xc5vlx50t' feature version 2013.06 was
available (-15),
     so 'SysGen_TDP' may not be used.
Cannot connect to license server system.
 The license server manager (lmgrd) has not been started yet,
 the wrong port@host or license file is being used, or the
 port or hostname in the license file has been changed.
Feature:       SysGen
Server name:   localhost
License path:  D:\.Xilinx\Xilinx.lic;C:/Xilinx/14.6/ISE_DS/ISE/coregen/core_licenses\Xilinx.lic;C:/Xilinx/14.6/ISE_DS/ISE/coregen/core_licenses\XilinxFree.lic;C:/Xilinx/14.6/ISE_DS/EDK/data/core_licenses\Xilinx.lic;@localhost;
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".Cannot connect to license
server system.
Feature:       xc5vlx50t
Isnt the SysGen License included in the evaluation license?
Is there a free License for ISE 14.6?
Re: ISE 14.6 System Generator license error
From the license file, I can say that you are using ISE webpack license.
You cannot use Sysgen tool with ISE webpack license as mentioned above.
Vinay
I suspect if you are using webpack edition, please share yor license file for investigation
Features supported based on type of license is listed in below links, Sysgen needs either DSP edition or System edition
http://www.xilinx.com/products/design-tools/ise-design-suite/ise-webpack.htm
http://www.xilinx.com/products/design_tools/vivado/vivado-webpack.htm
Please check this discusion
http://forums.xilinx.com/t5/Installation-and-Licensing/System-Generator-Webpack-License/td-p/238298
Aslo you can open XLCM by going to start --> ISE Design Suite --> Accesories --> Manage Xilinx licenses and check if you are able to  see Sysgen in the feature column.
Hope this helps
Vanitha
Yes if you are using System edition or dsp edition in 30 days evaluation mode then it will include license for System generator.
we don't have any free licenses for system generator.
Satish
Sorry, frist I installed Web Edition. Now DSP Edition is installed.
License file is attached.
Vinay
Okay, so the problem is that I created a webpack license by mistake and now it is not possible to create a 30 day evaluation license because I already created a license file?
So I have to call the support to help me out.
Thanks for the fast reply.
