oldradarguy
ISE 14.7 on Windows 10 crashes
I’m trying to use ISE 14.7 in Windows 10.
ISE 14.7 starts okay, but if I click on New Project, it crashes.
I was able to get it to run by clicking on an *.xise file, but if I close that project and try to open another project, I get this popup error:
_pn.exe
_pn.exe has stopped working
Kind of frustrating not being able to open and close projects in ISE.
There's a link to a video in a different post, but that video has been removed.
nupurs
@oldradarguy,
See if this AR helps in your case:
https://www.xilinx.com/support/answers/62380.html
Nupur
nupurs
@oldradarguy,
Nupur
salman
Why does ISE 14.7 crash on windows 10? Are those devices no longer supported? It would crash on startup while creating a new project and I found one solution to rename some Portability dlls in the installed files. Now it runs but I am getting real weird behavior and sometimes weird screen dialogs on occasion that seem messed up (illegible).  Do I need to install a Win7 VM to use Spartan 6 devices?
ansarimo
Hi @salman,
Spartan-6 is supported on ISE 14.7, Which ISE 14.7 are you using is it ISE 14.7 win10 VM version or ISE 14.7 win7 version?
Please share the above information by raising a new forum topic particularly for your issue so that community can help you in a better way.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
