ISE 17.7 Webpack: ngdbuild.exe has stopped working - APPCRASH in libUtilC_MessageDispatcher.dll
Hallo,
can anybody help me with this issue. I installed ISE 14.7 Webpack on a Win 7 Enterprise SP1 64 bit computer, but I am unable to build any project. Even the example projects are not working, regardless if I try the 32 or 64 bit Version of the program:
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: ngdbuild.exe
  Application Version: 0.0.0.0
Application Timestamp: 525ad60c
  Fault Module Name: libUtilC_MessageDispatcher.dll
  Fault Module Version: 0.0.0.0
  Fault Module Timestamp: 525ace07
  Exception Code: c0000005
  Exception Offset: 0000000000013eda
  OS Version: 6.1.7601.2.1.0.256.4
  Locale ID: 1031
  Additional Information 1: 020e
  Additional Information 2: 020e9c9ae0a112d20ab2161a962b669c
  Additional Information 3: 136e
  Additional Information 4: 136e798186f1eca886ca9465da6be1e3
Re: ISE 17.7 Webpack: ngdbuild.exe has stopped working - APPCRASH in libUtilC_MessageDispatcher.dll
Check this thread: http://forums.xilinx.com/t5/Embedded-Development-Tools/Failed-to-read-dll-file-during-Project-gt-Generate-Netlist-for/td-p/67453
It may help you.
Vinay
Looks like machine specific issue.
Can you try replacing that error causing dll with the working dll and check if that helps?
Before replcing the dll please make sure that you may have a copy of the dll that already exists in your machine.
 For 64-bit system you can try replacing this dll with the attached dll in your  ISE installed folder.(C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64)
Please make sure that you will copy the existing dll before you replace with the attached dll.
@vuppala
Thanks for your hint. I checked the PATH enviroment and found no reference to the ISE installation. Also there was not older ISE version installed on this computer. What I did is, that I installed vivado before and uninstalled it after I learned that it does not support the Spartan-6 anymore, that I need for this project.
@pulim
I downloaded your dll and renamed ever dll with this name I found. There are 3 in the 32 bit and also 3 in the 64 bit installation path. From the size I guessed that yours is the 64 bit version, so I copied it to all 3 folders and started the 64 bit Project Navigator, but I got the same issue. You seem to be also right, that it is a computer specific issue, it works on an older computer with Vista using the same installation media.
Thank you for your quick responses!
Did you give a try uninstalling the software and re-installing it from scratch?
yes, I also tried a reinstallation. And  I repeated the installation on the other computer from the same media, since I first assumed something got corrupted because of  the big download.
Try running ngdbuild in command line mode and see if this helps.
Vinay
if i start it from the dos command shell without any arguments I get a slightly different error message, if I add C:\Xilinx\14.7\ISE_DS\.xinstall\bin\nt64 to the PATH enviroment I get the same  error as in my first message.
Problem Event Name: BEX64
  Fault Module Name: btprof64.dll_unloaded
  Fault Module Timestamp: 4bf687cc
  Exception Offset: 0000000006653ed8
  Exception Data: 0000000000000008
  Locale ID: 1031
  Additional Information 1: e520
  Additional Information 2: e520f4d54c8f98dfbb942580624b81f9
  Additional Information 3: 98e8
  Additional Information 4: 98e87225aa28635e49f0d5554edf9d18
I suspect the issue is due to corrupt install.
Do you have any other machine that has ISE installed and working without any issue?
Vinay
