ISE/EDK Node Locked License failed to built bitstream
I have purchased a Node Locaked License for ISE/EDK and installed sucessfully(saw C:\.Xilinx\Xilinx.lic).
But EDK generated following error message when I tried to built bitstream.
It seems the license didn't work because EDK thought it is WebPack or tried to get floating license.
How to fix this issue?
JY
# Starting program map
# map -o system_map.ncd -w -pr b -ol high -timing -detail system.ngd system.pcf
Release 14.6 - Map P.68d (nt64)
Copyright (c) 1995-2013 Xilinx, Inc. All rights reserved.
PMSPEC -- Overriding Xilinx file
<C:/Xilinx/14.6/ISE_DS/EDK/data/Xdh_PrimTypeLib.xda> with local file
<C:/Xilinx/14.6/ISE_DS/ISE/data/Xdh_PrimTypeLib.xda>
Using target part "6vlx240tff1156-1".
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
INFO:Security:56 - Part 'xc6vlx240t' is not a WebPack part.
INFO:Security:60 - The XILINXD_LICENSE_FILE environment variable is set to
'C:\.Xilinx\Xilinx.lic'.
INFO:Security:62 - The LM_LICENSE_FILE environment variable is set to
INFO:Security:68 - For more information or for assistance in obtaining
a license, please run the Xilinx License Configuration Manager
(xlcm or "Manage Xilinx Licenses".)
INFO:Security:68a - user is user, on host name.
WARNING:Security:9b - No 'ISE' feature version 2013.06 was available for part
'xc6vlx240t'.
ERROR:Security:12 - No 'xc6vlx240t' feature version 2013.06 was available (-15),
so 'WebPack' may not be used.
Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: ISE
Server name: localhost
License path:
C:\.Xilinx\Xilinx.lic;C:\Xilinx\14.6\ISE_DS\ISE\/coregen/core_licenses\Xilinx.li
c;C:\Xilinx\14.6\ISE_DS\EDK/data/core_licenses\Xilinx.lic;@localhost;
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".Cannot connect to license server system.
Feature: xc6vlx240t
License path:
ERROR:Map:258 - A problem was encountered attempting to get the license for this
architecture.
Design Summary
Number of errors : 1
Number of warnings : 0
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
Done!
Re: ISE/EDK Node Locked License failed to built bitstream
Can you attach your license file and xinfo here?
To generate xinfo,
1. run the command in "xinfo" if you are using linux.
2. If you are using windows, go to start --> all Programs --> Xilinx Design Tools --> ISE Design Suite 14.6 --> Accessories --> Xinfo System Checker
Vinay
Moving to licensing board.
Thanks,Vijay
See attached files.
This license issue has been hold my work.
I hope it will be fixed as soon as possible.
Junbo
Thanks for sharing the license file and xinfo.
from the xinfo, I observe that you have only EDK and SDK licnese.
For running MAP and PAR process, you need a ISE license. See this answer record for more information: http://www.xilinx.com/support/answers/42063.html
Vinay
This is coufused me because the local xilinx representive told me to get EDK license for my design.
I think I had to get ISE EDK license.
By the way, can you remove two attached files posted before?
JY
Yes, you have to get ISE license for running MAP and PAR process.
And why do you want to remove the attachments??
Vinay
