01-15-2016 02:31 AM
Hello All,
When I am trying to running map, I am getting the following error message:
Started : "Map".
Running map...
Command Line: map -intstyle ise -p xc6slx9-tqg144-2 -w -logic_opt off -ol high -t 1 -xt 0 -register_duplication off -r 4 -global_opt off -mt off -ir off -pr off -lc off -power off -o logipi_machine_vision_map.ncd logipi_machine_vision.ngd logipi_machine_vision.pcf
Using target part "6slx9tqg144-2".
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
INFO:Security:54 - 'xc6slx9' is a WebPack part.
INFO:Security:61 - The XILINXD_LICENSE_FILE environment variable is not set.
INFO:Security:63 - The LM_LICENSE_FILE environment variable is not set.
INFO:Security:68 - For more information or for assistance in obtaining
a license, please run the Xilinx License Configuration Manager
(xlcm or "Manage Xilinx Licenses".)
INFO:Security:68a - user is armen_gev, on host unknown.
ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2013.10 was available
for part 'xc6slx9'.
No such feature exists.
Feature: WebPack
License path:
/home/armen_gev/.Xilinx/Xilinx.lic:/opt/Xilinx/14.7/ISE_DS/ISE//data/*.lic:/opt/
Xilinx/14.7/ISE_DS/ISE//coregen/core_licenses/Xilinx.lic:/opt/Xilinx/14.7/ISE_DS
/ISE//coregen/core_licenses/XilinxFree.lic:/opt/Xilinx/14.7/ISE_DS/EDK/data/core
FLEXnet Licensing error:-5,357
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".No such feature exists.
Feature: ISE
License path:
ERROR:Map:258 - A problem was encountered attempting to get the license for this
architecture.
Design Summary
Number of errors : 1
Number of warnings : 0
Process "Map" failed
Could you please let me know how to resolve this problem ?
Tools and additional details:
I've read the solutions in this forum and checked my license but nonetheless, I can't seem to figure out my problem.
Please not that the 'xinfo' and licnese are attached.
Thanks in advance,
Armen
01-15-2016 02:49 AM
From the Xinfo.txt i see that Your Xilinx License is not picked up.
Make sure you have set the XILINXD_LICENSE_FILE pointing to correct License location.
Check the below AR#38293
http://www.xilinx.com/support/answers/38293.html
--Syed
01-15-2016 02:51 AM
Your License is evaluation License for Vivado HLS. So it can only be used for HLS and not for ISE.
--Syed
01-16-2016 03:54 AM
Thank you Syed very much for clarifications.
The thing is the following that currently I am unable to generate license for the ISE design suite (in getting license there is no option for the ISE) and it seems that spartan 6 is not supported in Vivado HLS.
Could you please give me advice how can I proceed with the 'xc6slx9' package ?
Thanks in advance,
Armen
01-16-2016 09:47 AM
Check below link to get list of supported devices in webpack license:
http://www.xilinx.com/publications/matrix/Software_matrix.pdf
Do you have any purchased license?
Yes, Vivado only supports 7-series and above devices.
Anusheel
Helpful answer -> Give Kudos
01-16-2016 02:44 PM
Hi Anusheel,
<<< Do you have any purchased license?
I am trying to use a 30-day evaluation license
Alos I found out that here this topic was discussed and guys were advised to communicate with nearest Xilinx Distributors.
For me it's becaming closed circle.
Armen
01-17-2016 08:02 PM
Yes, as mentioned in the thread/link in your post, you have to contact your nearest distributor for 30-day ISE evaluation license.
Vinay
