david.gill
ISE Foundation 7.1 download
I am trying to recompile an old project that was done with ISE 7.1.  The Xilinx archive downloads only have EDK and ISE 7.1 service packs.  Can somebody from Xilinx make this available somehow?  I'm assuming it exists out there somewhere.
vuppala
Hi @david.gill
Can you fill this form and raise a request for ISE 7.1: https://secure.xilinx.com/webreg/register.do?group=download_req
Vinay
u4223374
Advisor
Advisor
I can see a link to the full 7.1 download on the archive page; mayeb someone from Xilinx has seen your post and fixed it.
vuppala
Hi @david.gill
Its available on Downloads page.
Here is the link: https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/archive.html
Vinay
balkris
https://forums.xilinx.com/t5/General-Technical-Discussion/How-to-download-ISE-classics-without-redirect-to-newer-versions/td-p/254680
Thanks and Regards
Balkrishan
david.gill
Thanks guys, but if you expand 7.1 on the downloads page, there is only EDK, Programming Tools and some service packs.  The zip file that was shared was also just the EDK.  I am looking for the ISE Foundation.  If you look at all the other old software versions they all have both EDK and ISE.
I tried the EDK installation just in case and ISE is not a part of it.  I'm fairly certain it exists as I do have a product key for it that is not that same as the product key for the EDK.
u4223374
Advisor
Advisor
@david.gill My mistake, you're completely correct. Something similar seems to have happened with ISE 3.1 (there are the service packs available, but no software download).
@balkris@vuppala Any chance of seeing the archives updated with the full ISE WebPack installer? It'd also be great if there was a bit more information available next to each one (eg. which devices are supported). I know you can find that information elsewhere, but having it on the ISE download page would be logical.
david.gill
Anybody from Xilinx with a real answer to the question?  Is there an ISE Foundation 7.1 out there somewhere in existence?  Maybe our project notes are wrong and Foundation 7.1 never existed?
Again, it is definitely NOT on the downloads page.  I know where that it, and it's the first place I looked.  And I am NOT looking for the 7.1 EDK.
Obviously I can just use a different software version, but it would be great to get an answer to the question.
Thanks!
vuppala
Hi @david.gill
Vinay
david.gill
@vuppala,
Thanks, I'll give that a try.
david.gill
The download request did the trick.  I would attach it to share with everyone but the file size is too big.
peterfrey
I am also trying to get a hold of the ISE Foundation 7.1i Full product installation files.  They are still not on the archive download page.  I filled out the "Download Workaround Request Form" and got an email that the request was received last Thursday (Oct 5), but have yet to hear anything.  Where else can I go for this?
Thanks!
