Visitor cederom
ISE on FreeBSD and dynamic libraries *.so dependencies
Some time ago I have switched from Linux to FreeBSD because Linux is a mess. I can emulate linux applications, I could run ISE 11 on my BSD using this technique. ISE 12 however was is missing some dynamic libraries, but I found them on the installation "lib/lin" subdirectory, then added this directory to /usr/compat/linux/etc/ls.so.conf.d/xilinx-ise12.conf and rerun /usr/compat/linux/sbin/ldconfig -i. Maybe some of you may like this solution :-)
Best regards,
Tomek
Visitor cederom
Re: ISE on FreeBSD and dynamic libraries *.so dependencies
This problem is caused by improper linking the dynamic libraries path into Xilinx ISE - the libraries are on the LDPATH but they are not loaded by ISE, so the solution is to link them where ISE wants them to be. I have posted solution on FreeBSD forums [1] and have working Xilinx ISE 13.1.
Still I have no working cables. The cable drivers are even not working on Linux, as the kernel API again changed... this is why Linux is a mess. Why dont you release version for FreeBSD instead Xilinx? :-)
Is there any way to make cable working on FreeBSD???
[1] http://forums.freebsd.org/showthread.php?t=17776&highlight=xilinx
Visitor cederom
Visitor cederom
Anyway, please provide dynamic libraries within the installer package as those libraries ase VERY helpful in running linux binaries on non linux systems...
