sridhargunnam
Image processing IP core bundled license
Hi all, and @florent
Is there a documentation which gives us an idea of different IP cores most used in Image processing? Do you know if there is a bundled license package that I can purchase?
I am a research student and funds for the license are limited. So I need to look in terms of price point as well. (Please let us know if there are any special offers for student researchers.)
Sridhar
balkris
Please contact your local FAEs for buying option . The most of the IP freely avaialble or full hardware evaluation license available for these IPS .
Check the Vivado IP catalog for list of IPs
You can check product page of all the IPs here
https://www.xilinx.com/products/intellectual-property/audio-video-and-image-processing/nav-image-processing.html
https://www.xilinx.com/products/intellectual-property/video-processing-subsystem.html#overview
For FAEs contact check this page
https://www.xilinx.com/about/contact/sales-reps.html
Core evaluation license
https://www.xilinx.com/products/intellectual-property/video-processing-subsystem/video-processing-subsystem-evaluation.html
License status for specific IP you can check in IP catalog
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
florentw
Hi @sridhargunnam,
I don't think there is a document. But Xilinx does not have that many image processing IP. It is mainly the Video Processing Subsystem, the GAMA LUT, the demosaiser and the Video mixer.
As @balkris, you might want to talk to an authorized distributor about this. He might point you to our partner omnitek which has more video processing IPs.
You might want to do you own video processing IPs using HLS
Best Regards,
Florent
Florent
