boshkey
Install Different version of vivado on the same windows machine
Dear Fellows,
        I am preparing to install two versions of vivado design suite(2016.2 and 2017.2) on the same Windows machine. Is there any known problems about such operation? For compatiblility, I don't want to upgrade the suite.
hemangd
Hi @boshkey,
You can install multiple versions of Vivado on your windows machine. No issue in that.
But make sure you are using supported windows for both the versions. (Check below mentioned link for supported OS for respective Vivado versions.)
https://www.xilinx.com/support/answers/54242.html
hemangd
hemangd
hemangd
Hi @boshkey,
hemangd
hemangd
thakurr
@boshkey
There should not be any problem as long as you have sufficient memory to run the tools. Please find the below link for FPGA memory recommendation for using Vivado tool:
https://www.xilinx.com/products/design-tools/vivado/memory.html
Rohit
Rohit
u4223374
Advisor
Advisor
At one point I had 2015.2, 2015.4, 2016.1, 2016.2, 2016.3, 2016.4, 2017.1, and 2017.2 installed on the same machine - they don't interfere with each other at all.
boshkey
Thank you for your advice.
boshkey
Thank you kindly
boshkey
Thank you kindly.
jbdxilinx
I have recently installed Vivado 2018.2 on my Windows 10 PC. I also have 2015.4, 2016.2, and 2017.2 installed on the same PC.
When I open a design in 2016.2 that was created using 2016.2 and try to load that design into a Zynq-7000 using 2016.2 and a USB Platform II cable, neither SDK nor Vivado can detect the cable.
The cable works fine with 2018.2 with a design created in 2018.2. I've tried multiple cables and boards, no luck. Anyone else have a similar problem?
