Newbie mte160330
Install Enable VT-x in bios to continue install
I have enabled VT-x in bios and still receiving the error message.
Re: Install Enable VT-x in bios to continue install
Hello @mte160330,
Please check the below forum topic (specifically check @azad.jalali last response, as this could be the same situation in your case), and see if this would help you too:
https://forums.xilinx.com/t5/Installation-and-Licensing/ISE-Windows-10-version-does-not-install/td-p/820223
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @mte160330,
Hope this helps.
Kind Regards,
Anatoli Curran,
