darwineg
Install of ISE 14.7_VM on windows 10 Pro
I am trying to install ISE 14.7_VM on my machine, which is running windows 10 Pro. I get the following error at the end of the installation: "C:\Xilinx\13.2_VM\vboxmanage"' is not recognized as an internal or external command. This causes the installation to fail. Is there a solution for this issue:
Thank you
ansarimo
Hi @darwineg
ISE 14.7 on windows10 is supported through VirtualBox.
For successfully installing ISE 14.7 win10 version, Please refer to the below steps and verify if you have followed the same:
  1. You need to install the Virtual Box windows hosts(5.2.34)
  2. Enable Virtualization from BIOS on your PC
  3. Install ISE 14.7 Win 10 from the xsetup.exe as normal
Note: The version of Oracle VirtualBox officially supported by Xilinx is 5.2.34 and needs to be installed before running xsetup.exe
Refer to the following user guide for additional information on ISE 14.7 VM Win10 version and also check the steps for installing it.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-ise-vm-windows10.pdf
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
ansarimo
Hi @darwineg
Thanks and Regards,
Ansari Hunen
