MonicaEzzat
Installation and licensing
I am trying to download the Vivado design suit 2020 for 30 days trial however i keep getting the following message
Please correct the errors and send your information again.
We cannot fulfill your request as your account has failed export compliance verification.
any help?
Thanks in advance
ansarimo
Hi @MonicaEzzat ,
Have you checked this Answer Record in relation to the Failed export compliance issue?
https://www.xilinx.com/support/answers/44043.html
please send an email to Xilinx Customer Support (websupport@xilinx.comindicating your "export compliance" issue and they in turn will contact Xilinx Global Trade Compliance team on your behalf, who would be able to screen and verify your profile and if all is good, re-activate this then, so that you can then login and download the required software without issues.
Hope this helps.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
ansarimo
Hi @MonicaEzzat ,
Hope this helps.
Thanks and Regards,
Ansari Hunen
