puja
Installation of Vivado webpack on Ubuntu Linux 18.04 LTS (64 bit)
Dear Sir,
I have installed Vivado 2018.3 successfully on the above mentioned OS. I am facing following two issues:
1. I am unable to create desktop shortcut of Vivado 2018.3.
2. Whenever I want to create a new project, an error message pops up which says : need to change the permission setting of directory.
Please help me out to resolve above issues.
Thanks and Regards,
Puja Kumari
anatoli
Hello @puja,
See if the workaround in this Answer Record would help you to overcome these issues: https://www.xilinx.com/support/answers/63098.html
This also has a .pdf file on how to set up icons on the Ubuntu OSs. This should help you too.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
