gszakacs
Professor
Professor
Installed ISE 14.5 and dongle-based nodelocked license does not work for new version
I have been using ISE Embedded edition with a nodelocked license tied to a flex dongle
(USB "9" series).  When I open the license manager for ISE 13.4, everything looks fine.
The ISE 14.5 license manager says the host ID does not match.  Is there something
I need to update for licensing with version 14.5?
Here's a screen shot showing license managers for 13.4 (background) and 14.5  Note that
the dongles don't show up in the status bar of 14.5
-- Gabor
graces
Check out this answer.
http://www.xilinx.com/support/answers/55509.htm
graces
gszakacs
Professor
Professor
Thanks for the answer.
I also had ISE 14.2 installed on the same machine and noted that it does not exhibit the
same problem.
On an aside, I tried to go back to the downloads page to see if this answer record was noted
in the "known issues" for ISE 14.5, but the ISE page was not available:
503 Service Temporarily Unavailable
This patch seems important enough to show up on the download page.  Note that I
downloaded 14.5 just this week, so the answer record and patch already existed at
that time.
-- Gabor
graces
Hi Gabor,
It's linked from 14.5 - known issues in Download page > AR #46491 > (Xilinx Answer 47297) 14.x ISE - Known Issues for Xilinx software licensing in ISE Design Suite 14.x.
