me-3
Installing ISE 14.7 on a PC without IP/www
i am just trying to get ISE Licensing to work.
The PC has no IP (ipconfig/all is without entries, network deactivated)
The Licensing Management Tool says Licencing is succesful, but most functions doesn't find a
license.
Example:
ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2013.10 was available
ERROR:Map:258 - A problem was encountered attempting to get the license for this  architecture.
Xilinx.lic is attached
Marc
nupurs
Hi @me-3,
This is a Vivado webPACK license. It cannot be used for ISE. For using ISE generate a ISE license.
Nupur
Nupur
me-3
Hello Nupur,
thanks for your answer.
I thought this already but all I got during first attempt was the Vivado licence.
I had to generate a ISE Lic using the Manage Licence Tab on Xilinxs website.
This should be mentioned...
Marc
vuppala
Hi @me-3
The license names are mentioned in the "Create New Licenses" tab of Xilinx Licensing Site.
Also while generating the license, after providing the host id information, the information is providing for "Review".
Vinay
sandeepmarode
I too faced the similar issue and getting the same error. The license file I am able to down load is only for Vivado.
The product licensing page does not lists ISE license. How I can generate ISE 14.7 evaluation or free Webpack edition license?
Does XILINX has discontinued support for downloading ISE licenses?
Thanks in advance for helping me.
vuppala
Hello @sandeepmarode
Can you share the snapshots of "Create New Licenses" and "Manage Licenses" tabs of Xilinx Licensing site.
Vinay
