Installing SDAccel ubuntu 2018 (app from windows 10)
Hey, I downloaded SDx 2019 the full installation file. I'm using windows 10. Windows 10 has an ubuntu 2018 in it's store. When I try to install the SDx using that ubuntu bash (sudo ./xsetup) , at first I've got these errors:
ERROR: Installer could not be started.
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
java.awt.HeadlessException:
at java.desktop/java.awt.GraphicsEnvironment.checkHeadless(Unknown Source)
at java.desktop/java.awt.Window.<init>(Unknown Source)
at java.desktop/java.awt.Frame.<init>(Unknown Source)
at java.desktop/javax.swing.JFrame.<init>(Unknown Source)
at h.b.<init>(Unknown Source)
at com.xilinx.installer.gui.G.<init>(Unknown Source)
at com.xilinx.installer.gui.InstallerGUI.<init>(Unknown Source)
at com.xilinx.installer.gui.InstallerGUI.<clinit>(Unknown Source)
at com.xilinx.installer.api.InstallerLauncher.main(Unknown Source)
I tried
export DISPLAY=:0.0
but after that when I type sudo ./xsetup , nothing happens ..! I shave to hit ctrl+c to get out of that situation
What should I do?
Re: Installing SDAccel ubuntu 2018 (app from windows 10)
I solved it. I used an X server (Xming). Now I'm running SDAccel setup on ubuntu 18 windows subsystem.
