rkfournier
Installing Vivado 2018.2 corrupts the Vivado 2018.1 Installation
I installed Vivado 2018.2 on a Windows 7, 64-bit computer and it is working correctly. However the prior 2018.1 installation is now corrupted so that it cannot be uninstalled.
How can I uninstalled Vivado 2018.1?
See the attached file for the effect on the Windows start menu.
rkfournier
I removed 2018.1 Windows program groups, then deleted the 2018.1 files. I also checked the registry, which I found had been updated for 2018.2.
rkfournier
