beep7886
Installing floating license for ISE
I purchased Vivado design suite last week which also came with ISE embedded floating license as well.  I am trying to get the ISE floating license up and running so I can have access to the full parts list for the Virtex 4 family, (I want to build for LX160).  I am having some issues getting the license to work.  I downloaded flexlm_v11.11 and used the steps found on this forum in a different thread to get my floating license to show up on the Xilinx License Configuration manager as shown below
lmgrd.exe -c C:\Xilinx\Xilinx.lic
XILINXD_LICENSE_FILE: 2100@navabs-PC;C:/Xilinx/Xilinx.lic
LM_LICENSE_FILE: 2100@navabs-PC;C:/Xilinx/Xilinx.lic
I attached an image so you can see that the floating license is shown on my XLCM.  When I go to start a new project the full devices are not showing up, (I still cant select the part I want, which is Virtex 4 XC4VLX160).  I was told by a Xilinx rep that I have been  emailing that "it appears as though you have the full ISE loaded in your license manager...... but many not have installed it"
What steps am I not covering??
Thanks in advance for the help
Brandon
arpansur
Hi @beep7886,
Were the suggestions helpful?
Arpan
arpansur
Hi @beep7886,
I think by mistake you installed webpack. It's not issue with license rather your installation.
Please check if you are able to select the webpack devices listed in snapshot. If you are able to select the webpack devices and not able to see non webpack devices then you need to reinstall ISE e.g.; embedded edition according to your requirement
Arpan
arpansur
Hi @beep7886,
Arpan
beep7886
Yes thank you so much for the help and quick response.
