beandigital
Issue installing Vivado 2015.4 from web
I am having an issue installing from the web based application. It just keeps saying it cant connect to the internet. My login is fine as I can logon to the website. I read someone else had this issue and it was a problem with JAVA. This was using Linux but I am on Windows.
nupurs
Check if this AR helps you:
http://www.xilinx.com/support/answers/64656.html
Accept as solution if it resolved your query, give kudos if the post is useful.
Nupur
beandigital
If I look in the log file I see this error
2016-01-29 13:41:04,546 ERROR: k.b:? - The proxy host: unstopp.me/wpad.dat?f2a18c5a1f4d82ab4de4f9f895be20092043426 is invalid
Any idea what the issue is?
nupurs
Set you proxy settings properly. Refer to page 22 of this link:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf
Nupur
beandigital
But I have never had to do that before. I am trying to install it on my laptop which is failing. I have already done it on my desktop without any issues.
nupurs
Which version of windows is this?
Can you paste the install.log file here?
Nupur
beandigital
I have manged to use the downloaded data from the desktop pc to install on the laptop.
nupurs
So, is your issue resolved?
If so, close this thread by marking an appropriate reply as solution in the interest of other users.
Nupur
