Issue installing xrt Ubuntu 2018
Hi, I wanted to install xrt on Ubuntu 2018. At first I got a message to install some packages. After I installed them, I wanted to reinstall XRT. But I got these messages:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'xrt' instead of './xrt_201910.2.2.2173_18.04-xrt.deb'
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 22 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Get:1 /mnt/c/users/reza/Downloads/xrt_201910.2.2.2173_18.04-xrt.deb xrt amd64 2.2.2173 [7115 kB]
(Reading database ... 122769 files and directories currently installed.)
Preparing to unpack .../xrt_201910.2.2.2173_18.04-xrt.deb ...
Unloading old XRT Linux kernel modules
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.4.0-18362-Microsoft/modules.dep.bin'
Unregistering XRT Linux kernel module sources 2.2.2173 from dkms
Progress: [ 0%] [..................................................................................................]
And the progress won't proceed. I did some searches and I found that I have to reinstall linux image. So when I wanted to do that, I get these:
E: The package xrt needs to be reinstalled, but I can't find an archive for it.
It seems that it's like a loop. I can't fix XRT unless I fix the image and I can't fix image unless I fix XRT !!!!!!!!!!!!!!!!
Any idea?
I fixed it by reinstalling my linux kernel image with following commands:
uname -r
sudo apt-get update
sudo apt-get dist-upgrade
uname -r
sudo apt-get update
