Java NullPointerException when trying to uninstall Vivado 2016.3 or to install 2017.3
Hi All,
I was trying to make some room on my drive by removing Vivado 2016.3. When I launch the uninstaller, I get an error message:
There was an error loading installation data. Please refer to the log file (...) for more information.
The log file is attached to this post.
I had the same kind of trouble when I installed Vivado 2017.3. There, I was able to install only when I ran the installer from sudo bash. If launched in a normal shell, I would also get NullPointerExceptions and graphical issues in the installer.
I'm working on Ubuntu 16.04.
The solution is to use the xsetup tool that is stored in the correct location. For every Vivado version, there are TWO copies of the xsetup tool!
1) /opt/Xilinx/Downloads/Vivado_2017.3/xsetup
2) /opt/Xilinx/.xinstall/Vivado_2017.3/xsetup
You must use the second tool, as the first one will not work.
Also, you need to run it from a sudo bash, just running it as sudo will not work.
I don't understand why Xilinx puts two copies of the tool on my disk, and why only one of them will work.
Hi @welo_zhaw,
Try to delete the contain of AppData\Roaming\Xilinx\Vivado. You will find this directory in USER directory.
After deleting this content , check whether you face this java Nullpointer error or not.
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi @hemangd,
The path you mentioned looks like a Windows path. I'm working on Ubuntu. Would you happen to know where I would find the corresponding directory on Ubuntu?
Regards, welo_zhaw
Hi @welo_zhaw,
Usually, when you write pwd in tcl console, it lets you know the default working directory that is used when the Vivado tool is opened.
hemangd
hemangd
Hi @hemangd,
Using the 'pwd' will give me the workspace path. I don't think erasing the workspace will achieve much except deleting my work.
Again, my goal is to launch the Uninstaller for Vivado 2016.3 and I can't launch it because of the NullPointerException. These NullPointerExceptions have started occurring during the installing I of Vivado 2017.3.
The contents of the logfile I attached to the initial post don't provide a lot of information, but to me it looks like a problem in the installer api.
Is it safe to just erase all the directories belonging to the Vivado 2016.3 install?
welo_zhaw
