muneet
Kintex-7 ffg900 -2 board license issue in vivado 2018.1.
Our server has valid license for vivado 2018.1. But it is giving license error in case we use Kintex-7 ffg900 -2 board for synthesis. Other licensed boards are working fine. Is there a solution for this or is it the issue of vivado version and will be fixed in the upcoming releases?
anatoli
Hello @muneet,
Thanks for sharing this info.
As correctly indicated by @nupurs, from this Answer Record: https://www.xilinx.com/support/answers/69377.html, you can read that Vivado 2017.3 (and newer Vivado releases, e.g. 2017.4, 2018.x etc.) now uses FlexLM 11.14.1.0, which older floating server machines cannot provide licenses to unless the license utilities version matches or is newer.
Therefore, all of the floating license users must upgrade their license utilities in order for licenses to be picked up in Vivado 2018.x.
As such, please obtain these utilities from the downloads page (https://www.xilinx.com/support/download.html) and provide the .zip file to your floating license admin (please note that there are utilities specifically for Windows OS and also separately – for Linux). Then ask the admin to unzip this anywhere on the server. Then he needs to start the floating license server using the lmgrd from this location where he has just unzip these. It will then in turn will call the xilinxd vendor daemon (also found from the same location as lmgrd v11.14).  And that is it then, your Vivado 2018.1 will then be able to successfully detect and check out the necessary license and your issue will be resolved then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
devinl
Community Manager
Community Manager
Hi @muneet,
It sounds like the Vivado tools license is not being pulled on your machine or possible is not a compatible version for your tools. Can I have you run the below command and see if your see if your synthesis feature shows and has a version limit of 2018.04 or higher?
lmutil lmstat -a -c 1700@my_license_server
https://www.xilinx.com/support/answers/33770.html
Thank you,
Devin
anatoli
Hello @muneet,
Also, in addition to what @devinl has suggested, when you run lmutil lmstat -a -c 1700@my_license_server, see if lmgrd and xilinxd are both v11.14. Can you confirm on this please?
Kind Regards,
Anatoli Curran,
Versal Blogs
muneet
Hi @devinl @anatoli,
Thank you for quick reply. Ran the above mentioned commands on the license server. It is not showing any version limit. The version of the server tool is 11.13. I have attached screenshot of the window when command is run on the server.
nupurs
@muneet
Since Vivado 2017.3, it is compulsory to use Flexlm tools version 11.14 on the server.
Hence, you can download, install and use the License Management tools given at end of this page : https://www.xilinx.com/support/download.html
Nupur
anatoli
Hello @muneet,
Kind Regards,
Anatoli Curran,
Versal Blogs
muneet
Hi @anatoli,
Tried all the steps as mentioned in your latest reply. The license limit is 2019.06 for all the tools including synthesis tool and 2018.1 version is detecting them as well(checked in license manager after upgrading the flex tool to version 11.14). But still the mentioned device is throwing the same error.
anatoli
Hello @muneet,
Can you please now run this below command similar to mine and share a screenshot of the output you'd get:
E.g.
lmutil lmstat -a -c 2100@XIRANATOLI31 -f Synthesis
Kind Regards,
Anatoli Curran,
Versal Blogs
muneet
Hi @anatoli,
The screenshot of the window when the command ran on server.
anatoli
Thanks @muneet,
As you can see, your xilinxd is still v11.13, where as both lmgrd and xilinxd must be v11.14
Fixing this, will fix your licensing issue.
Kind Regards,
Anatoli Curran,
Versal Blogs
license
Hi @anatoli,
We followed your steps and LMTOOLs version changes to 11.14 but XILINXD is still 11.13. Could you please provide a guideline for upgrading the version of XILINXD tool?
anatoli
Hello @license,
Are you specifically pointing to the xilinxd v11.13 within your license file? If so, edit your lic file and update to point to v11.14 version of xilinxd.
If not, then have you obtained these utilities from the downloads page (https://www.xilinx.com/support/download.html)?
If so, if you unzip this.zip file and then start the floating license server using the lmgrd from this location where you've just unzip these, it will then in turn call the xilinxd vendor daemon (also found from the same location as lmgrd v11.14).
If further help is needed, please let me know.
Kind Regards,
Anatoli Curran,
Versal Blogs
anatoli
also, @license, if you are using lmtools, the location where you've specified where to look for lmgrd v11.14, is xiilnxd v11.14 also in the same location?
Kind Regards,
Anatoli Curran,
Versal Blogs
muneet
Hi @anatoli@nupurs@devinl,
Thank you for providing to the point guidelines for resolving the issue.
