Participant chaooxford
Licence not found for Vivado system edition license
We have a system edition license for Vivado, but it shows the following fail message when synthesised with 'xcku040'.
It works with Artix part, but not the 'xcku040' part we wanted. Could you please help me with this?
[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xcku040'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". If you are using a license server, verify that the license server is up and running a version of the xilinx daemon that is compatible with the version of Xilinx software that you are using. Please note that Vivado 2017.3 and later requires upgrading your license server tools to the Flex 11.14.1 tools. Please confirm with your license admin that the correct version of the license server tools are installed.
Community Manager
Community Manager
Re: Licence not found for Vivado system edition license
Hi @chaooxford,
Vivado 2018.1 requires a license version limit of 2018.04, your license has a version limit of 2018.02 therefore the license is not compatible. Either the license would need to be upgraded via your marketing rep or Vivado 2017.4 would need to be used instead.
Please see the license version limit chart below.
https://www.xilinx.com/support/answers/33770.html
Thank you,
Devin
Community Manager
Community Manager
Hi @chaooxford,
The Kintex US part you are selecting is not covered in the webpack and requires a tools license. You can see which parts are supported via the webpack tool on page 18 of the release notes https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug973-vivado-release-notes-install-license.pdf. Now your VLM does show you do have a tools license however this version limit of 2018.02 is not compatible with the tools version you are using. Please see the version limit chart https://www.xilinx.com/support/answers/33770.html. Your current license will work with Vivado versions 2017.4.1 and prior.
Thank you,
Devin
Hi devinl,
We have the the full license for Vivado design edition, not the webpack.
And I am using 2018.1, which should be OK.
I do not understand why this happened.
Best regards,
Chao
Community Manager
Community Manager
Hi @chaooxford,
Thank you,
Devin
