License Expired
I have installed ISE Project Navigator Release Version: 14.1 (nt), Application Version: P.15xf on Windows 10 machine.
When I open the ISE Project Navigator, I get the error message that "A license was not found for the ISE Feature". Typical causes for this error are either that there is no license files which were found, do not contain an unexpired license with the required feature.
The Xilinx License Configuration Manager (XLCM) will  be launced to assist you with locating or obtaining the license.
When I goto Help > Obtain a license key, doesn't work.
I am B.Tech Student, need to do a project on Xilinx FPGA. Please  help me in resolving this issue.
Kritika
Community Manager
Community Manager
Hi @toreachkritika,
You can go to the link below and click on the hyperlink Xilinx Product Licensing Site to acquire free and eval licenses.
https://www.xilinx.com/support/licensing_solution_center.html
Thank you,
Devin
Community Manager
Community Manager
Hi @toreachkritika,
Thank you,
Devin
