hillseg
License (Version Limit 2019.04) won't work with Vivado 2019.1
We using floating license server on windows 7-x64 machine (flexlm v11.14.1.0). Last verison that we use (Vivado 2018.3) work perfectly but when we trying to use newer version of Vivado something went wrong. So, my question is: version of Vivado is equal to Version Limit of license - 2019.04 = 2019.4? If it's equal how we need to configure our  license server to work with newer version?
graces
As mentioned, version limit 2019.04 enables software update till the end of April, 2019.
The minimum version limit required for Vivado 2019.1 release is 2019.05.
yangc
Hi @hillseg ,
2019.04 means 2019 April , is not equal to vivado version. If you want to use vivado 2019.1 , you should get a new license for vivado 2019.1 .
hillseg
Thank's!
graces
