smileyoung
License checkout unsuccessful.
Hello, everyone
I have got a zynq zcu104 board, the licensing for vivado is oaky. But when I launched the Vivado HLS, a licensing problems appeared.  Any one meet this problem?  the version for the vivado is 2018.2.license.png
smileyoung
hemangd
Hi @smileyoung,
Run command "report_environment -file <filepath>/env.txt" in tcl console and provide env.txt to evaluate.
Also provide the license file which you are using to run HLS.
hemangd
smileyoung
These two files are attached here. Because I don't know why I cannot upload .lic file, so I modify license file to Xilinx.txt
anatoli
Hello @smileyoung,
Were you able to overcome this licensing issue now or still seeing the same error in Vivado HLS? Can you confirm on this please? Thanks in advance.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
