Anonymous
Not applicable
Licensing/Download - Why am I getting an error message related to an "export compliance alert"?
Hi All,
Please help me on the Vivado 2014.4 obtain License.
When I login to Xilinx to get file license .xml.
The system note as picture below:
I try to edit my pesonal profile in my account as attached file but I can not fix this error.
Please help me on this.
Many thanks !
Re: Licensing/Download - Why am I getting an error message related to an "export compliance alert"?
Hi @Anonymous
I will send you a personal message. Please check.
Thanks,Vijay
Hi @Anonymous
Thanks,Vijay
Anonymous
Not applicable
Hi Vijay,
If convenien, please send the answer to my persional email: tienthanhkt09@gmail.com
Many thanks and regards,
Thanh
Check if these links might help you:
http://www.xilinx.com/support/answers/44043.html
http://www.xilinx.com/support/answers/63618.html
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
