Licensing Issue with Vivado 2016.2 Vivado System Generation
I have recently installed Vivado system edition 2016.2 recently in Sep-2017. It is node locked license.
Main use of this license is to generate FPGA models using Xilinx block set of Simulink (Matlab-2015-B), and dSPace (version 2016-B) XSG block sets. Everything was working fine after installation but for last couple of days I am not able to build FPGA. Even the models which were successfully build in past are giving error as follows:
“The framework selected in your FPGA-Setup Block could not be found. Please check your installation”. I have also attached screenshot of error message generate by Simulink(Matlab).
Can someone help me to resolve this issue or let me know what are typical reasons for this error?
Best Regards
Milan
Re: Licensing Issue with Vivado 2016.2 Vivado System Generation
@milan.rajne
Thanks for sharing the solution. I am sure it would help others in case they run into the same issue.
Please mark your post as solution for convenience of other users running into same issue.
Nupur
check the log file for details.
Please make sure you are using compatible version of tools.
https://www.xilinx.com/support/answers/55830.html
You may require to contact Dspace directly
Thanks and Regards
Balkrishan
Thanks Balkrishan !
It's kind of unusual but recent update of  Symantec endpoint protection software was blocking vrs.exe process which was trying to access runme.bat file.  After changing Symantec setting to enable runme.bat access, issue is solved.
Best Regards
Milan
@milan.rajne
Nupur
