ds_aud
Licensing issue ISE
Hi Guys,
Any ideas why I am getting the below error. I think I am using correct license but still getting this error. I am using SP605 board and I got license with it but when I generate the copy of the license from licensing manager and upload the .lic file. When I run the compilation process i get following error.
Command Line: platgen -p xc6slx45tfgg484-3 -lang vhdl -intstyle ise -lp
/home/ise/ShareVM/summit_hc_sp605/src/ -toplevel no -ti microblaze_i -msg
__xps/ise/xmsgprops.lst microblaze.mhs
ERROR:EDK - INFO:Security:71 - If a license for part 'xc6slx45t' is available,
   it will be possible to use 'XPS_TDP' instead of 'XPS'.
   INFO:Security:61 - The XILINXD_LICENSE_FILE environment variable is not set.
   INFO:Security:63 - The LM_LICENSE_FILE environment variable is not set.
   INFO:Security:68 - For more information or for assistance in obtaining
    a license, please run the Xilinx License Configuration Manager
          (xlcm or "Manage Xilinx Licenses".)
   INFO:Security:68a - user is ise, on host localhost.localdomain.
   WARNING:Security:9b - No 'XPS' feature version 2016.11 was available for part
   'xc6slx45t'.
   ERROR:Security:12 - No 'xc6slx45t' feature version 2016.11 was available
   (-5),
        so 'XPS_TDP' may not be used.
   No such feature exists.
   Feature:       XPS
   License path:
   /home/ise/.Xilinx/Xilinx(1).lic:/home/ise/.Xilinx/Xilinx(2).lic:/home/ise/.Xi
   linx/Xilinx.lic:/opt/Xilinx/14.7/ISE_DS/EDK/data/*.lic:/opt/Xilinx/14.7/ISE_D
   S/ISE//data/*.lic:/opt/Xilinx/14.7/ISE_DS/ISE//coregen/core_licenses/Xilinx.l
   ic:/opt/Xilinx/14.7/ISE_DS/ISE//coregen/core_licenses/XilinxFree.lic:/opt/Xil
   inx/14.7/ISE_DS/EDK/data/core_licenses/Xilinx.lic:
   FLEXnet Licensing error:-5,357
   For further information, refer to the FLEXnet Licensing documentation,
   available at "www.flexerasoftware.com".No such feature exists.
   Feature:       xc6slx45t
   License path:
ERROR:EDK:440 - platgen failed with errors!
gmake: *** [implementation/microblaze_microblaze_0_wrapper.ngc] Error 2
ERROR:EDK -
   Error while running "gmake -f microblaze.make netlist".
ERROR: synthesizing XPS module failed!
DS
anatoli
Hello @ds_aud,
Can you please generate an Xinfo report (in ISE) on that particular PC where you see the licensing failure and attach a copy of it for examination please, thanks? To generate Xinfo, Go to Start->All Programs->"Xilinx ISE Design Suite"->Accessories->XInfo System Checker.
Please also attach a copy of this device locked license that you have.
We will examine these files and will get in touch with you then.
Basically, you'd need a license that contains a feature such as "XPS". Do you have this licensing feature in your license file?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
ds_aud
Thanks for your reply.
I am currently on holidays and won’t be able to supply information requested as I can’t access PC.
What license I do get with XP605 board? I am under impression that XPS license will be included.
I will I’ll provide you information in new year.
Merry Christmas and Happy New year.
