Licensing
I'm trying to follow the Vivado Design Suite User Guide to install my license for Wilinx ISE 14.7 and end up loading the FreeWebPak licence that they email me from my Desktop but when I try to Generate Programing Files it doesn't get past the Synthesis and starts a "Traslation" then fails and says:
ERROR:ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'error deleting "C:/SVN/10_22_18_DynamicLoadSpeedExperiments/InductorsInc_NoRemote/ipcore_dir/clkgen.ncf": permission denied'.
Tcl_ErrnoId: unknown error
Tcl_ErrnoMsg: No error
_cmd: ::xilinx::Dpm::dpm_chTransformExecuteForXst dpm_xstRun $piThisInterface
errorInfo: error deleting "C:/SVN/10_22_18_DynamicLoadSpeedExperiments/InductorsInc_NoRemote/ipcore_dir/clkgen.ncf": permission denied
while executing
"file delete -force $ncffile"
invoked from within
"if { [sup::IsChildProjectFile $iHdlFile] } {
set ise_helper [sup::GetIseHelperFromComp $iHdlFile]
if { $ise_helper == 0 } { re..."
("uplevel" body line 2)
invoked from within
"uplevel $_body "
(procedure "sup::ForEachIterEle" line 9)
invoked from within
"sup::ForEachIterEle iHdlFile $iHdlFileIter {
set ise_helper [sup::GetIseHelperFromCo..."
(procedure "dpm_preToPostUcf" line 17)
invoked from within
"dpm_preToPostUcf $iTranInst"
(procedure "::xilinx::Dpm::dpm_chTransformExecuteForXst" line 115)
invoked from within
"::xilinx::Dpm::dpm_chTransformExecuteForXst dpm_xstRun $piThisInterface"
ERROR:NgdBuild:1317 - Using core chipscope_ila_v1 requires a ChipScopePro
license. The following blocks are instances of core chipscope_ila_v1:
ERROR:Security:12 - No 'xc6slx16' feature version 2013.10 was available (-5),
ERROR:NgdBuild:1316 - A problem was encountered attempting to get the
ChipScopePro license.
anatoli
Hello @electronics117,
Can you please confirm what Operating System have you installed your ISE 14.7 on?
Also, have you obtained an ISE WebPACK license or Vivado WebPACK one?
And lastly, can you please generate an Xinfo report (in ISE) on that particular PC where you see the licensing failure and attach a copy of it for examination please, thanks? To generate Xinfo, Go to Start->All Programs->"Xilinx ISE Design Suite"->Accessories->XInfo System Checker.
We will examine these files and will get in touch with you then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hope you are doing well.
Were you able to overcome this issue by now or are you still having problems and would like our help support? If so, please let us know and we would be able to help you further on this matter then.
Kind Regards,
Anatoli Curran,
Versal Blogs
