Visitor amohamed
Map:258 - A problem was encountered attempting to get the license for this architecture.
Hi All,
I know it's quit often problem but seems to have different solution for each case.
I am compiling a project with ISE 14.7 latest version on win7 and it targets Virtex6 (XC6VLX195T). the problem I am getting an error message as in [1].
I am using a server based certificate which I connect to it from any device.
I've attached also the xinfo.txt from my device
any help ?
Cheers
Ashraf
[1]
Section 1 - Errors
ERROR:Security:12 - No 'xc6vlx195t' feature version 2013.10 was available (-5),
ERROR:Map:258 - A problem was encountered attempting to get the license for this
   architecture.
Section 2 - Warnings
WARNING:Security:9b - No 'ISE' feature version 2013.10 was available for part
'xc6vlx195t'.
回复: Map:258 - A problem was encountered attempting to get the license for this architecture.
Hello @amohamed,
You have a valid Vivado license but not ISE one. ISE license comes free with every Vivado purchased license, however you'd need to obtain/generate this separately to your Vivado license file.
Please ask Manfred (manfred.zimmer ->the person who's generate your Vivado System Edition license) to log in to www.xilinx.com/getlicenses and in here he can then generate the required ISE System Edition license. This will solve your issue then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
I don't find anything out of order from xinfo.
What if you open ISE Command Prompt (Start > Xilinx Design Tools > ISE Design Suite 14.7 > Accessories > ISE Design Suite 64 bit Command Prompt) and run the following command?
lmutil lmdiag ISE -c 2101@feda2014.desy.de
Hello @amohamed,
Kind Regards,
Anatoli Curran,
Visitor amohamed
Hi, I did but no thing changed
the message printed out is
C:\Xilinx\14.7\ISE_DS>lmutil lmdiag ISE -c 2101@feda2014.desy.de
lmutil - Copyright (c) 1989-2012 Flexera Software LLC. All Rights Reserved.
FLEXnet diagnostics on Thu 7/12/2018 16:35
Cheers
Ashraf
Visitor amohamed
okay I will ask Manfred and I will confirm if it works or not
thanks a lot
Cheers
Ashraf
@amohamed  已写:
Cheers
Ashraf
I can see 'ISE' feature listed in xinfo.
ISE S/W 2018.12 Permanent Floating 25 manfred.zimmer,Vivado_System_Edition,software,permanent,_180383582_180500054_210672084_403 2101@feda2014.desy.de 00082 0
However it is not returned when you run lmdiag command. Are you able to find out Vivado features using the same command?
e.g.
lmutil lmdiag Synthesis -c 2101@feda2014.desy.de
Hello @amohamed,
Indeed, as correctly indicated by @graces, the ISE license is already there, so Manfred has this already generated.
I've missed somehow to find this in the first place when i've examined your Xinfo report.
Can you please send us the output of 'lmutil lmstat -c 2101@feda2014.desy.de -f ISE'
Thanks in advance.
Kind Regards,
Anatoli Curran,
Visitor amohamed
Hi @anatoli,
now it works indeed I've asked Manfred and I was not allowed to connect to the license before some internal process.
I think I can close the issue.
Cheers
Ashraf
