Anonymous
Not applicable
Migrate node-locked license to different machine
HI,
We purchased a Node locked license.
Now we want to change it to other machine.
Can you help us, how we can do this.
Thanking you,
P Dasarath
Re: Migrate node-locked license to different machine
Hi @Anonymous
Check this answer record.
http://www.xilinx.com/support/answers/36136.html
Thanks,Vijay
Is this Vivado license or ISE license?
If it's certificate based (i.e. ISE license) use AR mentioned by Vijay.
If its Vivado License (activation based) then youhave to return the license first and re-generate using different machine.
Refer UG: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug973-vivado-release-notes-install-license.pdf
Also refer AR: http://www.xilinx.com/support/answers/60525.html
http://www.xilinx.com/support/answers/60522.html
Yash
Hi @Anonymous
Did that helped you in rehosting the license? If yes, close the thread by marking the solution in the interest of other users.
Thanks,Vijay
