Moving ISE to D drive
Hi all,
i have ISE installed on my C drive but because it is huge and this drive is almost full, i'd like to move it completely to the D drive.
I can imagine two ways: uninstall from C / reinstall on D (i want to avoid this one) or moving the complete directory and then editing some config files, this is from far the preferred solution. What is the procedure to do so? I
Thank you.
Professor
Professor
Re: Moving ISE to D drive
Unless you are very comfortable with using the registry editor the only real option
is to uninstall and re-install.  Unfortunately this also means going back to the
original installation files and then applying the service packs, etc.  You might
want to think about moving something else to your D drive to buy some time until
you're ready to install the next revision of ISE...
Gabor
-- Gabor
Go ahead and copy the installation over to the D drive and then just run "remotexsetup.bat".  That batch file will setup your registry, desktop icons, environment variables, start menu, etc.  You can find the batch file in your <install location>\common\bin\nt or nt64 folder depending on if this is 32-bit or 64-bit.
Professor
Professor
That's really good to know.  Is this documented somewhere?
-- Gabor
It is documented under Network Installations: Microsoft Windows Clients on page 40 of the Release Notes (http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/irn.pdf).  Obviously it applies to non-network installations as well.  Basically remotexsetup.bat allows you to move your installation around and then set up the environment and registry for the new location.
Historian
Historian
Wow, I had no idea that this existed. Is it relevant for 10.x too? I have both 10.1.3 and 11.5 installed on my machine, and I really need to get them off of the C:\ drive.
This did exist in 10.1 as well.  The information can be found on page 42 of the 10.1 installation guide (http://www.xilinx.com/itp/xilinx10/books/docs/irn/irn.pdf).  The script is called setXenv.bat in that version and it is in the <install_location>\bin\nt folder.
Historian
Historian
Much thanks -- I was able to move both my 10.1 and 11.5 installs to a different drive and everything still works!
I encounter the same problem, and I want to move ISE to other drive beside C. I am currently using the lastest version ISE14.7. Under the director you provided, I only find these two bath files, i.e. shortcutSetup.bat and install_drivers_wrapper.bat. I did not find the remotexsetup.bat file, could you please tell me which one should I choose? And do I run this bat file after I move the complete Xilinx file to say D drive?
