m-sathiyapriya
Need help: Installation of ISE 10.1.03 shows error while extract.
I tried to install ISE 10.1.03 but the installer  ISE-64 bit windows 10.1.03 (SP3) is giving me an error when I am trying to Self extract (10_1_03_win64) exe file by double clicking in it.
A download error has occurred:
Read Operation failed.
Do you want to retry the download, or cancel?"
when I am trying to extract (10_1_03_win64) exe file by using 7zip, a below errors on shown.
1.Unavailable start of archive.
Warnings:
There are some data after the end of payload  data.
2.Unavailable data:bin
3. Unavailable data:bin\nt64
4. Unavailable data:bin\nt64\xilinxupdate.exe
5.4. Unavailable data:bin\nt64\_xilinxupdate.exe
Looking for any help to resolve the installation problem.
ansarimo
Hi @m-sathiyapriya
Are you trying to install ISE 10.1 on a Windows10 machine? Please refer to ISE 10.1 user guide below for supported OS:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx10/books/docs/irn/irn.pdf
Only ISE 14.7 VM version is supported on Win10 machine. Also, elaborate on the issue as the information shared above is quite confusing.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
ansarimo
Hi @m-sathiyapriya
Thanks and Regards,
Ansari Hunen
