makestuff
New "manage licence" site?
All the documentation (e.g this, from June 2020 and forum posts I've seen about managing licences suggests using https://www.xilinx.com/getlicense, but that site now returns a 404 error. I've tried from several different computers, and several different browsers. Is there a replacement licensing site?
Chris
florentw
Hi @makestuff
The link is the one I am using as well usually. I think it is not meant to be broken.
We are trying to report this to the web team. In the meantime I have a small trick which is working.
Go into the following page (Test Pattern Generator IP) and click Get License:
https://www.xilinx.com/products/intellectual-property/tpg.html
No worries this is a free license (which is not even required in the latest tools) so you will not be charged anything. But at least this will direct you to the licensing site
Florent
florentw
Hi @makestuff
Florent
barriet
Chris,
There's an apparent problem with the website today - other redirects that usually work (https://www.xilinx.com/power) are also broken at the moment.
I've already reported it to the web team.
Cheers,
bt
anatoli
Thanks for reporting this issue.
I've contacted the Xilinx web development team to get this addressed as soon as possible.
I will update here once this is addressed.
Apologies for any inconvenience caused.
Kind Regards,
Anatoli Curran,
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
makestuff
Great, thanks. I was able to generate the license I needed!
anatoli
Hello All,
This issue has been resolved now.
Apologies for any inconvenience caused and thanks once again for raising this issue with us.
Have a nice day.
Kind Regards,
Anatoli Curran,
Versal Blogs
