No 'ISE' nor 'WebPack' feature version 2013.10 was available for part 'xc7z020'.
 I have installed the ISE Web pack for using with my Zedboard. I have ISE WebPACK License and also the Vivado Design Suite: HL WebPACK 2015 and Earlier License. Both the licneses are present in my working directory as well as C:\Xilinx\14.7\ISE_DS\ISE\coregen\core_licenses.
I have attached the xinfo.txt file
I am getting the following error:
Please help.
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
INFO:Security:51 - The XILINXD_LICENSE_FILE environment variable is not set.
INFO:Security:53 - The LM_LICENSE_FILE environment variable is not set.
INFO:Security:54 - 'xc7z020' is a WebPack part.
INFO:Security:68a - user is ssingh, on host PAN101.
WARNING:Security:43 - No license file was found in the standard Xilinx license
directory.
WARNING:Security:44 - Since no license file was found,
please run the Xilinx License Configuration Manager
(xlcm or "Manage Xilinx Licenses")
to assist in obtaining a license.
ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2013.10 was available
for part 'xc7z020'.
No such feature exists.
Feature: WebPack
License path:
\\/.Xilinx;c:\Xilinx\14.7\ISE_DS\ISE\/coregen/core_licenses\Xilinx.lic;
FLEXnet Licensing error:-5,357
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".No such feature exists.
Feature: ISE
License path:
ERROR:Map:258 - A problem was encountered attempting to get the license for this
architecture.
Design Summary
Number of errors : 1
Number of warnings : 0
ERROR: During map!
The process finished with an exit value of 2!
Process finished.
Hi @soumya.91singh
It seems the license location is not taken properly as seen in the error message.
Can you please add the location of license file to XILINXD_LICENSE_FILE environment variable and click on Set.
Then you can restart Xilinx tools and see if the license has taken effect.
Nupur
@soumya.91singh
From Xinfo license looks ok. Have you correctly set the XILINXD_LICENSE_FILE environment variable in the XLCM?
Share the similar screenshot.
Rohit
Rohit
Hi Rohit,
The license is already in the .Xilinx file. Please find the screenshot attached.
-Soumya
Hi @soumya.91singh
Nupur
Hi Nupur,
I downloaded the license once again to lead everything from the start and set the variables. It still returns the same error.
Soumya
Hi Nupur and Rohit,
Its working now. My workspace folder corrupted due to an older version of Xilinx. FPGA implementation now works for my Zedboard.
Thanks a lot.
-Soumya
this occurs when I run the "implement design"
I am getting same error message on implementing the design.
Map is not happening
Hello @PARTH ,
Based on your license file, you don't have a valid ISE license file.
Please obtain a free ISE Embedded Edition license and you can then overcome this licensing issue.
FYI - now a days, all of our customers can obtain an ISE Embedded Edition license free of charge. All they need to do is to log in into www.xilinx.com/getlicenses and they should see this FULL ISE Embedded Edition license in the entitlement list.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Thanks Anatoli !
Now, do I need to re-install the ISE14.7 Design Suite or just downloading the license file suggested by you will do?
It got mapped...!!
