venkateshv
No 'xc6vsx315t. feature version 2012.04 was available so'webpack' not found
Dear All, I am new for Xilinx FPGA product group. I am using Xilinx 14.1 ISE tool. We are working on Virtex-6 FPGA. When i try to build Top module i am getting some error as below. ERROR:Security:12 - No 'xc6vsx315t' feature version 2012.04 was available (-5), so 'WebPack' may not be used. ---------------------------------------------------------------------- License file does not support this version. Feature: ISE Application version > License version: 2012.04 > 2012.01 License path: C:/.Xilinx\Xilinx.lic;C:/.Xilinx\xilinx_ise.lic;C:\Xilinx\14.1\ISE_DS\ISE\/data\ *.lic;C:\Xilinx\14.1\ISE_DS\ISE\/coregen/core_licenses\Xilinx.lic;C:\Xilinx\14.1 \ISE_DS\ISE\/coregen/core_licenses\XilinxFree.lic;C:\Xilinx\14.1\ISE_DS\EDK/data /core_licenses\Xilinx.lic; FLEXnet Licensing error:-21,126. System Error: 2 "" For further information, refer to the FLEXnet Licensing documentation, available at "www.acresso.com".No such feature exists. Feature: xc6vsx315t License path: C:/.Xilinx\Xilinx.lic;C:/.Xilinx\xilinx_ise.lic;C:\Xilinx\14.1\ISE_DS\ISE\/data\ *.lic;C:\Xilinx\14.1\ISE_DS\ISE\/coregen/core_licenses\Xilinx.lic;C:\Xilinx\14.1 \ISE_DS\ISE\/coregen/core_licenses\XilinxFree.lic;C:\Xilinx\14.1\ISE_DS\EDK/data /core_licenses\Xilinx.lic; FLEXnet Licensing error:-5,357 For further information, refer to the FLEXnet Licensing documentation, available at "www.acresso.com". ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture. Kindly let us know how to resolve this.
ashishd
Hello @venkateshv,
If you check page #15 from below UG, you will find this device xc6vsx315t is not supported with ISE WebPack
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/irn.pdf
If you are not using WebPack and having valid license for this device, then you need to check version limit present in license file. Please check below AR to know details about version limit
http://www.xilinx.com/support/answers/33770.html
You can attach your license file here for further investigation.
Ashish
