01-29-2019 11:54 PM
Is it possible to host a floating license for the Xilinx 10GbE core, on a Windows based server, using the Lmgrd server, without a floating Vivado license? We have multiple node-locked Vivado licenses but not a floating Vivado lic. We purchased a floating 10GbE core license so that more than one developer can access the license when building with that core.
We followed the procedure in AR# 5332, but the Xilinx vendor daemon (XilinxD) will not start - producing following error:
Status
Flexible License Manager status on Wed 1/23/2019 17:31
[Detecting lmgrd processes...]
Error getting status: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: xx.xx.xx.xx
License path: ####@server;
FlexNet Licensing error:-15,10. System Error: 10061 "WinSock: Connection refused"
Is what we are trying to do not even possible? In other words, will the vendor daemon only start up with a Vivado license, or is it possible to run with only the 10GbE core license?
Thank you for any help.
02-04-2019 01:17 AM
Hello eskull@0,
"ten_gig_eth_pcs_pma_basekr" is what you are missing. Do you actually need BASE-KR option enabled in your design? If not, please disable it and you will be good to go then.
However, if you have this BASE-KR option enabled/selected (as shown below) for this IP Core, then just having "ten_gig_eth_pcs_pma" licensing feature isn't enough here, as this option requires an additional "ten_gig_eth_pcs_pma_basekr" feature and you don't have this right now. I don't think you can even obtain an evaluation license with "ten_gig_eth_pcs_pma_basekr" in it;therefore for the evaluation purposes of this IP Core, please note that you'd need to use/select BASE-R instead of BASE-KR (as shown below). Otherwise, you'd need a purchased license for this BASE-KR IP feature.
01-30-2019 12:31 AM
Yes it is possible to have IP floating license but node-locked Vivado license.
Did you start the lmgrd process for serving the license?
Can you share the following files so that I can debug the issue further:
1. Xilinx license files from server
2. lmgrd log from server
3. Run this command in Vivado tcl console at client end and share the env.txt file produced : report_environment -file env.txt
01-30-2019 12:43 PM - edited 01-30-2019 12:59 PM
License file:
# ----- REMOVE LINES ABOVE HERE --------------------------
SERVER mint1 2C56DC725238 2100
USE_SERVER
VENDOR xilinxd
# This is a permanent license generated on Mon Jan 21 04:01:44 UTC 2019
INCREMENT ten_gig_eth_mac xilinxd 2019.12 permanent 9999 8C95036DC8CC \
VENDOR_STRING=License_Type:Bought;jquinsaat,ten_gig_eth_mac,ip,permanent,_210674821_1777531991_210696076_663 \
ISSUER="Xilinx Inc" NOTICE="The license for this core was \
generated for jquinsaat on 01/22/2019It is the responsibility \
of the Licensee of this core to adhere to all terms and \
conditions of the applicable license agreement when using this \
core." START=21-Jan-2019 TS_OK
# Licenses for ten_gig_eth_mac_v3_0
FEATURE ten_gig_eth_mac_v3_0 xilinxd 1.0 permanent 9999 D61E48C3EC8A \
VENDOR_STRING=License_Type:Bought ISSUER=Xilinx NOTICE="The \
license for this core was generated for jquinsaat on \
01/22/2019It is the responsibility of the Licensee of this \
core to adhere to all terms and conditions of the applicable \
license agreement when using this core." TS_OK
# Licenses for ten_gig_eth_mac_v6
FEATURE ten_gig_eth_mac_v6 xilinxd 1.0 permanent 9999 817D5AB29AC1 \
# Licenses for ten_gig_eth_mac_v7
FEATURE ten_gig_eth_mac_v7 xilinxd 1.0 permanent 9999 41EE1C8FAE57 \
# Licenses for ten_gig_eth_mac_v9
FEATURE ten_gig_eth_mac_v9 xilinxd 1.0 permanent 9999 67524CD126B3 \
# Licenses for ten_gig_eth_mac_v8
FEATURE ten_gig_eth_mac_v8 xilinxd 1.0 permanent 9999 8A4682CCD2F5 \
# Licenses for ten_gig_eth_mac_v4_0
FEATURE ten_gig_eth_mac_v4_0 xilinxd 1.0 permanent 9999 AE165238F418 \
# Licenses for ten_gig_eth_mac_v5_0
FEATURE ten_gig_eth_mac_v5_0 xilinxd 1.0 permanent 9999 670C08DDA896 \
INCREMENT xxv_eth_mac_pcs xilinxd 2019.12 permanent 9999 FFEB55B7939B \
VENDOR_STRING=License_Type:Bought;jquinsaat,xxv_eth_mac_pcs,ip,permanent,_210674821_1777531991_210696076_905 \
INCREMENT xxv_mac_pcs xilinxd 2019.12 permanent 9999 3B0DD289D8FD \
VENDOR_STRING=License_Type:Bought;jquinsaat,xxv_mac_pcs,ip,permanent,_210674821_1777531991_210696076_761 \
INCREMENT x_eth_mac xilinxd 2019.12 permanent 9999 B0479D838E65 \
VENDOR_STRING=License_Type:Bought;jquinsaat,x_eth_mac,ip,permanent,_210674821_1777531991_210696076_641 \
# ----- REMOVE LINES BELOW HERE --------------------------
LMGRD Server Log:
17:31:46 (lmgrd) -----------------------------------------------
17:31:46 (lmgrd) Please Note:
17:31:46 (lmgrd)
17:31:46 (lmgrd) This log is intended for debug purposes only.
17:31:46 (lmgrd) In order to capture accurate license
17:31:46 (lmgrd) usage data into an organized repository,
17:31:46 (lmgrd) please enable report logging. Use Flexera Software LLC's
17:31:46 (lmgrd) software license administration solution,
17:31:46 (lmgrd) FlexNet Manager, to readily gain visibility
17:31:46 (lmgrd) into license usage data and to create
17:31:46 (lmgrd) insightful reports on critical information like
17:31:46 (lmgrd) license availability and usage. FlexNet Manager
17:31:46 (lmgrd) can be fully automated to run these reports on
17:31:46 (lmgrd) schedule and can be used to track license
17:31:46 (lmgrd) servers and usage across a heterogeneous
17:31:46 (lmgrd) network of servers including Windows NT, Linux
17:31:46 (lmgrd) and UNIX.
17:31:46 (lmgrd)
17:31:46 (lmgrd)
17:31:46 (lmgrd)
17:31:46 (lmgrd) Server's System Date and Time: Wed Jan 23 2019 17:31:46 Pacific Standard Time
17:31:46 (lmgrd) pid 61976
17:31:46 (lmgrd) SLOG: Summary LOG statistics is enabled.
17:31:46 (lmgrd) Done rereading
17:31:46 (lmgrd) FlexNet Licensing (v11.14.1.3 build 212549 x64_n6) started on mint1 (IBM PC) (1/23/2019)
17:31:46 (lmgrd) Copyright (c) 1988-2017 Flexera Software LLC. All Rights Reserved.
17:31:46 (lmgrd) World Wide Web: http://www.flexerasoftware.com
17:31:46 (lmgrd) License file(s): C:\MentorGraphics\License_Files\Xilinx.lic
17:31:46 (lmgrd) lmgrd tcp-port 2100
17:31:46 (lmgrd) (@lmgrd-SLOG@) ===============================================
17:31:46 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
17:31:46 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Jan 23 2019 17:31:46 Pacific Standard Time
17:31:46 (lmgrd) (@lmgrd-SLOG@) PID: 61976
17:31:46 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.14.1.3 build 212549 x64_n6 ( build 212549 (ipv6))
17:31:46 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
17:31:46 (lmgrd) (@lmgrd-SLOG@) Listening port: 2100
17:31:46 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
17:31:46 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
17:31:46 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
17:31:46 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\MentorGraphics\License_Files\Xilinx.lic -l C:\MentorGraphics\Licensing\MGserverLog.txt -z -s
17:31:46 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\MentorGraphics\License_Files\Xilinx.lic
17:31:46 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
17:31:46 (lmgrd) Starting vendor daemons ...
17:31:46 (lmgrd) Starting vendor daemon at port 2200
17:31:46 (lmgrd) Using vendor daemon port 2200 specified in license file
17:31:46 (lmgrd) Started xilinxd (pid 61840)
17:31:46 (xilinxd) Unable to initialize access to trusted storage: 1
17:31:46 (xilinxd) FlexNet Licensing version v11.14.1.0 build 194335 x64_n6
17:31:46 (xilinxd) SLOG: Summary LOG statistics is enabled.
17:31:46 (xilinxd) SLOG: FNPLS-INTERNAL-CKPT1
17:31:46 (xilinxd) SLOG: VM Status: 0
17:31:46 (xilinxd) Server started on mint1 for: ten_gig_eth_mac
17:31:46 (xilinxd) ten_gig_eth_mac_v3_0 ten_gig_eth_mac_v6 ten_gig_eth_mac_v7
17:31:46 (xilinxd) ten_gig_eth_mac_v9 ten_gig_eth_mac_v8 ten_gig_eth_mac_v4_0
17:31:46 (xilinxd) ten_gig_eth_mac_v5_0 xxv_eth_mac_pcs xxv_mac_pcs
17:31:46 (xilinxd) x_eth_mac
17:31:46 (xilinxd) EXTERNAL FILTERS are OFF
17:31:46 (lmgrd) xilinxd using TCP-port 2200
17:31:46 (xilinxd) SLOG: Statistics Log Frequency is 240 minute(s).
17:31:46 (xilinxd) SLOG: TS update poll interval is 600 seconds.
17:31:46 (xilinxd) SLOG: Activation borrow reclaim percentage is 0.
17:31:46 (xilinxd) (@xilinxd-SLOG@) ===============================================
17:31:46 (xilinxd) (@xilinxd-SLOG@) === Vendor Daemon ===
17:31:46 (xilinxd) (@xilinxd-SLOG@) Vendor daemon: xilinxd
17:31:46 (xilinxd) (@xilinxd-SLOG@) Start-Date: Wed Jan 23 2019 17:31:46 Pacific Standard Time
17:31:46 (xilinxd) (@xilinxd-SLOG@) PID: 61840
17:31:46 (xilinxd) (@xilinxd-SLOG@) VD Version: v11.14.1.0 build 194335 x64_n6 ( build 194335 (ipv6))
17:31:46 (xilinxd) (@xilinxd-SLOG@) === Startup/Restart Info ===
17:31:46 (xilinxd) (@xilinxd-SLOG@) Options file used: None
17:31:46 (xilinxd) (@xilinxd-SLOG@) Is vendor daemon a CVD: No
17:31:46 (xilinxd) (@xilinxd-SLOG@) Is TS accessed: No
17:31:46 (xilinxd) (@xilinxd-SLOG@) TS accessed for feature load: -NA-
17:31:46 (xilinxd) (@xilinxd-SLOG@) Number of VD restarts since LS startup: 0
17:31:46 (xilinxd) (@xilinxd-SLOG@) === Network Info ===
17:31:46 (xilinxd) (@xilinxd-SLOG@) Listening port: 2200
17:31:46 (xilinxd) (@xilinxd-SLOG@) Daemon select timeout (in seconds): 1
17:31:46 (xilinxd) (@xilinxd-SLOG@) === Host Info ===
17:31:46 (xilinxd) (@xilinxd-SLOG@) Host used in license file: mint1
17:31:46 (xilinxd) (@xilinxd-SLOG@) Running on Hypervisor: Not determined - treat as Physical
Output from report_environment:
Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
| Tool Version : Vivado v.2018.2 (win64) Build 2258646 Thu Jun 14 20:03:12 MDT 2018
| Date : Wed Jan 30 11:42:40 2019
| Host : 2JCCSQ2 running 64-bit major release (build 9200)
| Command : report_environment -file env.txt
Environment Report
Table of Contents
1. System Information
2. Environment Variables
3. Vivado Preferences
4. Install Information
5. Version of system dlls called by Xilinx software
6. License Information
Host Information
| Hostname | 2JCCSQ2 |
| Network Interface Card ID | e4b97a0b130c,e4b97a92877d,38baf84bd7c3,38baf84bd7c4 |
| C: Drive Serial Number | DISK_SERIAL_NUM=c98749b |
| FLEXID Dongle ID | |
| Platform | Microsoft Windows 8 or later , 64-bit |
| Operating System | major release (build 9200) |
| Processor Vendor | Intel |
| Processor Detail | Intel(R) Core(TM) i7-6920HQ CPU @ 2.90GHz |
| Processor Speed | 2904 MHz |
| Processor Count | 1 |
| Physical Core Count | 4 |
| Logical Core Count | 8 |
Available Disk Space
| Volume | Drive Type | Free | Total |
| C:\ | HD - NTFS | 599 GB | 952 GB |
| D:\ | CD/DVD - CDFS | 0 B | 1 GB |
| H:\ | network - NTFS | 25 GB | 100 GB |
Host Memory Information
| Memory Type | Value |
| Physical Memory | 63 GB |
| Available Physical Memory | 27 GB |
| Swap File | 73 GB |
| Total Virtual | 127 TB |
| Available Virtual | 127 TB |
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\eskul\AppData\Roaming
CHARPOP=1
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=2JCCSQ2
ComSpec=C:\WINDOWS\system32\cmd.exe
DEFLOGDIR=C:\ProgramData\McAfee\Endpoint Security\Logs
HDI_APPROOT=C:/Xilinx/Vivado/2018.2
HOMEDRIVE=C:
HOMEPATH=\Users\eskul
INT_VARIABLE_NAME=XILINX_PATH
ISL_IOSTREAMS_RSA=C:/Xilinx/Vivado/2018.2/tps/isl
LM_LICENSE_FILE=Xilinx.lic
LOCALAPPDATA=C:\Users\eskul\AppData\Local
LOGONSERVER=\\AUTHP-AD-CORP07
NUMBER_OF_PROCESSORS=8
OneDrive=C:\Users\eskul\OneDrive
OS=Windows_NT
Path=C:/Xilinx/Vivado/2018.2/bin;C:/Xilinx/Vivado/2018.2/lib/win64.o;C:/Xilinx/Vivado/2018.2/tps/win64/jre/bin/server;C:/Xilinx/Vivado/2018.2/tps/win64/jre/bin;C:/Xilinx/SDK/2018.2/bin;C:/Xilinx/Vivado/2018.2/ids_lite/ISE/bin/nt64;C:/Xilinx/Vivado/2018.2/ids_lite/ISE/lib/nt64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Python36-32\Scripts\;C:\Program Files (x86)\Python36-32\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\HID Global\ActivClient\;C:\Program Files\HID Global\ActivClient\;C:\Program Files\TortoiseSVN\bin;C:\Program Files\PuTTY\;C:\Users\eskul\AppData\Local\Microsoft\WindowsApps;;C:\intelFPGA_lite\16.1\modelsim_ase\win32aloem;C:/Xilinx/Vivado/2018.2\tps\mingw\6.2.0\win64.o\nt\bin;C:/Xilinx/Vivado/2018.2\tps\mingw\6.2.0\win64.o\nt\libexec\gcc\x86_64-w64-mingw32\6.2.0
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY;.PYW
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=5e03
PRODVERSION_EXE=C:/Xilinx/Vivado/2018.2/bin/unwrapped/win64.o/prodversion.exe
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files (x86)\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files\Boldon James\Power Classifier for Files\;C:\Program Files\Arellia\Powershell\
PUBLIC=C:\Users\Public
QSYS_ROOTDIR=C:\intelFPGA_lite\16.1\quartus\sopc_builder\bin
QT_DEVICE_PIXEL_RATIO=auto
QUARTUS_ROOTDIR=C:\intelFPGA_lite\16.1\quartus
RDI_APPROOT=C:/Xilinx/Vivado/2018.2
RDI_ARGS= -gui_launcher_event rodinguilauncherevent27924
RDI_ARGS_FUNCTION=RDI_EXEC_DEFAULT
RDI_BASEROOT=C:/Xilinx/Vivado
RDI_BINDIR=C:/Xilinx/Vivado/2018.2/bin
RDI_BINROOT=C:/Xilinx/Vivado/2018.2/bin
RDI_BUILD=yes
RDI_CHECK_PROG=True
RDI_DATADIR=C:/Xilinx/Vivado/2018.2/data
RDI_INSTALLROOT=C:/Xilinx
RDI_INSTALLVER=2018.2
RDI_INSTALLVERSION=2018.2
RDI_ISE_PLATFORM=nt64
RDI_JAVAROOT=C:/Xilinx/Vivado/2018.2/tps/win64/jre
RDI_LIBDIR=C:/Xilinx/Vivado/2018.2/lib/win64.o
RDI_MINGW_LIB=C:/Xilinx/Vivado/2018.2\tps\mingw\6.2.0\win64.o\nt\bin;C:/Xilinx/Vivado/2018.2\tps\mingw\6.2.0\win64.o\nt\libexec\gcc\x86_64-w64-mingw32\6.2.0
RDI_OPT_EXT=.o
RDI_OS_ARCH=64
RDI_PLATFORM=win64
RDI_PREPEND_PATH=C:/Xilinx/SDK/2018.2/bin;C:/Xilinx/Vivado/2018.2/ids_lite/ISE/bin/nt64;C:/Xilinx/Vivado/2018.2/ids_lite/ISE/lib/nt64
RDI_PROG=C:/Xilinx/Vivado/2018.2/bin/unwrapped/win64.o/vivado.exe
RDI_PROGNAME=vivado.exe
RDI_TPS_ROOT=C:/Xilinx/Vivado/2018.2/tps/win64
RDI_VERBOSE=False
RT_LIBPATH=C:/Xilinx/Vivado/2018.2/scripts/rt/data
RT_TCL_PATH=C:/Xilinx/Vivado/2018.2/scripts/rt/base_tcl/tcl
SESSIONNAME=Console
SOPC_KIT_NIOS2=C:\intelFPGA_lite\16.1\nios2eds
SYNTH_COMMON=C:/Xilinx/Vivado/2018.2/scripts/rt/data
SystemDrive=C:
SystemRoot=C:\WINDOWS
TCL_LIBRARY=C:/Xilinx/Vivado/2018.2/tps/tcl/tcl8.5
TEMP=C:\Users\SKULLE~1\AppData\Local\Temp\1
TMP=C:\Users\SKULLE~1\AppData\Local\Temp\1
UATDATA=C:\WINDOWS\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77
USERDNSDOMAIN=CORP.LEIDOS.COM
USERDOMAIN=LEIDOS-CORP
USERDOMAIN_ROAMINGPROFILE=LEIDOS-CORP
USERNAME=eskul
USERPROFILE=C:\Users\eskul
valid=True
windir=C:\WINDOWS
XILINX=C:/Xilinx/Vivado/2018.2/ids_lite/ISE
XILINXD_LICENSE_FILE=2100@mint1
XILINX_DSP=C:/Xilinx/Vivado/2018.2/ids_lite/ISE
XILINX_PLANAHEAD=C:/Xilinx/Vivado/2018.2
XILINX_SDK=C:/Xilinx/SDK/2018.2
XILINX_VIVADO=C:/Xilinx/Vivado/2018.2
XILINX_VIVADO_HLS=C:/Xilinx/Vivado/2018.2
XIL_CHECK_TCL_DEBUG=False
XVREDIST=C:/Xilinx/Vivado/2018.2\tps\win64\xvcredist.exe
_dir=C:/Xilinx/Vivado/2018.2/ids_lite/ISE
_plat=nt64
_RDI_BINROOT=C:\Xilinx\Vivado\2018.2\bin
_RDI_CWD=C:\Users\eskul\AppData\Roaming\Xilinx\Vivado
_valid=False
HOME=C:\Users\eskul
HRT_TCL_PATH=C:/Xilinx/Vivado/2018.2/scripts/rt/fpga_tcl
RT_INTERUPT=C:/Users/eskul/.oasys/realTime-interrupt.tcl
No install information found.
File Name: ADVAPI32.dll
Dll Version: 6.02.16299.696
File Size: 649376
Create Time: Mon Oct 15 20:34:37 2018
Access Time: Wed Jan 30 03:00:02 2019
Modified Time: Thu Aug 30 18:10:46 2018
File Path: C:\WINDOWS\System32\ADVAPI32.dll
File Name: COMCTL32.dll
Dll Version: 5.82.16299.904
File Size: 661816
Create Time: Mon Jan 14 20:45:28 2019
Access Time: Wed Jan 30 11:41:14 2019
Modified Time: Mon Dec 31 22:40:50 2018
File Path: C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.16299.904_none_88763f384abe0299\COMCTL32.dll
File Name: comdlg32.dll
Dll Version: 6.02.16299.402
File Size: 1057792
Create Time: Fri Jul 20 12:19:18 2018
Access Time: Tue Jan 29 16:27:44 2019
Modified Time: Sun Apr 15 13:04:28 2018
File Path: C:\WINDOWS\System32\COMDLG32.dll
File Name: CRYPT32.dll
File Size: 1873944
Create Time: Fri Jul 20 12:18:55 2018
Modified Time: Sun Apr 15 14:29:17 2018
File Path: C:\WINDOWS\System32\CRYPT32.dll
File Name: dbghelp.dll
Dll Version: 6.02.16299.15
File Size: 1725440
Create Time: Fri Sep 29 06:41:44 2017
Access Time: Wed Jan 30 11:41:58 2019
Modified Time: Fri Sep 29 06:41:44 2017
File Path: C:\WINDOWS\system32\dbghelp.dll
File Name: DCIMAN32.dll
File Size: 14336
Create Time: Fri Sep 29 06:41:45 2017
Access Time: Tue Jan 29 16:32:06 2019
Modified Time: Fri Sep 29 06:41:45 2017
File Path: C:\WINDOWS\system32\DCIMAN32.dll
File Name: DDRAW.dll
File Size: 572928
File Path: C:\WINDOWS\system32\DDRAW.dll
File Name: GDI32.dll
Dll Version: 6.02.16299.665
File Size: 155440
Create Time: Mon Sep 24 20:06:29 2018
Modified Time: Mon Aug 27 22:43:20 2018
File Path: C:\WINDOWS\System32\GDI32.dll
File Name: GLU32.dll
File Size: 162304
Create Time: Fri Sep 29 06:41:56 2017
Access Time: Wed Jan 30 11:41:32 2019
Modified Time: Fri Sep 29 06:41:56 2017
File Path: C:\WINDOWS\SYSTEM32\GLU32.dll
File Name: IMM32.DLL
File Size: 173640
Access Time: Tue Jan 29 16:24:57 2019
File Path: C:\WINDOWS\System32\IMM32.DLL
File Name: KERNEL32.dll
Dll Version: 6.02.16299.431
File Size: 702568
Create Time: Fri Jul 20 12:17:43 2018
Modified Time: Thu May 3 00:43:30 2018
File Path: C:\WINDOWS\System32\KERNEL32.DLL
File Name: LZ32.dll
Dll Version: 5.00.01.01
File Size: 3072
Access Time: Wed Jan 30 03:00:01 2019
File Path: C:\WINDOWS\system32\LZ32.dll
File Name: MFC42.DLL
Dll Version: 6.06.8063.00
File Size: 1420800
Create Time: Fri Sep 29 06:42:04 2017
Access Time: Tue Jan 29 16:47:24 2019
Modified Time: Fri Sep 29 06:42:04 2017
File Path: C:\WINDOWS\system32\MFC42.DLL
File Name: MPR.dll
File Size: 98752
Access Time: Wed Jan 30 11:41:36 2019
File Path: C:\WINDOWS\system32\MPR.dll
File Name: MSASN1.dll
File Size: 65176
Create Time: Fri Sep 29 06:41:43 2017
Modified Time: Fri Sep 29 06:41:43 2017
File Path: C:\WINDOWS\System32\MSASN1.dll
File Name: MSVCIRT.dll
Dll Version: 7.00.16299.15
File Size: 82432
Create Time: Fri Sep 29 06:42:03 2017
Access Time: Tue Jan 29 16:45:06 2019
Modified Time: Fri Sep 29 06:42:03 2017
File Path: C:\WINDOWS\system32\MSVCIRT.dll
File Name: MSVCP80.DLL
Dll Version: Specified dll was not found.
File Size: Specified dll was not found.
Create Time: Specified dll was not found.
Access Time: Specified dll was not found.
Modified Time: Specified dll was not found.
File Path: Specified dll was not found.
File Name: MSVCR71.dll
File Name: MSVCR80.DLL
File Name: MSVCRT.dll
Dll Version: 7.00.16299.125
File Size: 630752
Create Time: Wed Dec 13 17:40:06 2017
Modified Time: Wed Dec 13 17:40:06 2017
File Path: C:\WINDOWS\System32\msvcrt.dll
File Name: NETAPI32.dll
File Size: 80184
Create Time: Fri Sep 29 06:41:33 2017
Modified Time: Fri Sep 29 06:41:33 2017
File Path: C:\WINDOWS\SYSTEM32\NETAPI32.dll
File Name: NETRAP.dll
File Name: ntdll.dll
Dll Version: 6.02.16299.785
File Size: 1953960
Create Time: Mon Nov 19 21:21:48 2018
Access Time: Wed Jan 30 11:11:55 2019
Modified Time: Mon Oct 29 22:58:01 2018
File Path: C:\WINDOWS\SYSTEM32\ntdll.dll
File Name: ole32.dll
File Size: 1337272
Create Time: Mon Nov 19 21:21:54 2018
Modified Time: Mon Oct 29 22:52:00 2018
File Path: C:\WINDOWS\System32\ole32.dll
File Name: OLEAUT32.dll
File Size: 793960
Create Time: Fri Jul 20 12:19:51 2018
Modified Time: Thu May 3 00:48:42 2018
File Path: C:\WINDOWS\System32\OLEAUT32.dll
File Name: oledlg.dll
File Size: 165376
Create Time: Fri Sep 29 06:41:40 2017
Access Time: Tue Jan 29 16:45:37 2019
Modified Time: Fri Sep 29 06:41:40 2017
File Path: C:\WINDOWS\system32\oledlg.dll
File Name: OPENGL32.dll
File Size: 1034752
File Path: C:\WINDOWS\system32\opengl32.dll
File Name: RPCRT4.dll
Dll Version: 6.02.16299.846
File Size: 1173168
Create Time: Mon Dec 17 20:09:43 2018
Modified Time: Mon Dec 3 22:57:23 2018
File Path: C:\WINDOWS\System32\RPCRT4.dll
File Name: SAMLIB.dll
File Size: 121344
Access Time: Wed Jan 30 11:29:30 2019
File Path: C:\WINDOWS\system32\SAMLIB.dll
File Name: SECUR32.DLL
Dll Version: 6.02.16299.461
File Size: 27648
Create Time: Fri Jul 20 12:20:56 2018
Access Time: Wed Jan 30 11:41:57 2019
Modified Time: Fri May 11 14:50:13 2018
File Path: C:\WINDOWS\system32\SECUR32.DLL
File Name: SETUPAPI.dll
Dll Version: 6.02.16299.248
File Size: 4537040
Create Time: Fri Jul 20 12:16:51 2018
Modified Time: Fri Feb 9 22:12:18 2018
File Path: C:\WINDOWS\system32\SETUPAPI.dll
File Name: SHELL32.dll
Dll Version: 6.02.16299.666
File Size: 21356936
Create Time: Mon Oct 15 20:33:55 2018
Modified Time: Fri Sep 14 21:09:10 2018
File Path: C:\WINDOWS\System32\SHELL32.dll
File Name: SHLWAPI.DLL
File Size: 327008
Create Time: Fri Jul 20 12:20:16 2018
Modified Time: Sun Apr 15 14:25:31 2018
File Path: C:\WINDOWS\System32\shlwapi.dll
File Name: SNMPAPI.DLL
File Size: 32768
Access Time: Tue Jan 29 17:47:02 2019
File Path: C:\WINDOWS\system32\SNMPAPI.DLL
File Name: urlmon.dll
Dll Version: 11.00.16299.785
File Size: 1808896
Create Time: Mon Nov 19 21:21:57 2018
Access Time: Wed Jan 30 11:41:47 2019
Modified Time: Mon Oct 29 21:26:52 2018
File Path: C:\WINDOWS\SYSTEM32\urlmon.dll
File Name: USER32.dll
Dll Version: 6.02.16299.125
File Size: 1634288
Create Time: Wed Dec 13 17:40:01 2017
Modified Time: Wed Dec 13 17:40:01 2017
File Path: C:\WINDOWS\System32\USER32.dll
File Name: VERSION.dll
File Size: 30560
Create Time: Fri Sep 29 06:41:58 2017
Modified Time: Fri Sep 29 06:41:58 2017
File Path: C:\WINDOWS\SYSTEM32\VERSION.dll
File Name: WINHTTP.dll
Dll Version: 6.02.16299.820
File Size: 904408
Create Time: Mon Dec 17 20:08:02 2018
Modified Time: Tue Nov 6 22:26:40 2018
File Path: C:\WINDOWS\SYSTEM32\WINHTTP.dll
File Name: WININET.dll
Dll Version: 11.00.16299.820
File Size: 4832256
Create Time: Mon Dec 17 20:07:44 2018
Access Time: Wed Jan 30 11:41:37 2019
Modified Time: Tue Nov 6 21:02:15 2018
File Path: C:\WINDOWS\SYSTEM32\WININET.dll
File Name: WINMM.DLL
File Size: 123072
Create Time: Fri Sep 29 06:41:25 2017
Modified Time: Fri Sep 29 06:41:25 2017
File Path: C:\WINDOWS\SYSTEM32\WINMM.dll
File Name: WINSPOOL.DRV
File Size: 532480
Create Time: Mon Oct 15 20:35:29 2018
Access Time: Wed Jan 30 11:41:56 2019
Modified Time: Thu Aug 30 16:41:51 2018
File Path: C:\WINDOWS\system32\WINSPOOL.DRV
File Name: WS2HELP.dll
File Size: 4608
Access Time: Wed Jan 30 11:42:35 2019
File Path: C:\WINDOWS\system32\WS2HELP.dll
File Name: WS2_32.dll
File Size: 428352
File Path: C:\WINDOWS\System32\WS2_32.dll
File Name: WSOCK32.dll
File Size: 18432
File Path: C:\WINDOWS\SYSTEM32\WSOCK32.dll
License Information
| Feature | S/W or IP Core | Version | Expiring | Start Date | Floating or Node Locked | Count | ServerName | Host Id | Host Id Matches | Notice | Issuer | Feature Index | License Validity | Licenses in Use | File Name | Info |
| axi_usb2_device | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 1 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,axi_usb2_device,ip,permanent,_0_0_0 |
| can | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 2 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,can,ip,permanent,_0_0_0 |
| canfd | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 3 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,canfd,ip,permanent,_0_0_0 |
| cmac | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 4 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,cmac,ip,permanent,_0_0_0 |
| cmac_an_lt | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 5 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,cmac_an_lt,ip,permanent,_0_0_0 |
| cmac_usplus | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 6 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,cmac_usplus,ip,permanent,_0_0_0 |
| cpri | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 7 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,cpri,ip,permanent,_0_0_0 |
| displayport | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 8 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,displayport,ip,permanent,_0_0_0 |
| eth_avb_endpoint | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 9 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,eth_avb_endpoint,ip,permanent,_0_0_0 |
| interlaken | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 10 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,interlaken,ip,permanent,_0_0_0 |
| jesd204 | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 11 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,jesd204,ip,permanent,_0_0_0 |
| l_eth_basekr | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 12 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,l_eth_basekr,ip,permanent,_0_0_0 |
| l_eth_baser | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 13 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,l_eth_baser,ip,permanent,_0_0_0 |
| l_eth_mac_pcs | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 14 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,l_eth_mac_pcs,ip,permanent,_0_0_0 |
| pci32 | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 15 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,pci32,ip,permanent,_0_0_0 |
| pci64 | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 16 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,pci64,ip,permanent,_0_0_0 |
| spdif | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 17 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,spdif,ip,permanent,_0_0_0 |
| srio_phylog_io | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 18 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,srio_phylog_io,ip,permanent,_0_0_0 |
| ten_gig_eth_mac | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 19 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,ten_gig_eth_mac,ip,permanent,_0_0_0 |
| ten_gig_eth_pcs_pma_basekr | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 20 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,ten_gig_eth_pcs_pma_basekr,ip,permanent,_0_0_0 |
| tri_mode_eth_mac | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 21 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,tri_mode_eth_mac,ip,permanent,_0_0_0 |
| tsn_bridged_endpoint_eth_mac | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 22 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,tsn_bridged_endpoint_eth_mac,ip,permanent,_0_0_0 |
| tsn_endpoint_eth_mac | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 23 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,tsn_endpoint_eth_mac,ip,permanent,_0_0_0 |
| usxgmii_mac_pcs | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 24 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,usxgmii_mac_pcs,ip,permanent,_0_0_0 |
| v_ccm | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 25 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_ccm,ip,permanent,_0_0_0 |
| v_cresample | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 26 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_cresample,ip,permanent,_0_0_0 |
| v_deinterlacer | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 27 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_deinterlacer,ip,permanent,_0_0_0 |
| v_enhance | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 28 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_enhance,ip,permanent,_0_0_0 |
| v_gamma | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 29 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_gamma,ip,permanent,_0_0_0 |
| v_hdmi | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 30 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_hdmi,ip,permanent,_0_0_0 |
| v_osd | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 31 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_osd,ip,permanent,_0_0_0 |
| v_rgb2ycrcb | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 32 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_rgb2ycrcb,ip,permanent,_0_0_0 |
| v_ycrcb2rgb | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 33 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,v_ycrcb2rgb,ip,permanent,_0_0_0 |
| x_eth_mac | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 34 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,x_eth_mac,ip,permanent,_0_0_0 |
| xxv_eth_basekr | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 35 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,xxv_eth_basekr,ip,permanent,_0_0_0 |
| xxv_eth_mac_pcs | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 36 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,xxv_eth_mac_pcs,ip,permanent,_0_0_0 |
| xxv_tsn_802d1cm | IP:Design_Linking | 2018.06 | Permanent | 13-Jun-2018 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 37 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\Xilinx.lic | License_Type:Design_Linking;ipman,xxv_tsn_802d1cm,ip,permanent,_0_0_0 |
| PCIE_BLK_PLUS | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 38 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,PCIE_BLK_PLUS,ip,permanent,_ANY |
| PCIE_BLK_PLUS_classic | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 39 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| RGB2YCRCB | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 40 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,RGB2YCRCB,ip,permanent,_ANY |
| RGB2YCRCB_classic | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 41 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| S6_PCIE | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 42 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,S6_PCIE,ip,permanent,_ANY |
| S6_PCIE_classic | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 43 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| TC | IP:Bought | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 44 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,TC,ip,permanent,_ANY |
| TC_classic | IP:Bought | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 45 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| V4_EMAC | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 46 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V4_EMAC,ip,permanent,_ANY |
| V4_EMAC_classic | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 47 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| V5_EMAC | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 48 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V5_EMAC,ip,permanent,_ANY |
| V5_EMAC_classic | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 49 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| V6_EMAC | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 50 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V6_EMAC,ip,permanent,_ANY |
| V6_EMAC_classic | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 51 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| V6_PCIE | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 52 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,V6_PCIE,ip,permanent,_ANY |
| V6_PCIE_classic | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 53 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| XAUI | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 54 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,XAUI,ip,permanent,_ANY |
| XAUI_classic | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 55 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| YCRCB2RGB | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 56 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,YCRCB2RGB,ip,permanent,_ANY |
| YCRCB2RGB_classic | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 57 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| pcie_blk_plus_v1 | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 58 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| s6_pcie_v1 | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 59 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| ten_gig_eth_pcs_pma | IP:Bought | 2012.04 | Permanent | 21-Mar-2012 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc | 60 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;ipman,ten_gig_eth_pcs_pma,ip,permanent,_0_0_0 |
| v4_emac_v4 | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 61 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| v5_emac_v1 | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 62 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| v6_emac_v1 | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 63 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| v6_pcie_v1 | IP:Bought | 2010.08 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 64 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| v_rgb2ycrcb | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 65 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,RGB2YCRCB,ip,permanent,_ANY |
| v_rgb2ycrcb_v2 | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 66 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| v_tc | IP:Bought | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 67 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,TC,ip,permanent,_ANY |
| v_tc_v1 | IP:Bought | 2013.10 | Permanent | 24-Sep-2013 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 68 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| v_ycrcb2rgb | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 69 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought;Xilinx_Free_IP_Core,YCRCB2RGB,ip,permanent,_ANY |
| v_ycrcb2rgb_v2 | IP:Bought | 2013.10 | Permanent | 9-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 70 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| xaui_v3_0 | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 71 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| xaui_v4_0 | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 72 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| xaui_v5_0 | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 73 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| xaui_v6 | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 74 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| xaui_v7 | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 75 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| xaui_v8 | IP:Bought | 2010.08 | Permanent | 16-Aug-2009 | Nodelocked | Uncounted | | ANY | Yes | | Xilinx Inc, ip_license_admin | 76 | Okay | Not Applicable | C:\Xilinx\Vivado\2018.2\data\ip\core_licenses\XilinxFree.lic | License_Type:Bought |
| Analyzer | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 77 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,Vivado_System_Edition_Eval,software,evaluation,_211632088_1777503594_210664226_102 |
| HLS | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 78 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,Vivado_System_Edition_Eval,software,evaluation,_211632088_1777503594_210664226_102 |
| Implementation | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 79 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,Vivado_System_Edition_Eval,software,evaluation,_211632088_1777503594_210664226_102 |
| PartialReconfiguration | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 80 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,PartialReconfiguration,software,evaluation,_211632088_1777503594_210664226_861 |
| SDK | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 81 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,SDK,software,evaluation,_211632088_1777503594_210664226_660 |
| Simulation | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 82 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,Vivado_System_Edition_Eval,software,evaluation,_211632088_1777503594_210664226_102 |
| Synthesis | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 83 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,Vivado_System_Edition_Eval,software,evaluation,_211632088_1777503594_210664226_102 |
| SysGen | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 84 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,Vivado_System_Edition_Eval,software,evaluation,_211632088_1777503594_210664226_102 |
| Vivado_System_Edition_Eval | Tools | 2018.12 | 04-feb-2019 | 20-Dec-2018 | Nodelocked | Uncounted | | DISK_SERIAL_NUM=0c98749b | No | | Xilinx Inc | 85 | Okay | Not Applicable | C:\Users\eskul\AppData\Roaming\XilinxLicense\Xilinx.lic | eskull@0,Vivado_System_Edition_Eval,software,evaluation,_211632088_1777503594_210664226_102 |
Thank you again.
01-31-2019 07:00 AM
Hello eskull@0,
From the server point of view, all seems to be up and running.
So, the issue is coming from the Client's end.
To be able to check out the license from the server, the client end needs to set their XILINXD_LICENSE_FILE environment variable to point to the server with port_number@server_name, e.g.:
In your case, on your Windows 10 PC (i.e. your client PC = 2JCCSQ2), all you have done is, you've actually pointed your LM_LICENSE_FILE to your node-locked license however you haven't actually pointed this machine where to look for the Floating licenses.
Therefore, open your Vivado License Manager and set XILINXD_LICENSE_FILE to the following:
XILINXD_LICENSE_FILE=C:\Users\eskul\AppData\Roaming\XilinxLicense;2100@mint1
That way, Vivado will find your Node-Locked Vivado related license in the C:\Users\eskul\AppData\Roaming\XilinxLicense folder and then, it can also search and Check Out your IP Core floating license from the server 2100@mint1. And your issue should be sorted for you then.
Hope this helps.
01-31-2019 11:53 AM
Re. all appears OK on the server side, then why does the LMTools - Status Enquiry return the following error:
Status
There seems to be a dis-connect between the LMGRD log and what the server is actually doing?
Thank you again.
01-31-2019 12:38 PM - edited 01-31-2019 12:39 PM
Following thru with your advice, I edited the XILINXD_LICENSE_FILE on my client, which was originally set to 2100@mint1, to c:\Users\eskul\AppData\Roaming\XilinxLicense;2100@mint1.
For this test, since there is an existing lmgrd server running that serves licenses for a different tool, and people were using that license, rather than shutting down that license as we did for prior testing, we started a new lmgrd server session on the server machine that runs with the Xilinx.lic file. The intent was to run a second lmgrd in parallel with existing lmgrd. After starting up that lmgrd, no log file was generated for the Xilinx session. Status Enquiry in LMTools only showed the other tool license status. The Xilinx license did not appear. There was an option box to enter a specific daemon, on the status page of LMTools - we entered Xilinxd, but that didn't change the status report, which still only showed the other license (which was running ok). So maybe we are not setting up the second lmgrd session correctly...
On my client, starting a new Vivado session, loaded the 10GbE design and ran Reports-IP Status, which returned for 10G Ethernet MAC and PCS/PMA cores:
License = Design Linking.
Clicking on that link shows:
Feature: ten_gig_eth_mac
Status: Design Linking
Built in search paths: c:/Users/eskul/AppData/Roaming/XilinxLicense/Xilinx.lic;2100@nmint1;c:/Xilinx/Vivado/2018.2/data/ip/core_licenses/Xilinx.lic;c:/Xilinx/Vivado/2018.2/data/ip/core_licenses/XilinxFree.lic;Xilinx.lic;c:/.Xilinx
Meanwhile, we will repeat the above test running just one lmgrd session with the Xilinx license only, later when the users are done with the other license.
Thank you again for your time and help.
01-31-2019 07:08 PM - edited 01-31-2019 07:12 PM
We ran a different test. This time we merged the Vivado 10GbE floating core license file content in to the existing server license file and restarted lmgrd. The XilinxD appears to have started correctly, but part of the core appears to be not visible - details below...
The lmgrd log shows XilinxD started correctly (appears towards end of the pasted log file contents):
17:41:43 (lmgrd) -----------------------------------------------
17:41:43 (lmgrd) Please Note:
17:41:43 (lmgrd)
17:41:43 (lmgrd) This log is intended for debug purposes only.
17:41:43 (lmgrd) In order to capture accurate license
17:41:43 (lmgrd) usage data into an organized repository,
17:41:43 (lmgrd) please enable report logging. Use Flexera Software LLC's
17:41:43 (lmgrd) software license administration solution,
17:41:43 (lmgrd) FlexNet Manager, to readily gain visibility
17:41:43 (lmgrd) into license usage data and to create
17:41:43 (lmgrd) insightful reports on critical information like
17:41:43 (lmgrd) license availability and usage. FlexNet Manager
17:41:43 (lmgrd) can be fully automated to run these reports on
17:41:43 (lmgrd) schedule and can be used to track license
17:41:43 (lmgrd) servers and usage across a heterogeneous
17:41:43 (lmgrd) network of servers including Windows NT, Linux
17:41:43 (lmgrd) and UNIX.
17:41:43 (lmgrd)
17:41:43 (lmgrd)
17:41:43 (lmgrd)
17:41:43 (lmgrd) Server's System Date and Time: Thu Jan 31 2019 17:41:43 Pacific Standard Time
17:41:43 (lmgrd) pid 30584
17:41:43 (lmgrd) SLOG: Summary LOG statistics is enabled.
17:41:43 (lmgrd) Done rereading
17:41:43 (lmgrd) FlexNet Licensing (v11.14.1.3 build 212549 x64_n6) started on mint1 (IBM PC) (1/31/2019)
17:41:43 (lmgrd) Copyright (c) 1988-2017 Flexera Software LLC. All Rights Reserved.
17:41:43 (lmgrd) World Wide Web: http://www.flexerasoftware.com
17:41:43 (lmgrd) License file(s): C:\MentorGraphics\License_Files\SERVER_2c56dc725238_MergedXilinx.txt
17:41:43 (lmgrd) lmgrd tcp-port 1717
17:41:43 (lmgrd) (@lmgrd-SLOG@) ===============================================
17:41:43 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
17:41:43 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Jan 31 2019 17:41:43 Pacific Standard Time
17:41:43 (lmgrd) (@lmgrd-SLOG@) PID: 30584
17:41:43 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.14.1.3 build 212549 x64_n6 ( build 212549 (ipv6))
17:41:43 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
17:41:43 (lmgrd) (@lmgrd-SLOG@) Listening port: 1717
17:41:43 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
17:41:43 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
17:41:43 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
17:41:43 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\MentorGraphics\License_Files\SERVER_2c56dc725238_MergedXilinx.txt -l C:\MentorGraphics\Licensing\MGserverLog.txt -z -s
17:41:43 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\MentorGraphics\License_Files\SERVER_2c56dc725238_MergedXilinx.txt
17:41:43 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
17:41:43 (lmgrd) Starting vendor daemons ...
17:41:44 (lmgrd) Started mgcld (pid 58980)
17:41:44 (lmgrd) Starting vendor daemon at port 2222
17:41:44 (lmgrd) Using vendor daemon port 2222 specified in license file
17:41:44 (lmgrd) Started xilinxd (pid 37904)
17:41:44 (mgcld) FlexNet Licensing version v11.14.1.3 build 212549 x64_n6
17:41:44 (mgcld) SLOG: Summary LOG statistics is enabled.
17:41:44 (mgcld) SLOG: FNPLS-INTERNAL-CKPT1
17:41:44 (mgcld) SLOG: VM Status: 0
17:41:44 (mgcld) Server started on mint1 for: blzanyangle
17:41:44 (mgcld) blzanyangle blzautoroute blzautoroute
17:41:44 (mgcld) blzdbexp blzdbexp blzdbstd
17:41:44 (mgcld) blzdreexp blzdrestd blzgenedit
17:41:44 (mgcld) blzgenedit blzlayers2 blzlayers4
17:41:44 (mgcld) blzlayers4 blzlayers8 blzlayersunl
17:41:44 (mgcld) blzlayersunl blzshell blzshell
17:41:44 (mgcld) blzverify blzverify cespads
17:41:44 (mgcld) edxpublsh edxverify edxwrtrdr
17:41:44 (mgcld) ezwforhlynx lmpads lpepads
17:41:44 (mgcld) m3dpdfoutput m3dplugin padslogic
17:41:44 (mgcld) padsprjint2 padsstd_c padsstdplus_c
17:41:44 (mgcld) ploglibedit plogpadspcb plogpdf
17:41:44 (mgcld) plogschedit plogshell pwradvedtrf
17:41:44 (mgcld) pwradvedtrf pwranalog pwranalog
17:41:44 (mgcld) pwrautoplace pwrautoplace pwrcam
17:41:44 (mgcld) pwrcam pwrcam350 pwrcam350
17:41:44 (mgcld) pwrcamplus pwrcamplus pwrcopperflood
17:41:44 (mgcld) pwrcopperflood pwrdbexp pwrdbexp
17:41:44 (mgcld) pwrdbstd pwrdrafting pwrdrafting
17:41:44 (mgcld) pwrdre pwrdxf pwrdxf
17:41:44 (mgcld) pwreco pwreco pwrgenedit
17:41:44 (mgcld) pwrgenedit pwrlibedit pwrlibedit
17:41:44 (mgcld) pwrpdf pwrradialplace pwrradialplace
17:41:44 (mgcld) pwrshell pwrshell pwrspecctralink
17:41:44 (mgcld) pwrspecctralink pwrsplitplanes pwrsplitplanes
17:41:44 (mgcld) pwrvariants pwrverify pwrverify
17:41:44 (mgcld) spiceint visedatapads
17:41:44 (mgcld)
17:41:44 (mgcld) Licenses are case sensitive for mgcld
17:41:44 (mgcld)
17:41:44 (mgcld) EXTERNAL FILTERS are OFF
17:41:44 (lmgrd) mgcld using TCP-port 54768
17:41:44 (mgcld) mgcld v9.18.8.1
17:41:44 (mgcld) SLOG: Statistics Log Frequency is 240 minute(s).
17:41:44 (mgcld) SLOG: TS update poll interval is 600 seconds.
17:41:44 (mgcld) SLOG: Activation borrow reclaim percentage is 0.
17:41:44 (mgcld) (@mgcld-SLOG@) ===============================================
17:41:44 (mgcld) (@mgcld-SLOG@) === Vendor Daemon ===
17:41:44 (mgcld) (@mgcld-SLOG@) Vendor daemon: mgcld
17:41:44 (mgcld) (@mgcld-SLOG@) Start-Date: Thu Jan 31 2019 17:41:44 Pacific Standard Time
17:41:44 (mgcld) (@mgcld-SLOG@) PID: 58980
17:41:44 (mgcld) (@mgcld-SLOG@) VD Version: v11.14.1.3 build 212549 x64_n6 ( build 212549 (ipv6))
17:41:44 (mgcld) (@mgcld-SLOG@) === Startup/Restart Info ===
17:41:44 (mgcld) (@mgcld-SLOG@) Options file used: None
17:41:44 (mgcld) (@mgcld-SLOG@) Is vendor daemon a CVD: No
17:41:44 (mgcld) (@mgcld-SLOG@) Is TS accessed: No
17:41:44 (mgcld) (@mgcld-SLOG@) TS accessed for feature load: -NA-
17:41:44 (mgcld) (@mgcld-SLOG@) Number of VD restarts since LS startup: 0
17:41:44 (mgcld) (@mgcld-SLOG@) === Network Info ===
17:41:44 (mgcld) (@mgcld-SLOG@) Listening port: 54768
17:41:44 (mgcld) (@mgcld-SLOG@) Daemon select timeout (in seconds): 1
17:41:44 (mgcld) (@mgcld-SLOG@) === Host Info ===
17:41:44 (mgcld) (@mgcld-SLOG@) Host used in license file: mint1
17:41:44 (mgcld) (@mgcld-SLOG@) Running on Hypervisor: Not determined - treat as Physical
17:41:44 (mgcld) TCP_NODELAY NOT enabled
17:41:44 (xilinxd) Unable to initialize access to trusted storage: 14
17:41:44 (xilinxd) FlexNet Licensing version v11.14.1.0 build 194335 x64_n6
17:41:44 (xilinxd) SLOG: Summary LOG statistics is enabled.
17:41:44 (xilinxd) SLOG: FNPLS-INTERNAL-CKPT1
17:41:44 (xilinxd) SLOG: VM Status: 0
17:41:44 (xilinxd) Server started on mint1 for: ten_gig_eth_mac
17:41:44 (xilinxd) ten_gig_eth_mac_v3_0 ten_gig_eth_mac_v6 ten_gig_eth_mac_v7
17:41:44 (xilinxd) ten_gig_eth_mac_v9 ten_gig_eth_mac_v8 ten_gig_eth_mac_v4_0
17:41:44 (xilinxd) ten_gig_eth_mac_v5_0 xxv_eth_mac_pcs xxv_mac_pcs
17:41:44 (xilinxd) x_eth_mac
17:41:44 (xilinxd) EXTERNAL FILTERS are OFF
17:41:44 (lmgrd) xilinxd using TCP-port 2222
17:41:44 (xilinxd) SLOG: Statistics Log Frequency is 240 minute(s).
17:41:44 (xilinxd) SLOG: TS update poll interval is 600 seconds.
17:41:44 (xilinxd) SLOG: Activation borrow reclaim percentage is 0.
17:41:44 (xilinxd) (@xilinxd-SLOG@) ===============================================
17:41:44 (xilinxd) (@xilinxd-SLOG@) === Vendor Daemon ===
17:41:44 (xilinxd) (@xilinxd-SLOG@) Vendor daemon: xilinxd
17:41:44 (xilinxd) (@xilinxd-SLOG@) Start-Date: Thu Jan 31 2019 17:41:44 Pacific Standard Time
17:41:44 (xilinxd) (@xilinxd-SLOG@) PID: 37904
17:41:44 (xilinxd) (@xilinxd-SLOG@) VD Version: v11.14.1.0 build 194335 x64_n6 ( build 194335 (ipv6))
17:41:44 (xilinxd) (@xilinxd-SLOG@) === Startup/Restart Info ===
17:41:44 (xilinxd) (@xilinxd-SLOG@) Options file used: None
17:41:44 (xilinxd) (@xilinxd-SLOG@) Is vendor daemon a CVD: No
17:41:44 (xilinxd) (@xilinxd-SLOG@) Is TS accessed: No
17:41:44 (xilinxd) (@xilinxd-SLOG@) TS accessed for feature load: -NA-
17:41:44 (xilinxd) (@xilinxd-SLOG@) Number of VD restarts since LS startup: 0
17:41:44 (xilinxd) (@xilinxd-SLOG@) === Network Info ===
17:41:44 (xilinxd) (@xilinxd-SLOG@) Listening port: 2222
17:41:44 (xilinxd) (@xilinxd-SLOG@) Daemon select timeout (in seconds): 1
17:41:44 (xilinxd) (@xilinxd-SLOG@) === Host Info ===
17:41:44 (xilinxd) (@xilinxd-SLOG@) Host used in license file: mint1
17:41:44 (xilinxd) (@xilinxd-SLOG@) Running on Hypervisor: Not determined - treat as Physical
The merged license file (again the Vivado content is towards the end):
SERVER RB-mint1 2C56DC725238 1717
DAEMON mgcld C:\MentorGraphics\Licensing\mgcld
INCREMENT blzanyangle mgcld 2007.060 30-sep-2019 1 BE5C9D117B7908B04E7C \
VENDOR_STRING=FFE6C192 SN=63356475 SIGN2="11D0 37D8 9AC9 BF9F 8D00 \
7FC9 C425 D525 EA3C 8D6B A93D 83DA 78BB 9B5B 0FAD 1B52 F648 B8D8 160E \
3A0F 1D5A 3DD6 5060 5FD8 BC7D F80D 2E51 3D40 FE9F FAD0"
INCREMENT blzanyangle mgcld 2019.060 30-sep-2019 1 CE6DA0AB703A3D17563A \
VENDOR_STRING=695B6745 SN=63937916 SIGN2="0A96 5DC3 59BC B5D7 CCB8 \
E064 BA74 9D27 27B9 6735 36A1 BE0A CF83 BA01 7C00 12B4 3714 8164 0187 \
AB4B A363 2D99 640D 33F9 5703 CEB3 ACF8 B212 73F8 250F"
INCREMENT blzautoroute mgcld 2007.060 30-sep-2019 1 0E1CBD710F8F59D58B73 \
VENDOR_STRING=FA6C6235 SN=63356500 SIGN2="067C E894 DA2D 1A83 0A4F \
384B 8DC3 C4DD E99C B1A7 0696 231C 2408 B720 F31F 1ED4 ED19 3D46 95E6 \
F757 354E CF85 0622 1F33 D0BE 490F 9BBF 6DDD 8E40 55D3"
INCREMENT blzautoroute mgcld 2019.060 30-sep-2019 1 8E1D50DB47E6331A3090 \
VENDOR_STRING=6D47912D SN=63937914 SIGN2="0316 397B EA13 F9BC 1BE5 \
3C16 E50B DC30 5EF9 F2F0 0F9B 8078 D3C5 AAF0 EA09 1A54 54AC 7266 CA6F \
31F6 13AB 21B7 2F48 10DF 0C74 74FB AA6D 946E 53A5 DE54"
INCREMENT blzdbexp mgcld 2007.060 30-sep-2019 1 FE5C4D310AFD206AC883 \
VENDOR_STRING=65AC5C9E SN=63356474 SIGN2="0E4C 7456 5D11 5C70 EC87 \
1F87 0FB0 EBC9 125D 5470 DB39 2449 BAFB EA43 0922 0345 FECD EE80 0ADA \
7C8B E81E 61D9 5463 B85E 5618 6DB4 C587 A1F6 94C1 13D1"
INCREMENT blzdbexp mgcld 2019.060 30-sep-2019 2 AE3CADD1FC35C3518245 \
VENDOR_STRING=ADC4A273 SN=63356473 SIGN2="1057 CB53 1A4E 6961 66B6 \
CD93 D630 7ACC D70A 4120 84CB E842 F9A4 9576 86F5 1EB3 19E8 1B20 403E \
9A8D 89F4 1DE7 3029 07A3 2428 80FC A8BB 4090 355A 8AB0"
INCREMENT blzdbexp mgcld 2019.060 30-sep-2019 1 5E1D001B9C40833B2337 \
VENDOR_STRING=30B7A318 SN=63937896 SIGN2="0B30 BF41 5144 12D3 3CAE \
E6DB 5774 EBFF A54F 06CD EB57 DAA2 299D 3F0F 756C 054F F467 18C1 B81E \
66F0 9FAE FB7A 5E03 6980 0843 F53D FE5B D40B 21EA C4BD"
INCREMENT blzdbstd mgcld 2007.060 30-sep-2019 1 CE5C7D31867B617E2AF6 \
VENDOR_STRING=9A22205D SN=63356494 SIGN2="0728 C9EB CA08 831E D5B5 \
E176 549A 94B6 4133 5CD2 70C0 CD95 4DDF 48FB 8E86 17D4 CA44 C723 6310 \
71A0 B562 7602 AD19 347D 9252 A7C7 2D3C F753 18FC 3B0B"
INCREMENT blzdreexp mgcld 2019.060 30-sep-2019 1 AE5CBDB1EF0329B3EE34 \
VENDOR_STRING=59BBF946 SN=63356487 SIGN2="1443 EB30 CB3B EF1E 3AF7 \
55DE DBE7 CD79 FD8F 9717 FA89 F7D5 3F50 07C7 C3A1 114E 7FC0 0E4F 618E \
043A 4881 66AF A4F2 17E0 0173 C58E 1EAC EB35 2AFB 6359"
INCREMENT blzdrestd mgcld 2019.060 30-sep-2019 1 2ECCCD9175B208533D56 \
VENDOR_STRING=F51CB889 SN=63356497 SIGN2="1D39 5D81 E1E8 E121 3064 \
D32E 5EFF 1F60 FDD1 AAD1 723E 8103 39A2 1FCA 671D 1F41 A60A 0BDF CFC6 \
293D 77A1 38C7 FFEC 34DC 1225 CC90 A6AB 6550 75BA 9360"
INCREMENT blzgenedit mgcld 2007.060 30-sep-2019 1 2E8CFD3122CFFD7150BA \
VENDOR_STRING=F5442F9D SN=63356506 SIGN2="0F7B AFDC D8D6 F34C 4518 \
E3F6 A6D0 BDC6 8412 CDDF 3C85 5199 A7CF E9F2 AD3D 0757 CA0B 23DD B2F5 \
FE24 31BB 734A 4900 E1B0 D947 283C AD05 695C 172B 024B"
INCREMENT blzgenedit mgcld 2019.060 30-sep-2019 1 4E2D70CB74CF843BE117 \
VENDOR_STRING=104BD680 SN=63937897 SIGN2="0F56 EB82 84FD 3005 E143 \
4510 E883 985B 5DF0 C930 6147 16A4 F3EE 3AB3 B6BA 1F84 5F20 7986 0CBE \
6117 30BF 8A86 C5EB 8597 8333 297D 18DA B344 E2A9 83E7"
INCREMENT blzlayers2 mgcld 2007.060 30-sep-2019 1 4E7CFD2150E4F9A3966F \
VENDOR_STRING=03847EF9 SN=63356514 SIGN2="11B1 1B2F 531D 1637 EAD2 \
5628 56BB E267 D161 6B1D C221 1A5D 7D83 539D 8CA2 19A8 FC86 2096 7300 \
DFBD 9C30 E02B D633 A04F 1494 6D21 52F0 647A 77E9 09E2"
INCREMENT blzlayers4 mgcld 2007.060 30-sep-2019 1 DEBC1D71544BEC9EEF00 \
VENDOR_STRING=A28B661F SN=63356465 SIGN2="1ECB 583F 4B02 71EF EBFE \
B683 CBAA C56E 0B2E C25A 2768 6578 A1B0 C911 AEE8 11BB 80E5 2020 F226 \
670D 5634 B567 811E 2259 C7D8 6606 9C27 16D1 3E45 595D"
INCREMENT blzlayers4 mgcld 2019.060 30-sep-2019 2 BEDC9D21523FE0E8F16B \
VENDOR_STRING=7D32A562 SN=63356466 SIGN2="138A E77A 2232 7B40 5108 \
9C2B 06F7 0134 62E1 29DB AC05 BEE3 195C E1A9 CE49 1369 2F00 13EB E635 \
A324 F16F 1C79 F28E 776D 38C6 00C5 38AA FC46 705F 125F"
INCREMENT blzlayers4 mgcld 2019.060 30-sep-2019 1 1EED609BABC672D3E275 \
VENDOR_STRING=DA009AAE SN=63937915 SIGN2="1A8F FB56 76AF 579E 9530 \
3777 AE06 2EF8 0223 D7D0 4073 FE3B 207A 5D98 F5B5 16ED 5DB2 D15C 9269 \
9A17 AB69 ED65 8CFE 17B2 FA1A D195 04CC F64F F3A4 DA55"
INCREMENT blzlayers8 mgcld 2007.060 30-sep-2019 1 2E7C6D81FDFC9E3FB720 \
VENDOR_STRING=19B631DC SN=63356521 SIGN2="162D B308 967C 4804 F5D6 \
C16B C862 1A87 47E7 EB5A 278B 8197 6E93 9444 C68C 1291 C384 BE4D 56BA \
82BD BD03 1CDC 3A69 542F 4EE7 49D2 A03F A786 4905 964D"
INCREMENT blzlayersunl mgcld 2007.060 30-sep-2019 1 1E8C6D21FB40D06E5E2D \
VENDOR_STRING=6A0720C0 SN=63356457 SIGN2="0D30 9501 E334 B766 2C72 \
C246 4983 3814 CEEA 8A75 CE04 FE03 68CA F09B EE0C 1169 A5AC 71AA CE71 \
23D8 8732 5DCD 45DE 3890 4AEB FA73 6261 18CC 7893 477C"
INCREMENT blzlayersunl mgcld 2019.060 30-sep-2019 2 DE5C4DC11DBF3A1ED112 \
VENDOR_STRING=D5D8F26B SN=63356456 SIGN2="024F 5F56 2058 A6FF C440 \
4898 B8FE 6BF6 EEF4 1BF1 6F51 A37D 0636 7BBB 4A28 116B D301 D8CC FD17 \
C05C 4557 7F22 E126 45D0 854E 6530 901E 4CF9 2534 4E7D"
INCREMENT blzshell mgcld 2007.060 30-sep-2019 1 DE7CDD71F15BE805FCC1 \
VENDOR_STRING=ED327DAD SN=63356463 SIGN2="0B7D FE5C 7329 6A36 1B88 \
AEA4 8C39 8BB4 7E46 1D40 B81E B481 DAC3 980A 447E 0D65 32CC 8A65 1707 \
B7A2 CE27 AFAB CCB8 0169 9EA3 B72C B582 CD11 3E4D 9D36"
INCREMENT blzshell mgcld 2019.060 30-sep-2019 1 CE8DB02BBBD4CBF61AB2 \
VENDOR_STRING=AB3FDD3C SN=63937898 SIGN2="1B25 9095 8FDB 797A D71E \
4697 AEC7 03F4 9FF8 96CB 744D 5348 A93D 5294 AB42 1B3D E593 28C6 94DD \
8A7A C5BC 1E0C 8329 86B3 3865 AF2D 0892 E131 9063 09BA"
INCREMENT blzverify mgcld 2007.060 30-sep-2019 1 DE4CED319BC2BC466D1B \
VENDOR_STRING=2FF0B048 SN=63356447 SIGN2="0A2B 9ACA FA88 727F F204 \
5238 9A3D A521 07E7 0193 BF55 F651 3E8E 818A 1519 18E5 6010 6BB0 763F \
A73E 8223 C59E 218E AB13 62CF 4ACB 68BB A721 CA77 FD92"
INCREMENT blzverify mgcld 2019.060 30-sep-2019 1 5ECDE03B08C7F9CD6F5F \
VENDOR_STRING=AC0988CF SN=63937910 SIGN2="0311 9200 6C9B D0A2 FBBA \
7BF2 443D 0B3A E8A9 CD4F 0DD4 DFBB 76A9 1BD1 434A 15D1 2E63 E8E9 5DA2 \
B47E 4523 C434 5F96 E563 3976 D69F 0459 D8B8 BEEC 662A"
INCREMENT cespads mgcld 2019.060 30-sep-2019 1 5E6D403BFDFFDA6CEA93 \
VENDOR_STRING=E2E40E9A SN=63937920 SIGN2="1ECB BECD 2E7D 129A 18B5 \
34BB D6B5 EC27 4ED8 BEFC 4F71 28D2 F84A 8E33 7D19 0B71 C2CC 87C5 6ABE \
17BE 8881 8644 08FB 1401 9287 1952 0F94 B263 9793 ED89"
INCREMENT edxpublsh mgcld 2019.060 30-sep-2019 1 EEFD005B2696E862C3D1 \
VENDOR_STRING=31CE66EC SN=63937900 SIGN2="09CD 4900 23D8 FC0A D0B0 \
E4A8 D870 C379 4DF3 8318 9B90 9183 5B62 48BB 0316 09D0 9516 14EB 5544 \
9A24 CEC8 3FE2 487B 33FC 48B6 4D82 D305 E96F 985D 270F"
INCREMENT edxpublsh mgcld 2019.060 30-sep-2019 1 EEFD005B2895EA5CC2D3 \
VENDOR_STRING=31CE66EC SN=63914520 SIGN2="0D75 6127 008F E05B 8A6B \
C36E 2C0C 74D4 9384 8A63 E83C 56D4 F183 F6FA E72F 1BB6 5CF8 3B04 210E \
25CD 584A 2540 CA4A A6D7 4E47 7107 952D C6AC 23F8 4136"
INCREMENT edxpublsh mgcld 2019.060 30-sep-2019 1 EEFD009B2496EC63C3D2 \
VENDOR_STRING=31CE66EC SN=63937864 SIGN2="1F5A 417F C0CF B49F D899 \
216D 7DB1 47A3 8FE5 5603 500F 2E1F 8557 20A3 D8B7 07E6 258C C2CE 3AAC \
11CC 216A 8E09 B18A EDCC 6759 F3D0 AE5F D274 7E84 23A4"
INCREMENT edxpublsh mgcld 2019.060 30-sep-2019 1 EEFD009B2695EE5CC2D5 \
VENDOR_STRING=31CE66EC SN=63914504 SIGN2="021E BF91 191A 9D00 4370 \
C791 5986 0A32 48FC C2CD 5D6E 0A3D 1EB2 D9E1 A144 036D 1EA2 7FB4 22D0 \
B7AB CC8A 3AFE 22CB 71ED C721 2489 FB3D D7ED 194F EEFF"
INCREMENT edxverify mgcld 2019.060 30-sep-2019 1 4E8D500B8D2FB1964A4D \
VENDOR_STRING=F6642CE0 SN=63914522 SIGN2="000A F4CE CFF2 185A 4C4A \
E322 3073 D949 AB46 4CF0 9235 DB28 6098 74B5 FE99 0ADA 1F13 304C CA11 \
8F0B 5596 DD72 4BBC 6F44 1023 47D6 45E8 8925 75F2 8CDC"
INCREMENT edxverify mgcld 2019.060 30-sep-2019 1 4E8D503B8F32B29C4D47 \
VENDOR_STRING=F6642CE0 SN=63937905 SIGN2="1F2F C580 F917 2016 EB6A \
52FC 02EB 5ACD 6392 8818 C40E 7BA9 6631 2D92 4CDF 06C1 DB41 EB8C DC21 \
CAC6 85BA 9878 BC74 A300 FC0B F138 27C4 300F 2F24 CE05"
INCREMENT edxverify mgcld 2019.060 30-sep-2019 1 4E8D504B8932B39B4D4E \
VENDOR_STRING=F6642CE0 SN=63937866 SIGN2="1A7D 1A05 948F 83AB E694 \
7487 F456 0FFC F968 AEB9 83AC 9C44 42A0 106A F947 1482 08B9 8538 A0C2 \
06EF 51C5 5B3C 1257 962C B341 CACA 09DC 39CC D17D 079A"
INCREMENT edxverify mgcld 2019.060 30-sep-2019 1 4E8D504B8F2FB5964A4B \
VENDOR_STRING=F6642CE0 SN=63914506 SIGN2="1020 848A 94BB 1E71 475B \
0ABA 223E 1354 8A61 F870 76E5 5E4E CDD6 7507 9D75 0203 EC79 530A C19A \
B63E 96D1 2881 B12B 1F6C C96D 7901 1E11 8B28 EC16 BF2F"
INCREMENT edxwrtrdr mgcld 2019.060 30-sep-2019 1 1E0D006B066237E4D849 \
VENDOR_STRING=D06E146E SN=63914521 SIGN2="030B C192 ABDA 3FF4 1B1F \
AB13 181B 5BAC 700D BA21 AF6B E5A3 CA68 05CE 315B 0571 D62C 2375 A9EA \
BA4B 77AB 5957 50CB 100B 7E71 00D8 E6DD AF13 07CD AD73"
INCREMENT edxwrtrdr mgcld 2019.060 30-sep-2019 1 1E0D00AB04623BE4D84B \
VENDOR_STRING=D06E146E SN=63914505 SIGN2="0A8D AAAC 6002 6328 9CC1 \
79AD 3011 AC8C 3D4F 20C6 8D14 843F 99AF 6871 7C9B 026D BC65 05BD 18F6 \
A037 9DBF AF9B 242A EB72 D974 E2E0 61D7 F793 FE6F 7E1C"
INCREMENT edxwrtrdr mgcld 2019.060 30-sep-2019 1 1E0D00AB0A7739F1ED3A \
VENDOR_STRING=D06E146E SN=63937865 SIGN2="11D4 4FE1 86A1 FC30 1977 \
A851 4FBD 911E 1194 83DA BF03 6850 9E49 4213 A8C3 173D 7D09 98EC EEE2 \
5713 3F72 F427 2EF0 1021 B3D7 3493 9E8A 7DD5 A9D2 5033"
INCREMENT edxwrtrdr mgcld 2019.060 30-sep-2019 1 1E0D00DB06773CF2ED3D \
VENDOR_STRING=D06E146E SN=63937926 SIGN2="1DC5 B03E 471E 860D 00BE \
5425 BC97 84D4 C3F0 2EA0 39A6 7B8E 8D1F F5CD 294A 1A12 E064 7CCD EC7F \
5B20 C647 8784 C6F1 B197 BCE6 4C0C 4733 3A9C B058 C703"
INCREMENT ezwforhlynx mgcld 2019.060 30-sep-2019 1 0E4DF0BBFC51CB0B3608 \
VENDOR_STRING=12FCD897 SN=63914530 SIGN2="111C 51AF 8FED 9AF1 0C3E \
8B46 6A7E D322 7E3F 7F76 C8B3 A0F9 4CDD 7023 2163 0D7F 509D D797 5544 \
674B EE1A FFDB E3D7 AD93 0174 32AF 07CF FCE1 0056 42ED"
INCREMENT ezwforhlynx mgcld 2019.060 30-sep-2019 1 0E6DF0FBFA55CB0B3608 \
VENDOR_STRING=12FCD897 SN=63914514 SIGN2="0DCA 786E 698A 11CE C47F \
D748 7EE7 2ED9 E644 FD34 02FA B2CD 287F 2DB3 89F0 03D1 AF42 A835 D528 \
3777 C12A 69F0 22BC 3BAE 54C6 E7B4 E81E 154C 2F95 22C5"
INCREMENT lmpads mgcld 2019.060 30-sep-2019 1 AEDD506BEEE8C6E2A9D2 \
VENDOR_STRING=992378F1 SN=63937927 SIGN2="03D5 3D22 3975 5D99 1369 \
4EE3 6DD2 2727 4755 CEA1 737B E690 0C6B CB41 692C 02A6 CF81 C335 F58C \
5C06 403B 07FC AD8B A77E A346 CFE1 12BE 6986 4986 1479"
INCREMENT lpepads mgcld 2019.060 30-sep-2019 1 1E6DD0DB0EA7E9677A3A \
VENDOR_STRING=2FB82903 SN=63937899 SIGN2="0390 C714 9477 FB24 1CE5 \
2661 0ABB DF97 C34D CE4D 153D DDB5 1BCB F4A8 AC1E 08EB 749E 2205 591F \
A76F 96C1 5151 AE65 4924 CE12 ED03 BF6C E07E 7AE4 AFBA"
INCREMENT lpepads mgcld 2019.060 30-sep-2019 1 1E6DD0DB0EB0E9698338 \
VENDOR_STRING=2FB82903 SN=63937867 SIGN2="1074 4A39 D719 BA56 7E9E \
6199 34CC D393 D0AC 7E35 5C70 A8A2 730A 7037 AC2D 1181 4DC4 503C 374F \
500B 5FA8 C766 103D 1787 4A4E A2DE D174 0B3B 6E9C A1DB"
INCREMENT lpepads mgcld 2019.060 30-sep-2019 1 1E7DD0AB0DA8E4567C4E \
VENDOR_STRING=2FB82903 SN=63914523 SIGN2="178F 5E51 1762 FFE4 EE4C \
E4E4 2143 E074 6B0C 9C50 07EF 1B7C 2889 02CE AD2D 014C FBFA 65DC 9727 \
C46F BD45 25D3 DB37 5EAF 5AF5 FF7E D64E C947 C7ED 2E83"
INCREMENT lpepads mgcld 2019.060 30-sep-2019 1 1E7DD0AB0DAAE45A7E4A \
VENDOR_STRING=2FB82903 SN=63914507 SIGN2="06D0 2413 5AF8 367D 639A \
09C0 0A71 EF15 3B5D 0E07 8D8E EEC7 6BD9 11AC D770 0A71 F883 016A DB19 \
E5AF E504 C8C9 2A06 8430 6C1F 6EE3 A10A 7351 21CC 0652"
INCREMENT m3dpdfoutput mgcld 2019.060 30-sep-2019 1 AE0DF04BFB67A47EE1AF \
VENDOR_STRING=A280F203 SN=63914524 SIGN2="019E E3DF 56E8 B679 CFEC \
9432 EE1D 9B71 AF61 A0C9 0024 57DB 0C8B 94A0 B6FC 045A 3105 1E0D 410E \
2036 5BB9 460E E00E 19F5 CCDD BC6C 52CC 7859 57CC 2572"
INCREMENT m3dpdfoutput mgcld 2019.060 30-sep-2019 1 AE0DF06BFB69A87AE1AF \
VENDOR_STRING=A280F203 SN=63914508 SIGN2="0E8E BBD0 18C7 A211 3AB7 \
9A58 54B1 A4F5 6480 2115 ECF3 D7CE F9CA A537 62A2 0E83 1D52 9EBA 31EC \
198C E78A 7E7A F158 861A 7B6B 3056 E4E4 53D1 273A 70B7"
INCREMENT m3dpdfoutput mgcld 2019.060 30-sep-2019 1 AEDDF03BF063AB7AE1AD \
VENDOR_STRING=A280F203 SN=63937868 SIGN2="0155 8272 E4B0 7F2E 4C59 \
EA9A AE45 1C3B 4878 9E77 ED7B 0667 5E2D EF71 65C3 1BDB 31D7 9CF7 7B27 \
439D F99B C646 12FD ACDC D51B 8770 4D6B 0BAC FCD2 833D"
INCREMENT m3dplugin mgcld 2019.060 30-sep-2019 1 AE1D30FB09B4360A16B5 \
VENDOR_STRING=5D5B7923 SN=63914529 SIGN2="1C0A 66E9 FC9E 0B2C C059 \
F5E9 9D2C 5B5A 5BC2 C391 DBF6 5631 6BED 9AB9 52B8 0BB0 3778 6600 FA0C \
38F9 1451 5755 B282 C92F 22CE 06C8 B46D 7D1C 6236 0EE0"
INCREMENT m3dplugin mgcld 2019.060 30-sep-2019 1 AE1D409B0AB4400A16B4 \
VENDOR_STRING=5D5B7923 SN=63914513 SIGN2="0864 0690 E514 9EAE 1535 \
459B 7F76 A17A 550C 14F4 47E1 8846 56DB 6D8B F52F 1E33 BCC9 9501 807F \
5C7E 771B 847C 14C5 C2DC DA07 FF4B 5767 0926 02D3 F5E2"
INCREMENT m3dplugin mgcld 2019.060 30-sep-2019 1 AE1D40AB04B343FD15C5 \
VENDOR_STRING=5D5B7923 SN=63937872 SIGN2="186E CEF4 6EB7 9756 1EF7 \
C325 067A 02AB 8060 EC7A 609A D22C D675 A442 B064 1F0F 1377 32F0 D283 \
3DD2 C04D 3972 078B 74D6 2070 499E 3A4D 86F0 2A9D 992E"
INCREMENT padslogic mgcld 2019.060 30-sep-2019 1 CEEDC0CBA14AD1735F2C \
VENDOR_STRING=8F6C1B92 SN=63914531 SIGN2="1714 9698 C575 40AC 535D \
880F 5F11 BB8A 20FB 9E11 1E0B 31A2 D010 BC37 653F 1E1B B92C 705E A046 \
C748 5BD9 427B 246D 783D DD34 E26A 3C39 A97B 58F0 088F"
INCREMENT padslogic mgcld 2019.060 30-sep-2019 1 CEEDC0EB9D45D57C5A25 \
VENDOR_STRING=8F6C1B92 SN=63937873 SIGN2="1B1A ACF6 2592 1A3F 8FA1 \
59A7 62D6 F7C0 5E06 788D FA0E F51F B59F 3A45 1A60 0D97 BCC8 BB41 39DB \
DAB0 3257 4934 F0DC 7AF4 F448 53F3 F085 00E3 A871 B10E"
INCREMENT padslogic mgcld 2019.060 30-sep-2019 1 CEEDD00B9F4AD5735F2E \
VENDOR_STRING=8F6C1B92 SN=63914515 SIGN2="0117 1A12 1661 81FB B83D \
9375 D685 08FC 2196 729F AF16 A7D3 1C31 ACF0 3DC4 1C1A FE5F 369D 7B3A \
76CA D09D B699 A83F 4985 4B0F 962C 25B6 DA18 6806 8A39"
INCREMENT padsprjint2 mgcld 2019.060 30-sep-2019 1 3E2D607BABCD5E54A2AB \
VENDOR_STRING=2F15EDCA SN=63937919 SIGN2="016F 09FF B074 A088 D55D \
D640 518A 6F37 2F1D D054 8321 5DB4 DA48 3EE4 2315 01D3 364E 351A DADC \
DB3F F044 0073 6648 D355 5CF6 3553 7D76 6369 5DE2 CB1A"
INCREMENT padsstd_c mgcld 2019.060 30-sep-2019 1 BE3D407B9B0B8B11A0F0 \
VENDOR_STRING=A5C52BD3 SN=63937877 SIGN2="027D 7EEB 5427 B7B2 C5CE \
3C61 7B7F 6780 87BE 27A7 FD43 CED8 DF25 B5AC B559 0232 9109 318E 7CF1 \
8C3E 2532 9B2E 4B40 4323 451B D41C 2468 E3A4 7106 07E3"
INCREMENT padsstdplus_c mgcld 2019.060 30-sep-2019 1 8EFD701B52F8EDDA0FDE \
VENDOR_STRING=388A7618 SN=63914528 SIGN2="0076 14DB 624E B15D EB3F \
E9D7 043C 2EBD 3A14 80B5 3032 7669 BE31 0B5F 7A9E 0575 C79A A282 E39E \
0CBC 2161 B89F FC2B 9E31 E4CD 6BAC A12F 28FC 8DE2 2D38"
INCREMENT padsstdplus_c mgcld 2019.060 30-sep-2019 1 9E9D701B52F8ECDB19DE \
VENDOR_STRING=388A7618 SN=63914512 SIGN2="0C11 07B6 0A75 C752 BD59 \
8386 6A86 E20D 6350 D009 99D5 AB0F F33A 45BB D2D3 1979 6AD0 C411 6325 \
FC6F CB8B 1C95 EAE9 ADAC BC7C 530E 1BC5 6F65 976B 5A94"
INCREMENT ploglibedit mgcld 2019.060 30-sep-2019 1 BE9D80DB45CCA6BDD331 \
VENDOR_STRING=51FC31BB SN=63937869 SIGN2="17CF 7767 7F89 5BD5 BB8D \
2475 CA4E 8875 529D 08B6 094B 1516 783B 4DCE B856 1971 05AA 28A9 FF5C \
1640 51E5 0EFE 0B98 56A2 B727 BCD4 59D0 2959 5015 9D0B"
INCREMENT ploglibedit mgcld 2019.060 30-sep-2019 1 BEDD904B42D8A1BFD32E \
VENDOR_STRING=51FC31BB SN=63914525 SIGN2="1AC8 3E68 FA2C DE49 8898 \
D0C3 4C89 106A 30C3 186D 947D 1E16 B779 C5A5 4594 1B4E FB5E 2B69 10E5 \
B825 F475 B742 5548 F526 6495 0358 0A70 BCE5 5662 44FB"
INCREMENT ploglibedit mgcld 2019.060 30-sep-2019 1 BEFD808B40CCA1BFD32E \
VENDOR_STRING=51FC31BB SN=63914509 SIGN2="1F2F 68D1 44EE D68C 8CB5 \
A50A 153B 0143 1FDA 5202 ECF0 4E6D 85D6 E47E C5D8 0BBC D5CA 10C0 66FD \
2980 D6DB 5F5E 4ECB 67DC D3AB 1D99 D817 D56E 407C 795F"
INCREMENT plogpadspcb mgcld 2019.060 30-sep-2019 1 BE5D203B3F6A297D1C39 \
VENDOR_STRING=3A09D52C SN=63914511 SIGN2="181B A66E 8906 BC04 BD4E \
4813 37E6 5FDF 7588 21A6 AFE4 C8BC 5908 0D34 7EEA 0D97 E285 9900 5305 \
1F63 769A 3B35 10EA B065 8934 D3EB 4ED7 C923 A823 FF0A"
INCREMENT plogpadspcb mgcld 2019.060 30-sep-2019 1 BE8D205B3C6C297D1C39 \
VENDOR_STRING=3A09D52C SN=63914527 SIGN2="1D98 F044 0024 5996 5109 \
A792 5EB2 33BD C47A 69E9 78B5 8354 5756 F82E 7F12 09C4 4A81 A79B E8CD \
EBED 24FD 8F49 CF3F 9824 C11E 6382 9AFA F5AD 9219 AFE2"
INCREMENT plogpadspcb mgcld 2019.060 30-sep-2019 1 BEBD200B366A267B1C3E \
VENDOR_STRING=3A09D52C SN=63937871 SIGN2="18AD FB08 F7C7 BEDB C086 \
0D8D 7649 ADD8 676C 100F 2107 1F3A 6A0C E36F BB20 002E F96B 0929 DAED \
6053 1099 6C38 4C3B 9B8E E307 C49E 724D 18C5 43E4 AA0E"
INCREMENT plogpdf mgcld 2019.060 30-sep-2019 1 7E7D10DB24ECF40F1BAC \
VENDOR_STRING=760167D1 SN=63937876 SIGN2="08C1 B24F D29B 6F92 E318 \
0CC5 2659 A754 CC07 D612 17FC EDC3 6720 14BF 5DA5 0D02 9CE3 B354 A959 \
DA70 4697 43F6 2F2F 8E3E 2CCB A035 2ABD F267 9C59 2BFD"
INCREMENT plogpdf mgcld 2019.060 30-sep-2019 1 7E8D10EB23E0F31A10A4 \
VENDOR_STRING=760167D1 SN=63914518 SIGN2="0A57 8206 95FB B0FB 529A \
D476 066D 3DA5 C05E 6A18 0C96 96C3 374E AA8C 323A 1269 B562 C2E4 6197 \
6875 D79A DBEE 7E70 5AD1 6827 1553 3AAC CF54 46EB F9A3"
INCREMENT plogpdf mgcld 2019.060 30-sep-2019 1 7E8D10EB23E2F31612A8 \
VENDOR_STRING=760167D1 SN=63914534 SIGN2="1218 8471 A52B 5659 62F6 \
AEE5 49DA 741F 17D4 E434 0402 254F 399D 7289 BF0A 0668 0644 6067 378A \
24AD AC74 FF7D 1F26 091B BB03 85BB BC62 C1F2 00AE 8A43"
INCREMENT plogschedit mgcld 2019.060 30-sep-2019 1 3EDD209BE802DDB6E04D \
VENDOR_STRING=696305D6 SN=63914533 SIGN2="10A2 7DCC A863 0A10 D4E9 \
100E E159 0523 4237 1D7A F84B F363 89E0 7FC9 1D99 096D 0105 2E96 E3D8 \
C4E1 D20A 115E 3FCE 9351 D35A 31B3 505D 9B8D 0D24 F0CA"
INCREMENT plogschedit mgcld 2019.060 30-sep-2019 1 3EFD205BE6FEDDB6E04D \
VENDOR_STRING=696305D6 SN=63914517 SIGN2="1815 97B6 9281 6D9C 225A \
B86D AF4B 40D7 DE1D 864B 419A A14F 083A 0EB7 5E15 106F 86ED 72E2 5FBE \
2134 239A 5B08 C211 8C9F AAFF A89F 138D 8D73 FE35 6E54"
INCREMENT plogschedit mgcld 2019.060 30-sep-2019 1 4E1D200BE7FCDAB8E048 \
VENDOR_STRING=696305D6 SN=63937875 SIGN2="171F 5077 F8F2 432D B1CA \
936D 039E C414 EF3A BA14 3824 E6A8 6360 C80E DB54 000C F052 1160 0616 \
10C0 9FB1 4D7D 3AC0 6E5F 50A5 1A1B 148E 6E5F 351D 755A"
INCREMENT plogshell mgcld 2019.060 30-sep-2019 1 DEED90DBB16A8039C5AE \
VENDOR_STRING=7EFA7805 SN=63914532 SIGN2="139A C259 0D26 21AE B638 \
DFE5 3119 F753 0A81 E3F5 9AF2 1C84 79DD A4B5 3BB2 1A74 773E 1634 BA2E \
F58E 5CA0 E07F 13B7 8056 A210 FCD6 937B 5F75 4D11 4543"
INCREMENT plogshell mgcld 2019.060 30-sep-2019 1 DEED90FBB569803EC4A7 \
VENDOR_STRING=7EFA7805 SN=63937874 SIGN2="00BA ACB1 4780 16B4 D338 \
ADB4 04ED F31A 7384 AAF3 0635 4DD8 983B 0987 F3FF 0A90 732C E992 9319 \
7FBE AB43 54B8 CA4F 69BC D025 F923 C973 9C35 B7B7 6AAE"
INCREMENT plogshell mgcld 2019.060 30-sep-2019 1 DEEDA01BB36A8439C5AC \
VENDOR_STRING=7EFA7805 SN=63914516 SIGN2="0C6E 8A6F D7D8 06BD F288 \
E777 63A7 64C3 9F9A 1658 6723 BDCE 9EEF FD4F A2EE 0FC5 5E63 0718 DBD6 \
8B2A D8B2 A933 9C53 9F01 F5AF 16BF 888D 4BF5 B3B7 3E3D"
INCREMENT pwradvedtrf mgcld 2007.060 30-sep-2019 1 FE0C7D319B3A99748625 \
VENDOR_STRING=D5EFEE13 SN=63356477 SIGN2="08F8 6BFA BABA 0E8F BD08 \
321B B4D6 41FE 7FEF 0F77 0530 89CB 5815 0ECE 06A0 0974 04DD 413B C652 \
9155 87D7 D67D 7DC1 0E49 4101 7D72 5B60 D7E4 2698 BF91"
INCREMENT pwradvedtrf mgcld 2019.060 30-sep-2019 1 FE9D405B951D81D19FE5 \
VENDOR_STRING=5CE3A732 SN=63937924 SIGN2="13B0 685E A535 C69B E5E4 \
9DE5 9AFC BA37 12A4 A81A 5E3D 6FA6 E0F3 28FE 0998 0EB3 58FB E63A 776E \
F315 7CA2 A154 E923 5B57 A65D 37C2 23EC C998 D916 2D11"
INCREMENT pwranalog mgcld 2007.060 30-sep-2019 1 CE7C7DD1E11580541701 \
VENDOR_STRING=F64C65A6 SN=63356467 SIGN2="0C56 40DA 2B0C 8EB2 65FA \
17B9 7F49 8301 8DC8 0D35 FF13 5A54 82EE 6C10 5081 0393 F779 D2D8 E7C0 \
9D55 78B8 4663 90AF 7E21 A475 1B8A C476 BD24 CAB7 00CD"
INCREMENT pwranalog mgcld 2019.060 30-sep-2019 1 8E8D409B7FBB4417234D \
VENDOR_STRING=1150D99F SN=63937904 SIGN2="0E62 F08A B6C9 15AB 2822 \
48B8 C3C3 B094 51ED A350 9CAE 1BF0 91A3 CFA5 4AA1 1B8A 0299 9078 3348 \
5982 FFC1 EDA4 A35C 0C63 00D0 5678 731B 597A EFAC E14F"
INCREMENT pwrautoplace mgcld 2007.060 30-sep-2019 1 0EFCED51A162B1E5D611 \
VENDOR_STRING=8229F6AE SN=63356488 SIGN2="1928 0168 128F 8FA1 072F \
F2BB 1647 47B3 3597 0DE2 A941 0EC4 3C96 D309 3464 0403 62FD EB38 99EC \
F663 C63C 8A54 42D3 7173 1827 A6E3 769A 1BE3 82B7 89D1"
INCREMENT pwrautoplace mgcld 2019.060 30-sep-2019 1 1E6D107B768F735D4E78 \
VENDOR_STRING=FA8461B1 SN=63937912 SIGN2="007A 9B12 680F 020B C209 \
84E5 15F7 61BF 3B01 45B5 57C0 18FE F6D6 61D7 C084 0962 1148 046B FC59 \
3434 E3A3 8256 082A 597E D2C8 F0DD 4BB2 FA16 F068 1702"
INCREMENT pwrcam mgcld 2007.060 30-sep-2019 1 7E2C4D311313A7F10617 \
VENDOR_STRING=D5467630 SN=63356479 SIGN2="035E 4124 EDE3 1920 A0B3 \
7080 FB11 AB27 A537 83D4 09A2 15B9 54CE 3B15 743B 0D6E 89BD 838F B289 \
A1A9 964B C72A 5978 5162 7AAE 4D89 6558 3530 8877 AA2E"
INCREMENT pwrcam mgcld 2019.060 30-sep-2019 1 2E7D106B00922924FD0B \
VENDOR_STRING=D25C59AD SN=63937909 SIGN2="094C E418 6C87 3C3B 0306 \
0DD0 7D8B 793E 50FB 141C 9517 CC82 18DF C4ED 2A0B 1B64 AAF1 862F 2629 \
30D3 65E1 6922 2936 54D9 2369 101A 560E D631 A73A 8D1B"
INCREMENT pwrcam350 mgcld 2007.060 30-sep-2019 1 4E0CCD91CDC69B92EEB5 \
VENDOR_STRING=C25A1B8C SN=63356495 SIGN2="0628 D9CC 00A5 DC42 4A20 \
22C1 0132 DC13 1A8C B8D8 DA62 9CF1 C130 7EB2 D680 0983 8DFC A524 2BCB \
33B3 071E DEAF 7D0B 15D1 558B 214D B750 01C5 A856 17DD"
INCREMENT pwrcam350 mgcld 2019.060 30-sep-2019 1 9EBD30FB759167F63978 \
VENDOR_STRING=F656701A SN=63937895 SIGN2="0268 3B89 AC07 9FC2 6654 \
D6F3 DBF6 460F FE00 2312 D41E 555F 642D BA25 67E4 0849 80E8 A311 29E5 \
8541 AF1B B2B8 0B12 9B02 3127 EF4A BC5D 1F99 BECC 3C3B"
INCREMENT pwrcamplus mgcld 2007.060 30-sep-2019 1 2EFC5DD10719EAEDB7EC \
VENDOR_STRING=A6B31465 SN=63356454 SIGN2="13E5 7BEC 7CD9 A00D 5889 \
F077 9660 8E9F 7131 C0AC 5795 13B5 0CA6 7649 0A13 0688 AF3E 5338 F1A8 \
D8F1 6BDF 5479 555E 8936 55B5 06D8 A97F AB85 62FC 25F2"
INCREMENT pwrcamplus mgcld 2019.060 30-sep-2019 1 BE9DA0FBD1D8CA2AFC53 \
VENDOR_STRING=23BCF100 SN=63937901 SIGN2="1D42 009D 5284 1CC2 C328 \
3DA9 7389 8807 A4E5 F091 C1E4 B65D 66A3 02BC 82E8 13E6 D9D3 1DE5 5D18 \
1EAB 4216 8F25 52CE 8CD3 B287 6765 A6A6 718C B7B2 51F4"
INCREMENT pwrcopperflood mgcld 2007.060 30-sep-2019 1 DE8CFDC1C70ECEBD00C2 \
VENDOR_STRING=F24D454A SN=63356484 SIGN2="1966 D899 A1F0 F794 65ED \
0707 36FC 4024 F390 88EC 974C 1856 0E95 DAF7 A218 0DDE 3A19 7B5D AFFF \
963B E9C2 71F9 9AA2 BB6D BF72 B2DB C65D CB52 8DF2 7F3F"
INCREMENT pwrcopperflood mgcld 2019.060 30-sep-2019 1 FEEDC06B359FCD0E3249 \
VENDOR_STRING=76762C12 SN=63937923 SIGN2="08E8 7736 5A84 E32D FE70 \
E68D 0FE4 0022 7355 B66C EDC7 2BA9 BD40 0ACB 2AD4 06F9 9F46 0BF8 6655 \
0E51 B077 81A8 3C30 1853 0977 017C AEEC 1AA3 637E C924"
INCREMENT pwrdbexp mgcld 2007.060 30-sep-2019 1 6E4C9D411E257A099B03 \
VENDOR_STRING=A11C5420 SN=63356462 SIGN2="1618 45D1 9740 93AD DF7B \
4EAC 744E AA8B DF23 3194 93BD 92EA 3CD8 A14B FB3B 0709 6EE4 425E 5B0B \
A490 F66F 894F 7694 1080 73A6 AD02 D69D 77E5 58F7 5089"
INCREMENT pwrdbexp mgcld 2019.060 30-sep-2019 2 8EDCBDD114EFF08B39E9 \
VENDOR_STRING=0A111DC8 SN=63356461 SIGN2="05F9 D85F 14AD 837E F2F1 \
B1D1 D4C5 B53D EB8D 768A FFD9 4929 C5CE D231 3E8C 02DD 838C 3C2A 3208 \
870A 9F10 4030 342D 63E7 B389 CA71 AB3A 79C0 37AB 686C"
INCREMENT pwrdbexp mgcld 2019.060 30-sep-2019 1 7E5D40DB666B863F2C6C \
VENDOR_STRING=E5D1B776 SN=63937907 SIGN2="1BBA CDF6 E3AC 883A 5092 \
1477 CBAB 1E69 D36A B4E5 ABD6 5FD0 9FFD B41D 1B47 06CE ECD5 5DFF 9FEB \
CE99 C628 A554 8370 828F 3FAF 2B68 2BC4 CC46 F6D1 8D52"
INCREMENT pwrdbstd mgcld 2007.060 30-sep-2019 1 CE9C4D61B73CBD35A53B \
VENDOR_STRING=CECD1821 SN=63356469 SIGN2="1C1E 1375 51B1 BC09 057F \
985F 26E3 78AD AB7E 5BBD 95B7 9A64 4D0A 7733 9E6D 1A09 EA42 2702 1E6B \
474A 6DA2 414D 75E7 CFBC 21C0 629A BDEC DC41 5B04 B823"
INCREMENT pwrdrafting mgcld 2007.060 30-sep-2019 1 DE9C1D01C8043EA865E8 \
VENDOR_STRING=1F08FB49 SN=63356490 SIGN2="1E29 C074 F8F9 0636 B509 \
E4D5 6943 1C4D 3375 F174 F2C4 21A3 3F70 F968 B13A 1A80 213C 1CD1 97C3 \
892C DA8E EE7F DA6D 6003 2018 9C3E E746 7137 7F01 F66D"
INCREMENT pwrdrafting mgcld 2019.060 30-sep-2019 1 FE1D00BB6442B822B34B \
VENDOR_STRING=63AE034B SN=63937917 SIGN2="14A1 AEBD 6E1A AA6A D950 \
B63A 3496 E817 E8D3 030D 600D 97BA 7D0B F022 E878 1BDE 50CF FD4D D984 \
1AF5 2CB4 D74B 6E73 12FA 6B17 B5AA 054A 71B4 A8F8 E040"
INCREMENT pwrdre mgcld 2019.060 30-sep-2019 3 4E3CBDF19F20D3A074BC \
VENDOR_STRING=70F42217 SN=63356486 SIGN2="112F 515B 4186 2EF5 54F9 \
B10F 9307 252C 556F 8B99 901F 2EEC 5562 543B B4C8 0FE8 8C34 52E5 5D2E \
021D 2ED6 612A 0087 C878 9011 8B7F 14A2 8A62 F009 518A"
INCREMENT pwrdre mgcld 2019.060 30-sep-2019 1 FE4DA06BFC7247850177 \
VENDOR_STRING=1FEE82DD SN=63937902 SIGN2="0085 0589 EF33 C8CA 7743 \
0BAF 1CB0 0F39 57F3 A656 5788 4D71 94A2 9F6D 4E67 1788 3791 2D47 5AFD \
6EC5 69A4 34BE 15B5 7140 7FB1 BE60 8823 CD7D 3162 0488"
INCREMENT pwrdxf mgcld 2007.060 30-sep-2019 1 2E6CBD91FFA00390C524 \
VENDOR_STRING=AE7A758E SN=63356481 SIGN2="1F82 5E4A FDA1 0B46 28CD \
AF64 04C4 F181 4157 6E9C 0D3D 9F63 E919 049E F81B 0403 5DF7 C43C 0CFE \
616A 9DAE 4919 E62C E402 A7C5 2B28 C018 F72F 052C 5697"
INCREMENT pwrdxf mgcld 2019.060 30-sep-2019 1 8E5DD03B0431A592B292 \
VENDOR_STRING=265FB362 SN=63937925 SIGN2="02DD B0D9 DA26 CC5D AD90 \
3F55 8C9B 44AC DFE9 42FC F5C1 5114 D435 08E3 64E6 15B4 8D64 6A99 1DEB \
057F 6D49 0913 2550 1601 C753 7D22 2489 1704 3A29 2C60"
INCREMENT pwreco mgcld 2007.060 30-sep-2019 1 DEFC7DA105A7F65B3DD9 \
VENDOR_STRING=8523136A SN=63356471 SIGN2="0BF9 49BD 28A0 AB95 9410 \
94AA 1FDB C3D0 CE96 5630 B082 3FE6 8B89 D22C 3D30 014C 94C2 ADBD 43AA \
7E3C DC13 E32B E361 8A5B 5020 B392 C0E4 C37D CB55 A4D9"
INCREMENT pwreco mgcld 2019.060 30-sep-2019 1 4E0D305BBF89BEF97C70 \
VENDOR_STRING=A3690176 SN=63937913 SIGN2="002D 0B75 8D0A 10AC B5C5 \
A7FE CADE 4804 7AFE E2F8 DFD0 1CD9 B62E E98C F223 03D4 B932 27E2 967F \
012F 729C 3AAE 0D9B A550 A7DD 7B8E 8E50 3DA1 2CAD 59E0"
INCREMENT pwrgenedit mgcld 2007.060 30-sep-2019 1 DEFC2DA1D59743DF44FF \
VENDOR_STRING=FDC3C89B SN=63356504 SIGN2="0B9C AEFA 4CF4 DDE6 3FB5 \
2FD7 0BF2 CAFD 9E54 8A9A 1D72 6E3C 7CA0 D1D8 997E 18F3 CDAB 046C 28BC \
47A3 7848 66FB E85B AE2A 4A69 3AE2 99C1 8743 8361 E6CB"
INCREMENT pwrgenedit mgcld 2019.060 30-sep-2019 1 4E4D008B03D3B93D9F95 \
VENDOR_STRING=9A44F197 SN=63937906 SIGN2="0D26 8B5B 28CA 0D19 7719 \
9A51 7663 95C2 E111 7ACF 4E1B 9D3F C8E6 B849 EFB9 15F7 F200 0FFD 2E92 \
8740 EFA2 DB3B 336F DBCE 2B0F 8F59 CA7F 2353 9042 B1A9"
INCREMENT pwrlibedit mgcld 2007.060 30-sep-2019 1 2E8CBDB18B955983750A \
VENDOR_STRING=76132A84 SN=63356515 SIGN2="1A30 4DF6 1AF5 E74E 3833 \
9F9C 2485 945C E1C0 F4E8 AEC7 377B 2F31 BCD8 7099 17B1 644F 8760 5626 \
7F3C E02F 130C CEEE 1DEE B059 0E4D 3052 4146 19DC 69B6"
INCREMENT pwrlibedit mgcld 2019.060 30-sep-2019 1 6E1D301BA142C4DCCF1A \
VENDOR_STRING=28017812 SN=63937894 SIGN2="03BA 210D A19B EEDC 95F4 \
D219 67F6 BA64 0926 9A5D 75FC E6FF 784A 29E1 3957 0C54 CC0F D670 FC1C \
F3BA 01E1 4533 F90B F2B5 67FB F3BB EBD6 450D F7F4 35ED"
INCREMENT pwrpdf mgcld 2019.060 30-sep-2019 1 AE3D106BD338C0863D5D \
VENDOR_STRING=AEFA9D8F SN=63937918 SIGN2="0A0D 12D7 5809 EB81 5C53 \
EEB7 4588 F6FE AA29 9A2C 04DD 8639 FF3F A92F 8DC8 0CD0 EFCE 0B39 F154 \
798F F180 9890 C31A 64ED DB9C CD79 C382 4DE8 F9B5 CF5C"
INCREMENT pwrradialplace mgcld 2007.060 30-sep-2019 1 1E4C9D0180324E1BA201 \
VENDOR_STRING=EC01CA55 SN=63356451 SIGN2="1AE0 1F55 9CFB 87CB C668 \
C8BE CDB1 8C35 2F76 27E2 6F74 4FBE 0F46 5BD9 9955 1796 0349 C0A2 8ABE \
B52C A005 1DCF 0C37 6F32 2EEA 1AC7 3CCB 9549 7D36 A7DB"
INCREMENT pwrradialplace mgcld 2019.060 30-sep-2019 1 EE7D005BA7EB4E36575D \
VENDOR_STRING=D5FFF7E2 SN=63937903 SIGN2="1FE9 C41C E473 11FE CF04 \
48F1 8309 F0B1 5E65 E541 88CD BC9F ED09 876D 8E16 10E4 6FBE 1589 FA61 \
1121 1C55 6170 F1C1 BD81 DB2B 7EE0 2C48 8C07 7480 F219"
INCREMENT pwrshell mgcld 2007.060 30-sep-2019 1 6E2CFD31F25795EEFFC2 \
VENDOR_STRING=1F00773A SN=63356525 SIGN2="01BC 5D05 1367 2582 6FD4 \
AE20 BAF9 3291 4D07 86C0 F06F 8689 E1E6 056D D134 0E83 A223 697C EE4D \
946A 9DD7 3FE0 8F6B CF20 9556 6B70 FBEE 7B2D 3CC0 63C5"
INCREMENT pwrshell mgcld 2019.060 30-sep-2019 1 4E6D408B2AABFBBC9307 \
VENDOR_STRING=F9BA27A0 SN=63937908 SIGN2="14C6 9BCD 2C30 C122 E359 \
E518 8B90 7050 ACA3 FAE6 0F41 92F9 3B5F BE05 7EF0 1793 436E CDDF C963 \
7D95 4E3D 7222 68CA 5128 316A 835C EA1A 79F3 4C9D 9023"
INCREMENT pwrspecctralink mgcld 2007.060 30-sep-2019 1 \
DEBCAD815D62DF33A29C VENDOR_STRING=5EA37968 SN=63356502 SIGN2="12B3 \
A418 12A3 3A6F F9A5 3406 82C1 A34A 208F B40B 7A45 D386 9845 CDA7 0731 \
09EE 7BB3 9B53 4998 1447 80E3 3C69 B3A3 CDFC F6D1 CDD3 CFF8 464D 8B00 \
2C23"
INCREMENT pwrspecctralink mgcld 2019.060 30-sep-2019 1 \
8ECD709B4643A18F3C6E VENDOR_STRING=9A497D41 SN=63937922 SIGN2="0FD6 \
C2AD EA53 20B7 56EB E128 6FBA 4F47 FA5F 5165 45FE 2784 D7EC C08D B50E \
0450 32A1 0A1B 8338 7B59 BEAB 1346 6916 1702 8C03 3FA0 05DB 0C50 754F \
B42D"
INCREMENT pwrsplitplanes mgcld 2007.060 30-sep-2019 3 0E9CED71389EDEED6BA6 \
VENDOR_STRING=0388BED0 SN=63356509 SIGN2="1925 B0A8 D0BD 1A01 5BDE \
4092 6627 30BD 6891 2BE8 8A6C BD9A C317 3890 F689 106A 207E 571B 3672 \
E011 DE4B 79BA E6EC 1BB1 A8F0 9699 935F 8123 F479 D525"
INCREMENT pwrsplitplanes mgcld 2019.060 30-sep-2019 2 0EEC3DF19FE7AB4747FE \
VENDOR_STRING=ED721E4C SN=63356510 SIGN2="169D 73D1 0CA9 24FC 975D \
5338 3BEB 0449 7C9B 545A 8708 675B 327D CFB7 0ABC 1D9D 5491 14DB 8B3F \
8A8A 2ADA 33C3 08F8 C822 D901 1FB9 E150 E9F9 794E 2F2C"
INCREMENT pwrsplitplanes mgcld 2019.060 30-sep-2019 1 EE5DD0BBD99761668744 \
VENDOR_STRING=D22C18BC SN=63937921 SIGN2="16DB 7F6D 8AE4 D508 F117 \
8CA0 CDBE E4F0 98E8 E6AC 7FD8 5DBB DFDC 2866 522B 099B 0A3A 1232 6F34 \
68D9 9A78 B006 0E86 ADB6 8C24 859E F771 D47E 4D0D FD1E"
INCREMENT pwrvariants mgcld 2019.060 30-sep-2019 1 DE4CED91E99146C835C0 \
VENDOR_STRING=E645F722 SN=63356449 SIGN2="1AF6 425B 5B82 E6B3 7D21 \
A9B2 2C0F C21E 7107 8A0C B2BD 5369 8C4B DE31 2EDD 0E73 90DB A053 A928 \
240E 1738 DD95 C71D 2A4C 3157 A4D1 BC90 F7CA 9A7A 9BE4"
INCREMENT pwrverify mgcld 2007.060 30-sep-2019 1 EE6CBDD1655528306B2E \
VENDOR_STRING=278FD7B3 SN=63356522 SIGN2="1A01 E6CE 0308 75A6 7B2D \
0AB0 643D C4B7 2AB3 2439 DC9E 2C57 4741 D07D FD5A 0398 4881 D514 6659 \
EB7A 46B4 27AA AD30 EAF6 1EF2 30FB 7979 89F3 92A4 E5E4"
INCREMENT pwrverify mgcld 2019.060 30-sep-2019 1 5E2D008BD69D747D2F7F \
VENDOR_STRING=FAE96464 SN=63937911 SIGN2="0414 6981 6056 A054 717E \
A9DC 910F 3386 B305 EB73 BA50 5524 DBC3 C6ED 5B7E 0DB3 4E50 76EE 7804 \
B497 09D2 CBBF 6B8D 6E5E D61A 307C CCFE D57A A472 6AA3"
INCREMENT spiceint mgcld 2019.060 30-sep-2019 1 BEFD703BEAE6D994EB60 \
VENDOR_STRING=6A31561A SN=63914510 SIGN2="1A9E 09C4 A27A CFEF AFAA \
39CF B953 3FCC 27BF DCE9 84D8 FB74 9401 898E 0D2E 1088 7DFA D913 D734 \
33AE 1302 BD36 E2B9 EA07 AAC8 2442 5343 9115 A224 8186"
INCREMENT spiceint mgcld 2019.060 30-sep-2019 1 BEFD703BF0E6D993EB5B \
VENDOR_STRING=6A31561A SN=63914526 SIGN2="0FD9 2F2D E88E F22D 4BF1 \
3483 1A12 8F5D 4280 6CE8 A6B8 71AD 80D5 114B E58E 00B5 CEC6 B9E1 A68D \
1A4F 7A49 B538 915D 6C56 C2D3 AAFA 75E7 AC22 A80C 33EB"
INCREMENT spiceint mgcld 2019.060 30-sep-2019 1 CE1D701BE8E0D88FE766 \
VENDOR_STRING=6A31561A SN=63937870 SIGN2="176A 61B2 54FF 00F6 95C5 \
38F3 24E7 33FB 062F 081F 2F3B 3793 390C 153B 50FB 0836 9148 24F0 72B6 \
6A26 3C5F E0A6 B608 F8B3 4A68 1D4A CE8D 91C3 A254 02B4"
INCREMENT visedatapads mgcld 2019.060 30-sep-2019 1 7ECD304B89197673325D \
VENDOR_STRING=25319A01 SN=63914519 SIGN2="08C2 4733 AC51 9084 A2C5 \
A348 CCAC DF75 E375 E3C0 E6E3 49AC 0DAF 5ED8 C6EA 01C2 571A A13B 0CAE \
B8E9 7C0E 3C6C 3F41 CECE 474B 02C6 B560 5AB7 537F 772B"
INCREMENT visedatapads mgcld 2019.060 30-sep-2019 1 7ECD306B891B8267325D \
VENDOR_STRING=25319A01 SN=63914535 SIGN2="17B1 EAFF 3C3C 480A AC5E \
1DAB 87E0 4F68 A35D 3090 BD93 A27A DFF2 0D70 1CD6 0BF3 3D53 3D46 1DA5 \
CF30 0491 781A F2CF B208 EC9F BA18 4D2A D253 A2FA 6E63"
INCREMENT visedatapads mgcld 2019.060 30-sep-2019 1 8E7D30DB801F7A72325B \
VENDOR_STRING=25319A01 SN=63937878 SIGN2="0721 6686 13F0 108F 4695 \
D485 4838 E0D7 8508 A7ED 6222 2751 BB20 14F0 C1CD 07EB 5186 A89C B225 \
9A07 2F5C 0AF7 ABD9 0EEE A150 3113 DED6 4668 464F 6BCD"
# ----- REMOVE LINES ABOVE HERE --------------------------
#SERVER mint1 2C56DC725238 2100
USE_SERVER
VENDOR xilinxd C:\MentorGraphics\Licensing\xilinxd.exe port=2222
# This is a permanent license generated on Mon Jan 21 04:01:44 UTC 2019
INCREMENT ten_gig_eth_mac xilinxd 2019.12 permanent 9999 8C95036DC8CC \
VENDOR_STRING=License_Type:Bought;jquinsaat,ten_gig_eth_mac,ip,permanent,_210674821_1777531991_210696076_663 \
ISSUER="Xilinx Inc" NOTICE="The license for this core was \
generated for jquinsaat on 01/22/2019It is the responsibility \
of the Licensee of this core to adhere to all terms and \
conditions of the applicable license agreement when using this \
core." START=21-Jan-2019 TS_OK
# Licenses for ten_gig_eth_mac_v3_0
FEATURE ten_gig_eth_mac_v3_0 xilinxd 1.0 permanent 9999 D61E48C3EC8A \
VENDOR_STRING=License_Type:Bought ISSUER=Xilinx NOTICE="The \
license for this core was generated for jquinsaat on \
01/22/2019It is the responsibility of the Licensee of this \
core to adhere to all terms and conditions of the applicable \
license agreement when using this core." TS_OK
# Licenses for ten_gig_eth_mac_v6
FEATURE ten_gig_eth_mac_v6 xilinxd 1.0 permanent 9999 817D5AB29AC1 \
# Licenses for ten_gig_eth_mac_v7
FEATURE ten_gig_eth_mac_v7 xilinxd 1.0 permanent 9999 41EE1C8FAE57 \
# Licenses for ten_gig_eth_mac_v9
FEATURE ten_gig_eth_mac_v9 xilinxd 1.0 permanent 9999 67524CD126B3 \
# Licenses for ten_gig_eth_mac_v8
FEATURE ten_gig_eth_mac_v8 xilinxd 1.0 permanent 9999 8A4682CCD2F5 \
# Licenses for ten_gig_eth_mac_v4_0
FEATURE ten_gig_eth_mac_v4_0 xilinxd 1.0 permanent 9999 AE165238F418 \
# Licenses for ten_gig_eth_mac_v5_0
FEATURE ten_gig_eth_mac_v5_0 xilinxd 1.0 permanent 9999 670C08DDA896 \
INCREMENT xxv_eth_mac_pcs xilinxd 2019.12 permanent 9999 FFEB55B7939B \
VENDOR_STRING=License_Type:Bought;jquinsaat,xxv_eth_mac_pcs,ip,permanent,_210674821_1777531991_210696076_905 \
INCREMENT xxv_mac_pcs xilinxd 2019.12 permanent 9999 3B0DD289D8FD \
VENDOR_STRING=License_Type:Bought;jquinsaat,xxv_mac_pcs,ip,permanent,_210674821_1777531991_210696076_761 \
INCREMENT x_eth_mac xilinxd 2019.12 permanent 9999 B0479D838E65 \
VENDOR_STRING=License_Type:Bought;jquinsaat,x_eth_mac,ip,permanent,_210674821_1777531991_210696076_641 \
# ----- REMOVE LINES BELOW HERE --------------------------
I also changed the port in the XILINXD_LICENSE_FILE path from port 2100 to port 1717, per what mgld deamon is using (and since we merged license files). With the above Xilinxd start up and this port change, the 10GbE core lic is visible to my client Vivado session. (Note that the 10GbE core was not visible when we tried with port set to 2100, our original intent).
However, the re appears to be an issue with the PCS/PMA, when I run Vivado's Reports-IP Status, which shows the PCS/PMA is still not visible.
However, running the Vivado Lic Manager tool, that shows the following, note the last two entries:
So it appears the PCS/PMA still has an issue (following shows the Reports-IP Status window in Vivado)?
Appreciate any guidance you can provide here.
Thanks again.
02-01-2019 02:02 AM
Hello eskull@0,
First of all, please note that you need to run your Xilinx related licenses separately to your other vendors, like MentorGraphics.
Therefore, please separate these and then separately run lmgrd+mgcld for Mentor Graphics license and separately, lmgrd+xilinxd - for Xilinx related license file.
Also, please note that you can't have 2 xilinxd servers running on the same server. Therefore, if you have 2 or more floating Xilinx related licenses, these must be merged together into 1 file and then start a single floating license server with lmgrd+xilinxd v11.14.
Before you can actually merge these together, your Xilinx floating licenses must be generated for the exact same server name and the Host ID. If so, then copy and paste these together, and then comment out the 3 server licenses that are duplicate, as you only meant to have 1 set of these SERVER, USE_SERVER and VENDOR lines in a single Floating license file, and any other copies of these 3 lines must be comment out.
Secondary, the IP in your case that you are using is the Xilinx 10 Gigabit Ethernet PCS/PMA (10GBASE-R/KR):
This IP requires a licensing feature called "ten_gig_eth_pcs_pma_basekr" and that is what you are missing. Design_Linking type of a license won't let you to generate bitstreams. Therefore you are also need to have a license that contains this "ten_gig_eth_pcs_pma_basekr" licensing feature in it.
02-01-2019 02:41 PM
Thanks very much for the helpful info.
I searched the Xilinx Product Licensing page for ten_gig_eth_pcs_pma_basekr (no hits), then just pcs, and the following core lic option was listed, LogiCORE, 10 Gigabit Ethernet PCS/PMA, No Charge License. Since my Vivado lic is node-locked, I opted to download that license file.
After downloading, used the Vivado License Manager GUI, to Load License. This resulted in the following core to appear in the Lic Man Lic Status GUI: Restarted Vivado and loaded the project. Running Reports-IP Status still shows the PCS/PMA is not licensed.
Does it matter whether the PCS/PMA was added as node-locked? Since it appears in the License Manager, I have no clue as to why the project still doesn't recognize. Unless the core I licensed is not the one that is required. What I licensed was the only one I could find on the Product Licensing page the is 10GbE PCS/PMA.
Would be helpful if you could confrim I installed the correct license.
Thank you again for you time and help.
02-04-2019 01:17 AM
Hello eskull@0,
"ten_gig_eth_pcs_pma_basekr" is what you are missing. Do you actually need BASE-KR option enabled in your design? If not, please disable it and you will be good to go then.
However, if you have this BASE-KR option enabled/selected (as shown below) for this IP Core, then just having "ten_gig_eth_pcs_pma" licensing feature isn't enough here, as this option requires an additional "ten_gig_eth_pcs_pma_basekr" feature and you don't have this right now. I don't think you can even obtain an evaluation license with "ten_gig_eth_pcs_pma_basekr" in it;therefore for the evaluation purposes of this IP Core, please note that you'd need to use/select BASE-R instead of BASE-KR (as shown below). Otherwise, you'd need a purchased license for this BASE-KR IP feature.
02-08-2019 07:49 AM
Hello eskull@0,
Were you able to sort out this licensing issue by now or are you still seeing problems? Can you confirm on this please?
However if your licensing issue is resolved now, please mark a response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then.
We appreciate your help.
