Not able to install Vivado 2014.2 after downloading from web.
I am not able to install Vivado 2014.2 after downloading from web. I was able to install it from the DVD but it is an older version 2013.3. I want to update vivado but I am not able to do it. Please Help. I see following error. I have attached the log file also.
Re: Not able to install Vivado 2014.2 after downloading from web.
Are you using thin web client for installing the tool or you are downloading the complete package and installing it?
If you had downloaded the complete package and installing it, then please verify the md5sum value of the dowloaded file with website value.
Which version of 7-zip are you using?
Vinay
Also check the below AR’S which may help debug this issue.
http://www.xilinx.com/support/answers/60155.html
http://www.xilinx.com/support/answers/60410.html
http://www.xilinx.com/support/answers/60749.html
http://www.xilinx.com/support/answers/60122.html
I tried using both both of them fail the same way.
I am using 9.20 version of 7-zip.
kinshuk
Xilinx recommends the use of 7-zip or WinZip (v.15.0 or newer) to decompress the downloaded tar.gz file.
Try with new version of 7-zip and let us know if you still see the issue.
Deepika.
Deepika.
