Observer Anviori
Not able to start viviado - 'vivado.bat timeout'
Can't start the program. It was working yesterday and now it's not. asdf.png
Re: Not able to start viviado - 'vivado.bat timeout'
Hi @Anviori,
There is a known issue with VIvado 2017.3 and the Windows 10 Creators Update from Microsoft which may be case here.
This is documented in Answer Record 69908
https://www.xilinx.com/support/answers/69908.html
While this update for Windows 10 is not officially supported with Vivado 2017.3, the following work-around is available:
  1. Navigate to (Vivado Installed Directory)\2017.3\bin\unwrapped\win64.o
  2. Backup 'vivado.exe' by renaming it to 'vivado.exe.backup'
  3. Copy 'vivado-vg.exe' and paste it into the same folder.
  4. Rename 'vivado-vg - Copy.exe' to 'vivado.exe'
Let me know if this helps.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Hi @Anviori,
Can you open command prompt and then run vivado.bat? The Vivado.bat file should be in a similar path as: C:/Xilinx/Vivado/201x.x/bin/vivado.bat
Which OS are you using? Please check AR#57386 for debug.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
Observer Anviori
I tried running vivado.bat from the command prompt and it does not work.
I am using Windows 10; and I have already tried debugging from the link you provided, but it still keeps timing out.
I am using Vivado 2017.3
Hi @Anviori,
Best Regards
Aidan
Observer Anviori
It worked, thank you so much for your help!
Newbie shaun.lee56
I tried to make the changes to the file names but the same problem still exits.
Any other possible solutions?
Hello @shaun.lee56,
Just to double check with you, on this Windows 10 machine where you see this issue, do you have Vivado_init.tcl specified in either the software installation, i.e.: <installdir>/Vivado/version/scripts/Vivado_init.tcl (Where <installdir> is the installation directory where the Vivado Design Suite is installed), or in the local user directory, i.e.: %APPDATA%/Xilinx/Vivado/<VivadoVersion>/Vivado_init.tcl?
Can you confirm on this please? Thanks
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Newbie shaun.lee56
Hi Anatoli
Thanks for the prompt reply. It just worked suddenly. Thanks again!
Thanks for letting us know @shaun.lee56. Perhaps the changes that you've applied somehow didn't get detected for some reason? Anyhow, I'm glad to hear your issue is sorted now.
Have a lovely evening.
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Newbie namnesh
Hello sir !
I have been facing the same problem. i have worked on the changing the name and extension of vivado.exe to vivado.exe.backup but now facing launcher time out. and viavdo_init folder/file is not there in the design Suit directory
Vivado version 2017.1
Windows 10 latest update
Hello @namnesh,
Can you please confirm that after you've backup-ed  'vivado.exe' by renaming it to 'vivado.exe.backup' (i.e. step #2 below), you've then performed steps #3 and 4 as given below? This is necessary to be applied as indicated below, as otherwise you'd normally see a "Launcher time out issue". Can you confirm on this please? Thanks
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Newbie namnesh
hello sir!
I have performed all the steps listed . Still it shows the same error , yet  if i try to launch the new vivado.exe from the main folder
error displayed is
Newbie nambi
Thank you! it's help me,
now it works!!!
Thanks Aidan, It works for me. After the exe file rename we need to restart the system .
