Partial Reconfiguration not supported
PR Partial Reconfiguration license is not installed on the plan ahead local server but integrated in the Xilinx ISE Design Suite license, but the problem is when we use planahead to create a new project,  it does not contain the PR option as it seems that the local license does not support partial reconfiguration despite there is an option in the license as below:
#MAIN
INCREMENT PartialReconfiguration xilinxd 2018.12 10-jun-2018 \
uncounted 6FD2CA7CB467 \
VENDOR_STRING=rs,PartialReconfiguration,software,permanent,_123456789_123456_123456789 \
HOSTID=ANY ISSUER="Xilinx Inc" START=01-Oct-2010 TS_OK
INCREMENT System_Edition xilinxd 2025.01 permanent uncounted \
6C8EE4B2A5BE \
VENDOR_STRING=something@my.door,System_Edition,software,permanent,_0_0_0 \
Has someone any problem with PR support license settings?
Hi @mini_ds,
Please check this link:
https://www.xilinx.com/support/answers/35616.html
regards,
Raj.
thanks very much for your guidance, Raj.
partial reconfig bug  repaired.
Hello @mini_ds,
Thanks a lot for letting us know and we are glad to see your issue is resolved now.
As your issue is solved, please mark an appropriate response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so  the topic can be completed then. We appreciate your help.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
