Visitor vganesh218
Process MAP error
hey all!!!
Am unable to overcome the below mentioned problem.. I have Xc6vlx240T Virtex-6 board and also Full version license has been generated and installed. Still I get the below mentioned problem.. I have Copied and pasted the ERROR ..
Please help me out..
Thank u!!
Started : "Map".
Running map...
Command Line: map -intstyle ise -p xc6vlx240t-ff1156-3 -w -logic_opt off -ol high -t 1 -xt 0 -register_duplication off -r 4 -global_opt off -mt off -ir off -pr off -lc off -power off -o singlebitadder_map.ncd singlebitadder.ngd singlebitadder.pcf
Using target part "6vlx240tff1156-3".
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
INFO:Security:56 - Part 'xc6vlx240t' is not a WebPack part.
INFO:Security:61 - The XILINXD_LICENSE_FILE environment variable is not set.
INFO:Security:63 - The LM_LICENSE_FILE environment variable is not set.
INFO:Security:68 - For more information or for assistance in obtaining
a license, please run the Xilinx License Configuration Manager
(xlcm or "Manage Xilinx Licenses".)
WARNING:Security:9b - No 'ISE' feature version 2011.10 was available for part
'xc6vlx240t'.
ERROR:Security:12 - No 'xc6vlx240t' feature version 2011.10 was available (-31),
so 'WebPack' may not be used.
No such feature exists.
Feature: ISE
License path:
C:/.Xilinx\Xilinx.lic;D:\Xilinx\13.3\ISE_DS\ISE\/data\*.lic;D:\Xilinx\13.3\ISE_D
S\ISE\/coregen/core_licenses\Xilinx.lic;D:\Xilinx\13.3\ISE_DS\ISE\/coregen/core_
licenses\XilinxFree.lic;D:\Xilinx\13.3\ISE_DS\EDK/data/core_licenses\Xilinx.lic;
FLEXnet Licensing error:-5,357. System Error: 2 ""
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".Feature start date is in the future.
Feature: xc6vlx240t
Start date: 19-Jun-2012
License path:
FLEXnet Licensing error:-31,392
ERROR:Map:258 - A problem was encountered attempting to get the license for this
architecture.
Design Summary
Number of errors : 1
Number of warnings : 0
Process "Map" failed
Re: Process MAP error
To be able to check what’s causing your problem, please attach a copy of your license file (.lic file) and your “Xinfo” text file?​​ To generate an Xinfo report (on Windows OS) just go to Start -> All Programs ->Xilinx ISE Design Suite 13.3 -> Accessories -> Xinfo System Checker and after you ran “Xinfo System Checker”,​ the Xinfo.txt report will be generated and saved in your C(Home Drive):\Xilinx\13.3\ISE_​DS\common folder,​​ as a text file (.txt). Let me know if you have any difficulties doing this.
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
hi,
       for example u have installed your software in C drive ,pls check whether ur lic file is within the .Xilinx folder which is automatically created during installation in the following drive if its an evaluation lic then u will get only 30 days to use the software , so pls check every constraints....
Best Regards
Chandrajit
Voyager
Voyager
Error message straight forwardly says : The tool is unable to get the license for the architecture you are targetting for.
        Please check the configuration ? Have you installed a permanent license ?
        Does /.Xilinx folder containing .lic file exsist ?
Visitor dinesh@p
I am using ISE 13.3 and Xc6vlx240T Virtex-6 board. I got the ISE WebPACK license file through mail and i have installed it. I got stuck up at the same error. Were you able solve it? if so how?
I have attached my license file and xinfo.txt. Please have a look and help me out!!!
Thank you!!
