RHEL5 64-bit ISE 13.1, PlanAhead launch from w/in ISE fails, terminal indicates rdiArgs.sh Segmentation Fault
I'm trying to launch PlanAhead from within ISE. I double click "Floorplan IO (PlanAhead)" and the Xilinx Console indicates:
"Started : "Floorplan Area/IO/Logic (PlanAhead)".
Preparing PlanAhead launch script...
PlanAhead started. PlanAhead output can be found in /home/peon/work/IRAD/GDL/ise_proj/watchvhd/planAhead_run_4/planAhead_run.log"
And an ISE dialog then asks me which of my UCF files to use, then tells me something about the ucf file is open in another editor and asks if i want to continue, to which I say yes. and then nothing happens. Planahead never launches. The folder referenced above is created, but is empty.
On the terminal from which I launched ISE, there is message:
"/opt/Xilinx/13.1/ISE_DS/PlanAhead/bin/rdiArgs.sh: line 64: 14275 Segmentation fault      $RDI_PROG $*"
The contents of rdiArgs.sh are:
#!/bin/sh
# COPYRIGHT NOTICE
# Copyright 1986-1999, 2001-2010 Xilinx, Inc. All Rights Reserved.
# Default to 32bit platform options
RDI_PLATFORM=lnx32
RDI_JAVA_PLATFORM=i386
#RDI_PLATFORM=lnx64
#RDI_JAVA_PLATFORM=amd64
RDI_ARGS=
while [ $# -gt 0 ]; do
  case "$1" in
    -m64)
      if [ "$RDI_OS_ARCH" == "64" ]; then
        RDI_PLATFORM=lnx64
      else
        echo "WARNING: 64bit architecture not detected. Defaulting to 32bit."
      fi
      shift
    -exec)
      # We don't create an RDI_EXE_COMMANDS function and just overload the RDI_PROG variable,
      # so additional debug options can be used with -exec.
      # For example:
      #  -dbg -gdb -exec foo
      # Will launch the debuggable foo executable in gdb.
      shift
      RDI_PROG=$1
      shift
      RDI_ARGS="$RDI_ARGS $1"
      shift
  esac
done
RDI_VERBOSE=False
RDI_DATADIR=$RDI_APPROOT
RDI_JAVAROOT=$RDI_APPROOT/tps/$RDI_PLATFORM/jre
if [ "$XIL_PA_NO_XILINX_OVERRIDE" != "1" ]; then
  if [ -d "`dirname $RDI_APPROOT`/ISE" ]; then
    XILINX=`dirname $RDI_APPROOT`/ISE
    export XILINX
  fi
fi
if [ -d "`dirname $RDI_APPROOT`/common" ]; then
  XILINX_COMMON_TOOLS=`dirname $RDI_APPROOT`/common
  export XILINX_COMMON_TOOLS
fi
RDI_EXEC_COMMANDS() {
  $RDI_PROG $*
  return
I have an open webcase for this problem. I've tried changing the first 2 lines to default to 64bit based on some other forum messages / googling. That didn't work. Line 64 is the 3rd to last line. It says $RDI_PROG $*.
Re: RHEL5 64-bit ISE 13.1, PlanAhead launch from w/in ISE fails, terminal indicates rdiArgs.sh Segmentation Fault
I'm guessing you are using REL 5.6.
We've recently discovered this segfault on REL 5.6 and are looking into it.
Currently, the workaround is to use the 32 bit version of the tools.
We are creating an Answer Record and will update it as we get more information.
The AR will not be available until tomorrow but will have the following title.
Article: 42078-13.1PlanAhead - /​​xilinx13.1/​ISE_​DS/​PlanAhead/​bin/​rdiArgs.sh: line 62: 14279 Segmentation fault  $RDI_​PROG $*
Newbie jling
How do you launch 32bit ISE?
John
Visitor cgl_ict
I meet the same problem, is there any solution?
Newbie jostbissel
I managed to get the 32 Bit Version of PlanAhead running if I edit "/opt/Xilinx/13.4/ISE_DS/PlanAhead/bin/loader" and comment the architecture detecting lines out as follows:
RDI_OS_ARCH=32
#case `uname -m` in
#  x86_64)
#    RDI_OS_ARCH=64
#esac
32 Bit ISE is simply started via "/opt/Xilinx/ISE_DS/ISE/bin/lin32/ise"
Cheers
Observer paul.mnt
I have the same issue on Ubuntu 13.04 and it doesn't work, even with 32bit. The error it prompts is the same.
/opt/Xilinx/14.5/ISE_DS/PlanAhead/bin/rdiArgs.sh: line 95: 31921 Segmentation fault      (core dumped) "$RDI_PROG" "$@"
I'm running several EDA tools on this machine and I would swithc to another OS at this point. ISE and the other Xilinx tool run correctly, but for PlanAhead
Observer adrianf0
I confirm to suffer the same issue on Ubuntu 13.04 (PalnAhead 14.5).
Installation of oracle-java-7, replacement of the libjvm.so file in the PlanAhead directories, switch to 32 bit version don't help. I would be grateful for solution, even if Ubuntu is not officially supported.
Newbie padudle
I also have the same problem on my Ubuntu 13.04 machine.  It occurs whether I run the 32 or 64 bit tools.
I think it is related to file permissions because if I run as root it works.
sudo su
source /opt/Xilinx/14.5/ISE_DS/settings32.sh
planAhead
The gui comes up properly.
Note: I had to reinstall xilinx.lic in the root account to allow PlanAhead to run as root.
Newbie ecezhang
I encountered the same problem using Vivado v2013.2. I believe it is a permission problem because using root to run vivado works.
Newbie ecezhang
Sorry, I forgot to mention that my OS is also Ubuntu 13.04 64-bit.
Observer adrianf0
The same problem occur with version 14.6 of the PlanAhead.
Debugging the issue I got to this point:
#0  x86_64_fallback_frame_state (fs=0x7fe1b5e63860, context=<optimized out>) at ../../../../src/lnx64/libgcc/../gcc/config/i386/linux-unwind.h:47
#1  uw_frame_state_for (fs=0x7fe1b5e63860, context=0x7fe1b5e639e0) at ../../../../src/lnx64/libgcc/../gcc/unwind-dw2.c:1145
#2  uw_frame_state_for (context=0x7fe1b5e639e0, fs=0x7fe1b5e63860) at ../../../../src/lnx64/libgcc/../gcc/unwind-dw2.c:1124
#3  0x00007fe1eb77bc9d in _Unwind_Backtrace (trace=0x7fe1eb2985f0, trace_argument=0x7fe1b5e63b10) at ../../../../src/lnx64/libgcc/../gcc/unwind.inc:290
#4  0x00007fe1eb298786 in backtrace () from /lib/x86_64-linux-gnu/libc.so.6
#5  0x00007fe1ec2808ea in HUTBackTrace::getTrace(stlp_std::basic_string<char, stlp_std::char_traits<char>, stlp_std::allocator<char> >&, unsigned long) ()
   from /opt/Xilinx/14.6/ISE_DS/PlanAhead/lib/lnx64.o/librdi_common.so
#6  0x00007fe1ec281292 in HUTBackTrace::printTrace(stlp_std::basic_ostream<char, stlp_std::char_traits<char> >&, unsigned long) () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/lib/lnx64.o/librdi_common.so
#7  0x00007fe1ec281a58 in HUTBackTrace::handler(int) () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/lib/lnx64.o/librdi_common.so
#8  0x00007fe1c859a749 in os::Linux::chained_handler(int, siginfo*, void*) () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/tps/lnx64/jre/lib/amd64/server/libjvm.so
#9  0x00007fe1c859efb7 in JVM_handle_linux_signal () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/tps/lnx64/jre/lib/amd64/server/libjvm.so
#10 <signal handler called>
#11 0x00007fe1b3246880 in ?? ()
#12 0x00007fe1eb556d92 in __nptl_deallocate_tsd () from /lib/x86_64-linux-gnu/libpthread.so.0
#13 0x00007fe1eb556f9c in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#14 0x00007fe1eb280e1d in clone () from /lib/x86_64-linux-gnu/libc.so.6
The problem seems to be cause by a function in entry 11, but unfortunately I don't have DEBUG SYMBOLS for PlanAhead. The solution which I found (and doesn't involve running the software with root privileges) requires to create a symbolic link in ....Xilinx/14.6/ISE_DS/PlanAhead/tps/lnx64/jre/lib/amd64/server/  :
libjvm.so -> /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so
What I noticed, it will work only with link to the OpenJDK. The same trick with java-7-oracle causes the known segmentation fault.
Visitor embmicro
Thank you! This worked great for me on Ubunu 13.04 64bit.
Worked for me too. Thanks! (Mint 15, 64bit)
Newbie harryrose
Thanks for that.  I can confirm this also works for Vivado on Ubuntu 13.04
I ran
mv /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/libjvm.so.old
ln -s /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/
Newbie mjpelmear
This also worked for me for Vivado 2013.4 on Ubuntu 13.10:
mv /opt/Xilinx/Vivado/2013.4/tps/lnx64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.4/tps/lnx64/jre/lib/amd64/server/libjvm.so.old
ln -s /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.4/tps/lnx64/jre/lib/amd64/server/
I can confirm that this workaround also works on the new Ubuntu 14.04 (64bit)
Hello @lukasfischer ,
Thanks for the information. It will help others too.
Yash
Newbie jfrkuska
Thank you.
confirmed to work under Fedora 19 x64
Visitor davidrogoff
Centos 7.1.1503, Vivado 2015.2 - Re: RHEL5 64-bit ISE 13.1, PlanAhead launch from w/in ISE fails, terminal indicates rdiArgs.sh Segmentation Fault
Hi all. I'm trying to install the webpack versions of ISE and Vivado a fresh install of Centos. It shouldn't matter, but this is running under VMWare Fusion 8.0.0 under OSX 10.11 GM RC on a late 2012 15" rMBP.
Installed vivado in new centos:
[admin@localhost ~]$ cat /etc/centos-release
CentOS Linux release 7.1.1503 (Core)
[admin@localhost ~]$ source ~/Desktop/centos_disk2/opt/Vivado/2015.2/settings64.sh
[admin@localhost ~]$ vivado
****** Vivado v2015.2 (64-bit)
**** SW Build 1266856 on Fri Jun 26 16:35:25 MDT 2015
**** IP Build 1264090 on Wed Jun 24 14:22:01 MDT 2015
** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
start_gui
/mnt/19ef3347-9ad4-4f14-a0ff-168463358fa6/opt/Vivado/2015.2/bin/loader: line 157: 84484 Segmentation fault (core dumped) "$RDI_PROG" "$@"
Tried change of library from webpage
https://forums.xilinx.com/t5/Installation-and-Licensing/RHEL5-64-bit-ISE-13-1-PlanAhead-launch-from-w-in-ISE-fails/m-p/337289#M4680
Note: Just before installing vivado, I had installed ise 14.7-64 and it worked fine.
Change link for libjvm.so as shown on webpage with paths updated for my system:
Try running vivado again:
start_gui
ERROR: [Common 17-70] Application Exception: JVM: Can't create JVM - ErrorCode: -3
ERROR: [Common 17-211] Error loading jvm.
Vivado% exit
exit
INFO: [Common 17-206] Exiting Vivado at Sun Sep 13 17:39:14 2015...
Now what? This is beyond my Linux system knowledge.
Thanks!
 David
Visitor davidrogoff
Re: Centos 7.1.1503, Vivado 2015.2 - Re: RHEL5 64-bit ISE 13.1, PlanAhead launch from w/in ISE fails, terminal indicates rdiArgs.sh Segmentation Fault
oops - for some reason, the lines where I showed the links I made are missing. Here they are:
[admin@localhost ~]$ ls -lAFGH ~/Desktop/centos_disk2/opt/Vivado/2015.2/tps/lnx64/jre/lib/amd64/server/
total 16132
lrwxrwxrwx. 1 root 13 Sep 12 22:22 libjsig.so -> ../libjsig.so*
lrwxrwxrwx. 1 root 13 Sep 13 15:53 libjvm.so -> libjvm.so.old*
-rwxr-xr-x. 1 root 16506882 Jun 26 15:37 libjvm.so.old*
lrwxrwxrwx. 1 root 92 Sep 13 15:51 libvjm.so.1.7.0 -> /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.75-2.5.4.2.el7_0.x86_64/jre/lib/amd64/server/libjvm.so*
-rw-r--r--. 1 root 1423 Jun 26 15:37 Xusage.txt
[admin@localhost ~]$ sudo rm ~/Desktop/centos_disk2/opt/Vivado/2015.2/tps/lnx64/jre/lib/amd64/server/libjvm.so
[admin@localhost ~]$ sudo ln -s ~/Desktop/centos_disk2/opt/Vivado/2015.2/tps/lnx64/jre/lib/amd64/server/libvjm.so.1.7.0 ~/Desktop/centos_disk2/opt/Vivado/2015.2/tps/lnx64/jre/lib/amd64/server/libjvm.so
[admin@localhost ~]$ ls -lAFGH ~/Desktop/centos_disk2/opt/Vivado/2015.2/tps/lnx64/jre/lib/amd64/server/total 16136
lrwxrwxrwx. 1 root 97 Sep 13 17:37 libjvm.so -> /home/admin/Desktop/centos_disk2/opt/Vivado/2015.2/tps/lnx64/jre/lib/amd64/server/libvjm.so.1.7.0*
