Re-host IDE license when version limit expired
How to transfer IDE Design Suite 13.4 (node locked license with ML-605 board) to the new PC after version limit (2018.10) expiration?
Currently license is paired with HDD serial number and this license is not listed in web account under "Manage Licenses".
With regards
Krzysztof Zurek
anatoli
Hello @krzysztofzurek2017,
You can re-host your license even if/when you'd get your version limit of your license expired. See this Answer Record for more info: https://www.xilinx.com/support/answers/36136.html
If you don't see it under your www.xilinx.com/getlicenses account (under the Manage Licenses tab), then this would indicate to me that you weren't the one who has generated this license in the first place.
Please open your license file and under the "VENDOR_STRING=" section, here you can see a user's User Name or email address who has actually generated this in the first place. This person could then re-host this license for your new PC.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
