Re: unattended uninstall
I'm getting a Java error:
C:\TEMP\Vivado_2015.4\bin>C:\TEMP\Vivado_2015.4\bin\xsetup.bat -b Uninstall
Copyright (c) 1986-2016 Xilinx, Inc.  All rights reserved.
INFO : Log file location - C:\Users\Administrateur\.Xilinx\xinstall\xinstall_145
4100108207.log
Exception in thread "main" java.lang.NullPointerException
        at com.xilinx.installer.api.k.b(Unknown Source)
        at com.xilinx.installer.api.a.a(Unknown Source)
        at c.a.<init>(Unknown Source)
        at c.h.a(Unknown Source)
        at com.xilinx.installer.api.InstallerLauncher.main(Unknown Source)
Any ideas?
Hi @llalonde
Share the xinstall_xxxxxxx.log file here from the location: C:\Users\Administrateur\.Xilinx\xinstall\
Vinay
There's really not much helpful debug messages in that file:
2016-02-01 09:54:48,438 DEBUG: com.xilinx.installer.api.e:? - Log file location: C:\Users\Administrateur\.Xilinx\xinstall\xinstall_1454338467668.log
2016-02-01 09:54:48,736 DEBUG: com.xilinx.installer.api.e:? - Memory usage -- Used memory: 1759 MB. Total memory: 4026 MB
Recent cpu usage for system: 0%
Any other ideas?
