Reg: Installing Xilinx ISE 10.1 or 10.1.3 on Windows Vista or Windows 7 ...
I know that Xilinx ISE 10.1 and 10.1.3 work on Windows XP. I wanted to know if 10.1 or 10.1.3 can also be loaded on Windows Vista(32 bits)? Also, will windows 7 support ISE 10.1.3? Which is the most stable platform for Xilinx ISE 10.1?
I know this link - http://www.xilinx.com/ise/ossupport/index.htm says that ISE design suite is supported by windows 7 professional (32/64 bits) but can someone  please cofirm that this is for 10.1 and all future vesions of ISE? Also, I read on some threads that ISE is  not supported on Windows 7 or Vistas (because it is not mentioned in the supported OS list). So it would be great if someone could tell me exactly which OS supports 10.1 ad which one doesn't so as to clarify things to me?
Thanks for your inputs ...
Z.
To be more specific, you can read 10.1 Release Notes.
http://www.xilinx.com/itp/xilinx10/books/docs/irn/irn.pdf
Refer to Chapter 3 > Operating System and Architecture Support
The following answer talks about OS support on current and previous ISE tools.
http://www.xilinx.com/support/answers/18419.htm
see, that's the issue ... the hyperlink that I provided says ISE design suite is supported on Windows 7 professional (32 and 64 bit versions), but the link you provided does not mention support for 10.1 on Windows 7. It says that vista supports 10.1, which is not mentioned in the hyperlink !!!!!!!! So its a confusing situation!!!!  :smileysad: :smileymad:
So which OS supports 10.1 and/or 10.1.3 .... my question still stands ...
Please help clarify ...
Z.
I think the answer is pretty clear. The link you mentioned is highlighted as CURRENT release (which refers to 13.x).
The answer also lists OS support for previous ISE release (11.x, 10.1 ...).
For 10.1, the supported OS is Windows XP and Vista.
Windows Xp
@zubin_kumar31 wrote:
Z.
Anonymous
Not applicable
I tried installing  webpack 10.1 full product installation on windows 7 professional 64 bit machine. At first i was able to install and due to improper driver installations i uninstalled and tried reinstalling it but it says
"The program can't start because LIBWICLIENT.dll is missing from your computer. Try reinstalling the program to fix this problem."
COuld anyone please help me out with this.
Sujith Perla
I had the same issue. OPen cmd promt as an admin, type wdreg. You will get all command list. Try following.
(1) In a command prompt browse to your C:\Xilinx\13.2\ISE_DS\ISE\bin\nt64 directory on 64 bit installs or C:\Xilinx\13.2\ISE_DS\ISE\bin\nt on 32 bit installs
(2) To uninstall  type the command - wdreg -compat -inf %cd%\windrvr6.inf uninstall
(3) To reinstall type the command - wdreg -compat -inf %cd%\windrvr6.inf install
please reply  with correct procedure
yes it allow to download
