Regarding liscence of zync706
we have purchased  EVAL-TPG-ZYNQ3(Xilinx Zynq®-7000 All Programmable SoC Evaluation Kit) board From analog devices. Can you please let us know whether Xilinx Vivado license is available as a part of our purchase.
Re: Regarding liscence of zync706
Hello @omsainath ,
Xilinx ZC706 Evaluation Kit do come with a licensing voucher for the 'Node locked and device-locked to the XC7Z045 MPSoC FPGA, with one year of updates' license file.
This license voucher code should be included with the kit that came in with the board. There is a Quick Start Guide leaflet and at the back of it, there is a Step 4: section that explains the steps of redeeming the licensing voucher. In here you'd see the 'Important' section, which potentially your voucher code. e.g.:
I had to mark out the code for the above example.
Can you open the box and see if this Quick Start Guide leaflet can be found?
If not, you'd need to raise an Electronic Fulfillment SR with Xilinx Customer Service team (by logging in to https://www.xilinx.com/support.html#serviceportal -> LICENSING), and they will then be able help you with finding the this voucher code based on the purchase order number you have on the invoice.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
We purchased zynq board from analog devices, im sharing the link https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/EVAL-TPG-ZYNQ3.html#eb-documentation, can i get any vivado liscence for the above board.
@omsainath There should have been a license included. If there wasn't, contact Analog Devices and ask where it is.
Hello @omsainath ,
As correctly indicated by @u4223374 , this Eval kit should have came with a voucher for a Node locked and device-locked to the XC7Z045 MPSoC FPGA, with one year of Vivado updates. In your kit, can you see a Quick Start Guide leaflet with the voucher code on it? If not, then yes, please contact Analog Devices and request this to be provided to you, as this is needed to redeem a license from Xilinx.
Hope this helps.
Kind Regards,
Anatoli Curran,
