Anonymous
Not applicable
Renewal of hardware evaluation license
I am using ISE Design Suite 14.7, with permanent, node-locked licenses for ISE and EDK.
I have been evaluating the axi_can core recently, however, as of today, I am unable to generate the bitstream for my design, as the Full System HW evaluation licenses for all IPs, bundled with my EDK, have expired. This, I presume, is due to the 14-month validity for the evaluation licenses.
On the following page: http://www.xilinx.com/ipcenter/ip_license/ip_licensing_eval.htm#full_system_eval_license, it is mentioned that the evaluation licenses can be re-generated after the 14-month period. However, I see no such option on the Download and Licensing site.
There are options to generate evaluation licenses for a bunch of Logicore IPs, however axi_can is not among them. Am I missing something? How can I renew the HW evaluation licenses?
/Wasif
Re: Renewal of hardware evaluation license
Hi @Anonymous,
Contact your nearest Distributor, or contact someone on this list to generate the license:
http://www.xilinx.com/about/contact/authorized-distributors.html
or genereate it from this link: http://www.xilinx.com/products/intellectual-property/axi_can.html
Accept as solution if it resolved your query, give kudos if reply is helpful.
Nupur
Hi @Anonymous,
Nupur
