Returned license but cannot generate new one
Hi..
I installed Vivado Webpack on one of my computer's partitions that's running Kubuntu. It was activated and working. Then I installed Vivado on a different partition running Ubunut. I know that I need to return the first license first, and that's what I did. I opened the Kubuntu partition and open VLM and returned the license, and it returned successfully. However I still cannot generate a new license for the second installation.
The option for Activation Based Licenses is greyed out. What should I do?
Re: Returned license but cannot generate new one
Hello @sudani93,
Yes that is the problem. Make sure that you are using supported version of Ubuntu OS. You will get supported version in release notes. For Vivado 2015.3, Ubuntu Linux 14.04.2 LTS (64-bit) is supported.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug973-vivado-release-notes-install-license.pdf (page #14)
Ashish
Hello @sudani93,
Have you checked below answer records?
http://www.xilinx.com/support/answers/61574.html
http://www.xilinx.com/support/answers/62711.html
Ashish
Thank you for the reply.
I followed the instructions in the second link, and I initialized the trusted storage. Here is the output of the VLM save link as..
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
<html>
<META HTTP-EQUIV="Refresh"
CONTENT="0; URL=http://license.xilinx.com/getLicense?group=esd_oms&os=lin64&version=2014.4&licensetype=2&ea=000000000000&ds=&di=&hn=islam-Inspiron-7520&umn1=&umn2=&umn4=&req_hash=7C2B0E94EDE966877A111A345C5D4A4526399A0D&uuid=7C2B0E94EDE966877A111A345C5D4A4526399A0D&isserver=0&sqn=1&trustedid=1&machine_id=207225D40252D30FF2F45487CD9C976243554B1C&revision=DefaultOne&revisiontype=SRV&status=OK&isvirtual=0">
<head>
<title>Vivado License Manager (VLM) - redirect</title>
</head>
<body>
Redirecting...
<a href=http://license.xilinx.com/getLicense?group=esd_oms&os=lin64&version=2014.4&licensetype=2&ea=000000000000&ds=&di=&hn=islam-Inspiron-7520&umn1=&umn2=&umn4=&req_hash=7C2B0E94EDE966877A111A345C5D4A4526399A0D&uuid=7C2B0E94EDE966877A111A345C5D4A4526399A0D&isserver=0&sqn=1&trustedid=1&machine_id=207225D40252D30FF2F45487CD9C976243554B1C&revision=DefaultOne&revisiontype=SRV&status=OK&isvirtual=0>Click here if you have waited for more than 20 seconds</a>
</body>
</html>
However, the activation option is still grey.
Hello @sudani93,
Can you attach this file here ?
Ashish
I think the problem is that umn1=&umn2=&umn4= are all empty.
Hello @sudani93,
Ashish
I am using Ubunut 15.10 and Kubuntu 15.10.
I just tried installing Vivado 15.3 but I still cannot get the license. Is there anywy to get the license on Ubunut 15.10 without downgrading to 14.4? (P.S. It runs Ok and I can get license on Kubuntu 15.10).
Hi @sudani93
Do you have any network interfaces on the ubuntu machine?
What are the names of network interfaces? Are they named as ethX format or any other format?
Vinay
Hi @sudani93,
Can you run below command in Vivado Tcl shell and share the output file (xinfo.txt).
report_environment -file xinfo.txt
--Syed
Thank you all for your support.
I have downgraded to Ubuntu 14.4.2 and now it is working fine. Thanks again.
@sudani93,
Glad to know that the issue is resolved.
Please close the thread by marking the post as Accept as solution.
--Syed
